Question about RCA DRC247N DVD Player
I put the dvd in the slot and the machine takes a very long time loading and the the it says no disc. I also noticed one time it said ps off
  • RCA Master
  • 8,457 Answers
Tries it with many other DVD discs,If u have the same result the DVD player Laser eye is having problems and it dying,not reading Data's from the DVD disc anymore.If not,that only DVD disc,that have problems,than check DVD disc for smushes,grims and cracks on the DVD disc itself.If it is the DVD player having problems with it Laser eye and it dying.The DVD player is junk not worth repairing.The DVD player sell really cheap these days,like $40 for a brand new one.
Posted on Nov 15, 2010
Load disc, unit tries to load & play, unit shuts off. Turn power on to set time,etc,machine shuts off.
Laser pickup unit fault. The unit alongwith its flat connecting cable should be replaced. Contact any service technician. Electro help
Feb 23, 2015 | Samsung DVD-V2500 DVD Player
Tip
Mintek factory solution for the forever loading disc problem.
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
on May 29, 2009 | Mintek MDP-1770 Portable DVD Player
When i put in a dvd, it makes clicking noises, after that a notice
follow this steps and fix it. God bless you
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Nov 14, 2012 | Sony Televison & Video
My playstation has stop loading,but the disc continue spin
Hello, this problem is common. PS1 is a great machine, but the laser disc lens after serving us for years at one point it stops reading discs. Usually this problem doesn't happen suddenly, but there is a time period in between where sometimes it loads games and sometimes not. If you've noticed this symptom, then you may try to bring few more life to the PS. - Switch off your PS and open the round cover, locate where the laser lens is. Wet a cotton bud with one or two drops of a common glass cleaner. Clean very gently the lens for like ten seconds with circular movements, wait one minute so it'll get dry. Now put your game in and see if it has worked. You may try more than one disc if the first doesn't load, because some games are easier to load. - If this won't work, you may try to put your PS standing in vertical. Put it on one of its side, maybe better standing on a wall or on the side of the tv. It may sound weird, but sometimes it has worked for me. If one side wont work, just try also the other one. - If none of the above will work, i may suggest you to get a new one, on ebay you can find still many PS for few bucks.
Hope it'll help, good luck! Peter
Aug 03, 2010 | Sony Video Game Consoles & Games
Loading but nothing happens
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.I hope this information helps your problem.
Apr 07, 2009 | Mintek MDP-1810 Portable DVD Player
WILL NOT PLAY A DISC
Apr 03, 2009 | Mintek MDP-1770 Portable DVD Player
Disc does not spin and shows on screen that there is no disc
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
Oct 07, 2008 | 2007 GMC Acadia SLE
Can't get past LOAD
it might need to be cleand u take the sheild off and take a q tip and lightly clean the laser
pls rank ps keep off the carpit
Jan 23, 2008 | Samsung DVD-VR357
RCA DRC247N DVD Player Logo
308 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
