Question about Dirt Devil SE2800 Spot Scrubber Handheld Wet/Dry Vacuum
I lost my directions. What are the steps for using the scrubber?
Do I need to take my scrubber dryer for maintenance?
To help keep your scrubber dryer performing at its best, and to ensure efficiency and safety, you should take it to be serviced at least once per year. There are companies that specialise in the repair and maintenance of cleaning equipment that can help you with keep your scrubber dryer in tip top shape.
In addition to the annual servicing, you should regularly clean the filters, empty the recovery tank after each use, and ensure that you charge the machine if it is battery operated. There will usually be a manual provided along with the machine that explains the maintenance required in more detail.
Apr 28, 2018 | Vacuums
Hoover spinscrub
I would be careful in mixing solutions with different machines. The steamer carpet cleaner applies the cleaning solution differently than the spin scrub. If anything, I would delude the solution before using it in the shampooer. The steamer automatically deludes the solution, the scrubber directly applies a thick coat.
Elisa Jed ' http://www.babayans.com/en/
May 01, 2014 | Vacuums
Solution wont comeout of the scrubber
Hey Ellen! Not having spray when trying to clean your carpet can be frustrating. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jan 23, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
I HAVE A DIRT DEVIL SPOT SCRUBBER & HAVE NO USER MANUAL & NEVER USED BEFORE. CAN NOT FIND INSTRUCTIONS ONLINE. CAN ANYONE PLEASE TELL ME HOW TO FILL THIS MACHINE & USE PROPERLY? THANKS!
Hi ramond745...
Go to the following webpage and view the operating instructions for your Dirt Devil Spot Scrubber, you can also print the page/s on your printer for later reference.
Please take time to rate me
http://www.ehow.com/how_7830177_operating-dirt-devil-spot-scrubber.html
Aug 16, 2011 | Vacuums
I don't know how to use my Hoover Floor Mate scrubber.
You can download a new manual at www.hoover.com
You just type your model number in and it should pull up the manual for downloading.
If you need parts you can visit our web site:
www.usavacuum.com
Mar 11, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Help!!
Look up instruction manual at
http://www.dirtdevil.com/CustomerService/Manuals/DirtDevilManual.aspx?ManID=325fa4dd-0a38-48aa-b0b0-516143a0875a
Aug 23, 2008 | Dirt Devil SE2800 Spot Scrubber Handheld...
Nilfisk advance floor scrubber vacuum problem
CAN YOU HELP? I AM LOOKING FOR A SMALL FLOOR POLISHER AND SCRUBBER FOR MY OWN USE AT HOME. i SHOULD HAV TWO 5_6" SCRUBBER PADS AND FLOOR POLISHING PADS. THANK YOU AND GOD BLEES. NORSANRAIDERS@MSN.COM LOWTON , OK
Mar 12, 2008 | Vacuums
Dirt Devil SE2800 Spot Scrubber Handheld Wet/Dry Vacuum Logo
118 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
