Question about Car Audio & Video
Car radio wiring color coding. - Car Audio & Video
    Brigadier General:
  • 6,966 Answers
Specifically for what make and model of head unit pls?
Most current car radio would be using:
Yellow - +12V Constant Power/always on such as the battery's + terminal
Red - +12V Switched (accessory) Power such as the ACC terminal of the ignition switch
Blue - Power Antenna
Blue/White - Amp Turn-on
White - Left Front Positive Speaker Wire (LF+)
White/Black - (LF-)
Gray - Right Front Positive Speaker Wire (RF+)
Gray/Black - (RF-)
Green - Right Rear Positive Speaker Wire (RR+)
Green/Black - (RR-)
Purple - Left Rear Positive Speaker Wire (LR+)
Purple/Black - (LR-)
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 19, 2008
I need the order of the color coded wires on the conector for a Dual model xd122 please
If you are installing a radio, I recommend you purchase a wiring harness. You will hook your radio up to it and then be able to "plug" your radio in. It has the wiring color codes on the package.
Sep 06, 2011 | Car Audio & Video
I need wiring diagram for a deh 2100 pioneer
If you are going to install the radio, I recommend you get a wiring harness specific to your vehicle. It will have the color codes on the package. All aftermarket radios have standardized color coding for wires. hope this helps
Aug 27, 2011 | Pioneer Car Audio & Video
Need to know witch ones are speaker wires
If you are installing a radio, I recommend you purchase a wiring harness specific to your vehicle. It will have the color code on the package. All aftermarket radios have standardized wire color coding.
Aug 27, 2011 | Car Audio & Video
Trying to connect rear speakers in a car to the car raadio. Not sure what wires go where. I am looking for a wire ddiagram for a goodmans raddio serial number G- 172200 0229. Please can you help?
I recommend you purchase a wiring harness specific to your vehicle. Then you can hook the radio to the harness. The harness will have the color code on the package. All aftermarket radios have standardized color coding.
Wiring diagram pioneer deh-p4950mp
If you are installing the radio, I recommend you purchase a wiring harness to your specific vehicle. The wiring harness will have the color code and all you have to do is match colored wires. All aftermarket radios have standardized color codes for their wires. Hope this helps.
Aug 25, 2011 | Car Audio & Video
I need Only color coding for wiring diagram for cdx-gt550
If you are planning to install your radio, I recommend you purchase a wiring harness specific for your vehicle. All aftermarket radios are standardized in wiring colors. The harness will have the diagram to hook your radio to the harness. The problem with hardwiring a radio is the wiring colors don't match, and hooking it up wrong could fry your entire electrical system. You can find a harness at www.crutchfield.com Hope this helps.
Aug 23, 2011 | Car Audio & Video
I need a color coding of the wiring for the harness i was given for my kenwood dpx308u. i just need to know which colors belong to which wires
Ok, you should have a wiring harness that plugs into the radio. That comes with the radio. You will need a wiring harness that is specific to your vehicle, this will plug into the vehicle harness. The wiring harness will have the correct colors to attach your radio to it. All aftermarket radios have standardized wiring. I recommend not attempting to hardwire your radio due to the risk of frying your entire electrical system. I hope this helps.
Aug 19, 2011 | Car Audio & Video
Color codes for audio wiring on a 1995 ford thunderbird
1995 Ford Thunderbird Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Black/Orange
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Dimmer Wire: Light Green
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: Dark Blue
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
HAVE FUN!
May 24, 2009 | Car Audio & Video
Need color code for radio harness
Hello Mexicano1037,
Here are the colors for the radio harness on your '91 Escort.
1991 Ford Escort Radio Color Codes
Battery Constant 12v+ Wire: Blue/Red
Accessory Switched 12v+ Wire: Blue/Black
Ground Wire: Black
Illumination Wire: Red/Black
Left Front Speaker (+): Violet
Left Front Speaker (-): Blue/Orange
Right Front Speaker(+): Blue/White
Right Front Speaker(-): White
Left Rear Speaker (+): White/Blue
Left Rear Speaker (-): Red/Blue
Right Rear Speaker (+): White/Green
Right Rear Speaker (-): Blue
Hope this helps.
Apr 12, 2009 | Car Audio & Video
I need radio color codes for a 2001 fordranger
The simplest way to figure out wire colors on the ford is to purchase the radio wiring harness from a stereo shop like a Metra or Scosche harness and match the aftermarket wiring color code to the opposite side (vehicle side) of the radio plug. If you are just replacing speakers, then removing the speaker from the car with the plug attached, you can easily figure out polarity. Just connect a 9v battery to the speaker leads on the speaker (NOT THE CAR) for a second will make the cone either pop out or **** in. When the cone pops out, note the polarity of the + on the 9v battery. This is the positive for the speakers. Hope this helped.
Aug 03, 2008 | Car Audio & Video
Car Audio & Video Logo
104 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
