Question about Mitsubishi Televison & Video
Light engine is bad on a Mitsubishi wd-73732 need part number
Get a hold of mitsubishi they are replacing my light engine for free.I am paying $200 to have the authorized mitsubishi repair shop do it.
Posted on Dec 15, 2010
Where can i find a color wheel for a 73732 mit
The way that you change the color on this TV is thru the audio/video menu, under Perfect Color. It show you how in your owners manual on page 74. If you no longer have the owners manual you can downloaded it here http://www.mitsubishi-tv.com/pdf/ownersguides/WD-73732.pdf
Mar 02, 2011 | Mitsubishi WD-73732 73" Television
My mitsubishi wd-65c8 has a flashing green light.. I have replaced the capacitors on the DM board and the same is happening.. what else could be the...
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board. Make sure all bad caps are changed.
Jan 23, 2011 | Mitsubishi WD-65C8 65 in. LCD HDTV
Bad color on mitsubishi dlp wd-73732 hdtv
Light Engine Failure.
Mitsubishi extended the warranty on THIS model to 3 years. Check your manufacture date on the back of the TV, , Then call Mitsubishi. They are replacing light engines and/or replacing TVs with newer models without the problem part.
Jul 22, 2009 | Philips 60PP9202 60" Rear Projection...
Mitsubishi WD-73732 TV
It could be a bad lamp but I've run into many of these TVs with bad color wheel assemblies. Also, if you are getting a dialog box coming up with these words," airflow blocked, TV will shutdown ..." that's a defective thermal fuse.
This is a job for a mitsubishi authorized service center. A tech can disassemble the light engine and confirm that the wheel is the problem. If you're still in warranty, great. If you're only recently out of warranty, call mitsubishi for assistance. Remember that persistance pays off when dealing with large corporations. You very seldom get what you're looking for on the first call or from the first person you speak to.
michtech
Apr 29, 2008 | Mitsubishi WD-73732 73" Television
Half of the screen goes black
the light engine is defective and needs to be changed..this set is not that old..contact mitsubishi customer relations to see about having it done under a customer accomodation, as they have had a lot of problems with the engines
Nov 28, 2007 | Mitsubishi WD-73732 73" Television
Televison & Video Logo
329 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
