Question about Intel Desktop Board D865GLC (MBIND865GLC) Motherboard
How do I reset the CMOS settings on this motherboard (D865GLC)?
    President:
  • 1,901 Answers
The easiest way to reset the CMOS is to pop the coin-type battery out for a few minutes, reinsert it, then reboot your computer.
NOTE: Make sure you unplug the power cord and then hold the power on button in for about 5 to 10 seconds. This will drain any stored energy in the system. (Capacitors)
Thanks for using Fixya.
Posted on Nov 15, 2010
I'm trying to format my computer, and when I go into BIOS settings it is in "View Only" mode so I cannot change the boot priority to CD-ROM. I tried to access the boot menu after restart by trying every F...
Here is a site that has the information you need. It took 5 seconds to find using Yahoo.
http://www.intel.com/support/motherboards/desktop/d865glc/sb/cs-008973.htm
Sep 26, 2013 | Intel D865GLC Motherboard
I m having trouble with my SONY VAIO (VGN-FE770G). i forgot my bios password. kindly send me a solution.
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jul 03, 2011 | Computers & Internet
I started my pc with no software and os loaded and I got the message: WARNING: CMOS checksum Error My motherboard is: DH61BE and the bios ver. is BEH6110H.86A.0020.2011.0218
This is an error that occures when the BIOS has lost the CMOS settings. This usually happens if the CMOS battery has drained completely.
The solution is to first try to reload CMOS settings. you can do this by pressing DEL at startup and getting into BIOS. then find the "reset to defaults" setting and reset the CMOS settings. This should solve the problems.
If that doesnt help, then you would have to change the CMOS batter on your motherboard. This is a quite simple task. It is a standard battery and is quite cheap.
Also some motherboards have a CMOS battery connector jumper, refer to your motherboard manual and check if you have this and reset it.
These are all simple tasks, but get someone to help you if you don't feel comfortable doing it yourself.
--------- Please rate the answer if it was helpful. Thank You!
May 22, 2011 | Computers & Internet
Need ethernet controller driver - d865GLC motherboard - MPC345
You can download the LAN driver for the motherboard D865GLC from the website given below:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=950&DwnldID=8659&lang=eng
Regards
May 24, 2010 | Intel D865GLC Motherboard
No sound .multimedia audio driver controller not installed. mother board D865GLC
Go to this page: Intel D865GLC Support
For drivers go down and click on "Search for all the latest drivers"
Narrow the list by selecting your Operating System and Drivers.
Apr 01, 2010 | Intel D865GLC Motherboard
Cmos error-defaults loaded failed!
Please follow the following step to correct this error:
1. Change the CMOS battery,
2. Reset the CMOS Settings by using the CMOS Jumpers on the Motherboard.
3. Start the PC, enter BIOS setup.
4. Load the default settings
5. Save, Exit and restart the PC
Thanks
Geodavis
Nov 20, 2009 | Intel Motherboard
Intel D865GLC Mother Board which wont save changes to BIOS
Hi Hans
Try to restore the bios to factory defaults.
then restart the Computer and then change your settings again and see if it works then
Apr 26, 2009 | Intel D865GLC Motherboard
Please explain the difference between Intel ATX board D865GLCL vs. D865GLCLK.
Hello edk2,
Here are the diferences in the models of motherboards:
D865GLCLK: Video, Audio, Gibabit LAN D865GLCL: Video, Audio, 10/100 LAN D865GLC: Video, Audio
This means that the D865GLCL has the Fast Ethernet LAN Interface on-boardwhile the D865GLCLK has the Gig-E LAN Interface on-board. However, the D865GLC does not have an on-board LAN Interface.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 27, 2009 | Intel D865GLC/ D865GLCL/ D865GLCLK MB,...
I bought a mother board from a swap meet but it didnt come with the wiring up diagram and im lost as to how to wire it up only for the power reset etc.. not sure which way they plug into i think i have...
Hi kjstenny, not sure where you saw the board E210882. This is not a valid Intel model number. The Intel D865GLC is a valid model number & you can download the manual for this at the link below:
http://download.intel.com/support/motherboards/desktop/d865glc/BFLC_English.pdf
Main Intel link for D865GLC:
http://support.intel.com/support/motherboards/desktop/D865GLC/LC_manual.htm
MB layout page 14 & 15. Than see page 13 block D, J9J1 Front panel pins. Page 43 for jumper connections.
Intel D865PCD (Matched). Front panel, page 34 & 35. Download manual at this link:
http://download.intel.com/support/motherboards/desktop/d865pcd/sb/cdenglish.pdf
Main link: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1671&lang=eng
Intel D865PCK - (No Match). (Or no longer listed).
D865PE50 - (No Match). (Or no longer listed).
The most common wire color for each 2-pin connector will be negative, including the color black.
Good luck kjstenny!
Still need help, just post your question.
Mike
Dec 03, 2008 | ASUS A7S333 Motherboard
Computers & Internet Logo
447 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
