Question about Panasonic TH-42PX80U Plasma TV
I have a Panasonic Plasma TV Model number TH42PX80U the picture just went out and now the power button just blinks twice and then pauses blinks twice again and so forth. NO PICTURE JUST THE 2 BLINKS. Had the set for 2 yrs and can't beleive this could happen so soon! I contacted panasonic and they just told me I had to take it in for repairs that theres nothing they can do! With all the problems people are having with the blinks they should recall these t.v's and fix the problem. I had it connected in the front panel with hdmi to my dvr from comcast. Any help would be appreciated!
    Top Expert:
  • Panasonic Master
  • 75,169 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Apr 22, 2017
  • 367 Answers
SOURCE: Panasonic plasma
If you open the back,look at the can shaped items.If any of them have the tops bulged out,they need to be replaced.This should solve your picture problem,unless there is something else wrong.What is happening,is they are heating up,and the picture goes out.I bet the longer you have the TV off,the longer it stays on?Hope this helps.Thank You very much! Tyler
Posted on Apr 07, 2008
stonephoenix
  • 563 Answers
SOURCE: Panasonic Plasma screen suddenly has a verticle black line
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 03, 2009
  • 108 Answers
SOURCE: I have the same problem Panasonic Plasma TV wont come.
Alot of times capacitors on the power supply circuit board will go bad. They will bulge/dome or dry up which will cause this problem. Bad caps dont hold a charge, which is needed to maintain a voltage. The circuit board is two sided which makes replacing the caps difficult, and the board can be damaged and have to be replaced. Taking it to a repair shop may be cheeper and safer then doing it yourself. Having two-six caps replaced is a lot cheeper then a new board.
Posted on Aug 15, 2009
  • 8457 Answers
SOURCE: 10 red blinking lights on my Panasonic Plasma TV,
The power supply board is dead,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Jun 24, 2010
walesarumi
  • 6993 Answers
SOURCE: My Panasonic TH-50PZ800U plasma TV
This is not video board problem. It is actually a power supply problem.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Feb 02, 2011
Panasonic viera tv model #TC-L42U25 Had a lightning strike tv went off. Hit power button it comes on no picture or sound then turns off and flashes code 12. Is there any hope? Thanks,Patrick
Most likely your A board, which is the main circuit board. Best to call a technician for that. This may help.
http://electronicshelponline.blogspot.com/2012/05/panasonic-plasma-tv-blinking-codes.html
Apr 21, 2017 | Panasonic Televison & Video
Panasonic TC-P55UT50 plasma went black. power light blinks 7 times, pauses blinks 7 times. Is this a power board? or Y-Sustain?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Oct 06, 2016 | Panasonic Viera TC-P55UT50 55" 3D 1080p...
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Th42px80u- tv wont come on and red light flashes 10 times
Here are all the Panasonic blink codes.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Oct 21, 2009 | Panasonic Viera TH-42PX80U Plasma TV
I have Dish Network Remote but there is no LG TV Code. How can I get?
8006
Thats a goldstar code and the buzz on the web is it works 50% of the time.
I just found this as well never tried it but it may work good luck
you want to know the code to put in just do these steps:
1. press and hold the tv button till the all the top buttons turn red
2. press the # button twice
3. the tv light will blink out the code to you. It will blink the first number then a pause then blink the 2nd number then a pause then blink the third number. For Sony2.gif you will see 5 blinks, pause, short blink, pause, short blink. (short blink means a zero) the code for sony is 500
4. Thats it!
Sep 14, 2009 | LG 50PX5D 50 in. Plasma HDTV
Sony 62" Power TV Problem
Is your model KP61HS10? If so I can help you?
Jan 13, 2008 | Sony KP-61HS10 61" Rear Projection...
Power light blinks, but tv won't come on
I have the 52" version of the Viera model. Mine went out last night and started blinking twice over and over again. I suspected overheating so i just went to bed and tried it in the morning with no luck. Then I unplugged it for more than ten minutes and plugged it back in and everything worked fine. I hope this helps.
Jan 08, 2008 | Panasonic Televison & Video
Panasonic TH-42PX80U Plasma TV Logo
49 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
