Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
I was given a GE supersoft 39 smart water softner. I want to get an installation manual & an operators manual. For somereason I can not find them on line. Will you be able to hellp
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 306 Answers
Here is your link to GE for this unit. All the manuals you need should be here.
RJ
Posted on May 17, 2011
Install problems ge hybrid water heater
1) Copy following links for detailed resources:
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
2) T2 is tank temperature sensor failure located just above upper element.
Call for service/ warranty.
Call GE 888-433-4394
3) Was water heater completely full of water before applying power.
Do you have 10 gauge wire and 30 amp breaker.
Is unit receiving 208-240 Volt power. Click breaker fully on-off.
Move wire to another same size circuit breaker.
Mar 03, 2013 | General Electric Ge Appliances GEH50DNSRSA...
Control on whirlpool EEZ8OHD055V Blinks twice, no hot water
1) Call Whirlpool. 1-877-817-6750
Have them send 2 new thermistors (temperature sensors located above each element), and then install according to the instructions they give you.
2) Sounds like you have the American brand older energy-smart electric water heater with grey control box on top
Copy following link to exactly identify product and resources
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html#energy-old
3) Two flashes is 'high water temperature shut down.
Buy cheap multimeter from hardware store. Install battery. Set to read ohm, the upside down horseshoe symbol.
Use multimeter set to read ohms, and test thermistors
Copy following link for general service manual showing error #2 and thermistor resistance chart on page 10
http://waterheatertimer.org/pdf/Energy-Smart-troubleshooting-guide.pdf
Oct 07, 2012 | Water Heaters
I have a GE hot water heater, SE40M12AA01, dual element w/'smart lights'. 7 days ago a licemsed plumber replaced the lower heating elemnet. Today after having no hot water I checked the breaker, &...
1) You posted under Rheem-GE electric water heater.
If upper element is burned out, then water heater will not heat any water.
http://waterheatertimer.org/How-it-works.html
2) Replace upper element:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3) Open following link for complete troubleshoot:
This troubleshoot assumes you have standard thermostats and elements.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
4) Manuals and links. I do not see 'smart lights' in the manual.
http://products.geappliances.com/ApplProducts/html/GEAResults.htm#Category=Standard_Water_Heaters
Troubleshooting starts page 15.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=AP12168-7%20%28GE%20Elec%29.pdf
5) Add a comment with your experience so other with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 25, 2011 | General Electric Water Heaters
My smart water softner tank is filling up with water and will not drain
The eductor assembly is plugged. This is where the brine is drawn in to regenerate the system. It is the space capsule looking thing on the left side of valve. The owners manual has directions to repair this. You may find your manual here.
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=GXSF30H
RJ
Jan 30, 2011 | General Electric GE SmartWater Household...
M#GX1SO1C fittings for water in & out connection
This is the install manual for this filter housing. This should answer your question.
http://lib.store.yahoo.net/lib/yhst-29697636949810/fxutc-installation-manual.pdf
RJ
Jan 15, 2011 | General Electric GE SmartWater Household...
I just installed 2 new GE-GXWH40L filters installed on each side of my new GE water softner. I can not get water to go through the filter. Works fine in bypass. I triple checked the flow direction and it...
This is proabably not the case but I have seen it happen, Have you checked the outlet side of the filter to make sure it was drilled when it was made. Thank you
Nov 29, 2010 | General Electric GE SmartWater Household...
MY GE SMART WATER FILTRATION HAS A DRIP ON THE
If it is coming from the canister, pull it off, check the o-ring, it is probably pinched. It will need to be replaced.
RJ
Mar 29, 2010 | General Electric GE SmartWater Household...
I have a ge smart water electric water heater and
does it not have adjustments for heat settings. I thought these were smart as in maintaining heat with demand
Mar 05, 2010 | General Electric GE SmartWater Household...
Instruction manual for ge smart water filter
Here is the website that you can get your users manual. You will need the model #. Pls rate ny answer
Kurt
http://www.geappliances.com/service_and_support/literature/
Apr 19, 2009 | General Electric GE SmartWater Household...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
754 people viewed this question
Top General Electric Water Heaters Experts
paulcarew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
