Question about Microwave Ovens
I have GE Microwave Model JVM1540WMC. Clock works, light comes on when door opens, but none of the keypads work. Tried unplugging, still nothing.
  • 3 more comments
  • ggooder Nov 16, 2010
    Thank you for your quick reply. Tried this again (unplugging), message comes on saying press clock button to set, but there is no response to any of the buttons. Tried holding reset for 10 to 15 seconds but still nothing. Does this keypad just pop open or are there screws to remove?
  • ggooder Nov 17, 2010
    I had a repair guy come in and look at this, he said had to replace key pad which would cost $300, more than the cost of the microwave. Thank you for your idea.
  • ggooder Nov 18, 2010
    Thank you for your help regarding this. How does that panel come off? Do you have to take off the entire outer shell??
    Thank you, I will try to get this thing off the wall this weekend and will let you know the results.
  • ggooder Nov 22, 2010
    The touch pad is not available by itself anymore, you have to replace the entire computer memory, which lists at $265. Plus talking to a few other people on line about GE Microwaves, they have all run into the same problem. Therefore we just bought a new Panasonic. Thank you for you help in this matter.
    President:
  • 1,891 Answers
Will have to replace the key pad . this can be the only thing that is causing the problem. mm hope this helps feed back pls and thanks for using fix ya ..
Posted on Nov 16, 2010
  • dennis dodge Nov 18, 2010
    I didn't find the model you have listed but the key pad at retail is 37.00 / and this is done in the home . service would be about 87.50 . now that is not 300 .00 but we all set our own prices . the job is easy and you mght want to do it your self . question did the tech ck the ribon connections to the prosser . if the conections were not good this would render the pad dead. . you mght just unplug the ribbon and reconnect it //this will sometimes correct the poop connection . mm hope this helps ,,mm inside the control panel is the tech sheet and it will give you the part # i found it oa another web sight for 55.00 / mm
    remove the shell and inside there is a screw holding it in place it lifts up to release . if you remove the wires make sure you makr them so you can put them back. tyr to find the tech sheet inside behind the pad . this will help you to now where thing go and what they are called . . and a parts list with pr #
  • 4,323 Answers
Hi
Try unplugging the microwave for 30-40 minutes. If the error doesn't reset then check for any error code. If no error code is being displayed then keep the OFF/Clear button pressed for 5-10 seconds, this will reset the microwave. In case error is still present then you'll need to check the microwave keypad. Look for a tech sheet hidden inside the unit behind the control panel. Hope this helps... Please post back for any further assistance.
Daniel
Posted on Nov 15, 2010
  • Daniel Scott
    Daniel Scott Nov 16, 2010
    There are screws that you have to remove to replace keypad.
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
Model # MH7149XFQ - 0. Nothing works. No light when you open the door. The control pad does not respond. The light under the microwave does not work. The clock display shows the digital clock but the clock...
1. Go check your breaker box. Find the one for this outlet, reset. Or just reset every one if U cannot figure that out. 2. if that does not do it..... The ck the Outlet w/ a proper tester (cheap @ builders supply, just a plug in tester w/ lite for volts.... too easy. 3. If neither of these work, find the fuse for the microwave & replace. If not qualified, hire or ask someone who is.... 4. none of these work..... time to buy a new one. gettocar
Aug 14, 2011 | Whirlpool MH7140XF Microwave Oven
None of the buttons are working; unplugged and
Depending on the model its down to the keypad
Feb 12, 2010 | Panasonic Microwave Ovens
GE Microwave displaying --F3--
F3 on a GE / Hotpoint microwave means you have a shorting keypad / controls.
There's a chance it can come on by itself and run unattended, which can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open.
On this model, the keypad is not available as a separate part, so you would have to replace the entire controller assembly.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you disconnect the wires and install the new controller.
You can order part number WB07X10903 here for $114.37 (compare that to $174.75 direct from GE!).
Jun 24, 2009 | GE Microwave Ovens
GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Nov 15, 2008 | GE XL1800 1100 Watts Microwave Oven
Clock is flashing - no other buttons will work
hi
it sound like the keypad has died does happan on sharps does the light come on when you open the door ,onother problem that can happen is if one of the microswitches is sticking from storage ,if they are not working in sync then the keypad won't work
cheers grant
Oct 22, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
166 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
