Question about Kenmore Dryers
I have a Kenmore 70 Series Model 11064732400. the drum stopped turning so I took the housing off and the idler pully was laying at the bottom of the dryer. I cannot tell from the diagrams where it belongs...meaning the right position....any thoughts?
  • Kenmore Master
  • 8,220 Answers
Posted on Nov 15, 2010
Testimonial: "You are WONDERFUL GURU!!! Bless you"
Kenmore 70 Series Dryer Belt Keeps Breaking
A few things to check. Make sure that the idler pulley is turning freely without any signs of distress from the bearings. Make sure that when the belt is installed that all drum, motor and pulleys are perfectly in line. Even a small amount of misalignment will cause premature failure. Turn the drum by hand and make sure is turns fairly freely. There will be some drag from the drum supports, but it should turn readily with one hand, if it is any stiffer then the drum supports may be badly worn and will need to be replaced. Make sure that the pulleys on the motor and idler are in good condition and not damaging the belt. There are basically only three main reason for a premature failure, misalignment, pulley damage and overloading. It has to be pone of those.
Nov 26, 2017 | Kenmore Whirlpool Maytag Dryer Belt...
Drum is hard to turn. When running, there is a loud high pitched squeal. I oiled the pully area in the back, and the noise stopped and the drum turned, briefly. Now, the drum doesn't turn at all. ???
if you got oil on the belt or the part of the pully where the belt rides then the belt is sliping and wont turn the drum.
you will need to get the oil off of the belt or buy a new one and you will need to get the oil off the motor pully and the idler pully and if any oil is on the drum.
This is where I would start given the information you have given.
Oct 06, 2010 | Kenmore 83042 Electric Dryer
My kenmore 70 series dryer won't run. when I push the button, it makes a sound [like it did when it would run], but the dryer doesn't catch or start running...it seems like it is trying to, but it won't...
Reach in and turn the drum. It should be very easy to turn. If it is hard to turn you need to determine if it is :
If you have this crappy idler db00084.jpgchunk it in favor of the one above with a wheel. The glide band and feltd4503ef.jpg
The motor.e526c9d.jpg I have a manual
Apr 09, 2010 | Kenmore Dryers
Cannot put the drum belt on
make sure the bracket is properly cliped to the base and the iderl wheel is twords the tub
pull the bel together under the tub, take the loop, pull it under the pully, lift the pully slighltly, place the loop on the motor
Oct 14, 2009 | Kenmore 74602 Gas Dryer
Motor runs but drum doesnt spin
The belt may have broken, you must open the dryer case and check the belt. If broken, you'll see it laying on the bottom
May 18, 2009 | Kenmore Dryers
We have an electric Kenmore 70 series dryer that is making very loud noises - still drying well otherwise. Husband just took off front and top, and took out drum - still makes same noise when just motor is...
check yopur blower wheel and blower wheel housing...turn with hand to check motor bearing,,if motor bearing tell husband a little bit of wd 40,,or white grease at each end
Dec 28, 2008 | Kenmore 63942 Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Replaced idle pulley but drum wont spin when clothes are in it
Ok, when you removed the front cover to gain access to the idler pully, did you make sure that the drum didnt slip off one of the two roller wheels in the bottom rear of the dryer. If you get one of those roller wheels jammed and not in the track right, they will jam up. Look down at the bottom, grab the rollers, and pull them forward to be sure they are in the groove of the drum. Also, are you sure you relooped the belt correctly back around the idler pully? The best way to loop the belt is to place the idler pully in the correct position, then drop the belt down in front of it, loop the belt under the idler pully, push it back to tension everything, then take the loop and go over the motor pully (should be pretty tight). See if one of those solutions will help. Also be sure that you are properly getting the drum in the right position over the front seal (front should go on pretty easily, if not, reach your hand in the door, and lift up on the drum to center). Thanks and good luck!!!!
Jan 25, 2008 | Dryers
Kenmore series 70 electric dryer idler pulley
I figured this one out...there are two pairs slots...the tab of the idler pulley goes in the right slot near the motor and the idler pulley goes off to the left.
Nov 13, 2007 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
543 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
