Question about Microsoft SideWinder Force Feedback Pro Joystick
I have a 25 pin microsoft sidewinder force feedback pro joystick which I use with a flight simulator. After updating to win 7 x64 I need to convert this to usb for the hardware to be viable. Any suggestions including a converter which can be built. Kindly notify please sanjay bajpai
Hey m8,
stumbled over your post while searching for sullotions for the same kind of problems.
I also have a perfectly working M$ sidewinder FF pro, trying to get it to work WITH force feedback.
However I am affraid there is no way to do this. From what I read is the gameport to slow to keep up with nowaday PC speeds :(
I got the joystick working up to windows XP (in XP it lost its FF tho and slowed down gameplay sometimes. Not sure if that was caused by the joystick or the game itself running in some compatibility mode). I was using the gameport from an old soundblaster live! by the way.
I did find something that may be usefull for you tho. Check the link below:
http://social.technet.microsoft.com/Forums/en/w7itprohardware/thread/20fa2ccd-061b-4864-abbd-96d1a9871a2f
I havent tested this yet myself and it will require a creative soundcard but I think it will have a better chance of working that using some converter from gameport to USB.
Posted on Nov 25, 2010
Have microsoft sidewinder force feedback pro with 9 pin connecter.need usb adapter
You have the old game port connector. I have one of those too and researched it and even bought one of the adapters. What I found is that the adapters will generally work EXCEPT if your unit has force feedback. The force feedback versions of the MS sticks uses a special protocol that the adapters can't handle. I haven't looked recently, but if you look for an adapter make sure it says it will support force feedback (most will say they don't). In my case I just bought a new joystick.
Dec 27, 2012 | Microsoft SideWinder Force Feedback Pro...
I need drivers for microsoft sidewinder force feedback pro joystick that works with windows 7 64bit
buy a joystick that will work with win7, because the MS Sidewinder has no driver, and MS has no vested interest in developing one...
Jan 18, 2010 | Microsoft SideWinder Force Feedback Pro...
MCFS Joystick Problem
Make sure, that your Joystick is compatible with the version you are having problems with. If not, make sure that it's enabled in the configuration of MCFS. If none of those work, you will most likely have to purchase a more compatible Joystick.
Matt P,
Computer/Gaming Relations Team.
Sep 16, 2009 | Microsoft SideWinder Precision Pro 2.0...
No force feedback only with Flight Sim. 2004
O-the sweet feel of a Microsoft Sidewinder Force Feedback lets see if I can be of some help. there could be any number of things going on but I'm going to give this a try. have you checked the settings in Flight Simulator 2004 seems to me that I remember a check box that said disable force feedback make sure that is unchecked. also in the settings for your controller there is a box that says enable force feedback make sure that is checked. then make sure if you are using a firewall like zone alarm you are in gaming mode because this used to give me major headaches with my system to the point I had to detach from the internet and shut down my firewall to play my games. if this doesn't work you may have to reinstall the drivers for the sidewinder this is the last easy option and it should repair any broke links and reset itself into your system. Please let me know how this helped if you need more Ideas just contact me.
Jul 24, 2009 | Microsoft SideWinder Force Feedback 2...
Microsoft Sidewinder Force Feedback Pro 2 Drivers
You should be able to download them from the Microsoft web site.
Jun 15, 2009 | Microsoft SideWinder Force Feedback Pro...
Need a port for my MS force feedback pro
Just get yourself a new soundcard with a gameport on board. Disable your MoBO soundcard if you have one and instal the new one. Creative is probably the safest option. Update the drivers and off you go. Don't forget to add the joystick, the drivers are supplied in XP.
Jan 15, 2009 | Microsoft SideWinder Force Feedback Pro...
Combat flight simulator wont recognize my sidewinder precision 2 joystick on vista but it did on xp?
I am farmiliar with most flight simulators and know that you have to go to settings on the main menu the controls and select joystick, enable joystick and/or calibrate joystick. If this doesn't wok then in gameplay push "alt" on your keyboard if the task bar for flight simulator isn't at the top. Once or if it is allready there select settings and then enable joystick. If this doesn't work then call or contact or google microsoft flight simulator.
Jun 25, 2008 | Microsoft SideWinder Precision Pro 2.0...
The Software
I have same stick, that same software wont work with xp or vista depending on what game you have you should be able to set up in input settings for the game , there was a patch at one time that someone made up you mite want to try here and do a search > http://forums.ubi.com/eve/ubb.x?a=frm&s=400102&f=49310655
Grazz.
May 18, 2008 | Microsoft SideWinder Force Feedback 2...
Microsoft's Sidewinder Force Feedback Pro Driver
Sorry to report that there is no driver for this stick that will allow the feedback to work with Win XP. I wanted to cry when I first found this out. I've been searching since the mid 90's for a work around for this. We can send a man to the moon and back on less than 1 meg of ram. But someone can not get this stick to work properly with Win XP?
That REALLY SUCKS!!!
Dec 28, 2007 | Microsoft SideWinder Force Feedback Pro...
Microsoft SideWinder Force Feedback Pro Joystick Logo
401 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
