Question about Canon PIXMA MP830 All-In-One InkJet Printer
Mp830 fax problem
All of a sudden, my MP830 starts trying to receive faxes for every phone call, when I subscribe to a DRPD service. I checked my settings and don't have the DRPD selection available anymore. Someone at Canon suggested that the country code somehow got changed in the programming, probably due to power failure, etc. Does anyone know how to change this back without taking it to a repair depot?
  • eddiecg Jun 21, 2008
    When I purchased my machine, in New Zealand, it arrived set up for operation in Australia! A techie at Canon talked me through what buttons to press to change it to NZ, and everything was OK. Then the machine got broke, and I was given a new one - which has arrived set up for Australia! Can't remember what buttons we pressed (something to do with the power button, then you press something so many times, and so on), so am looking for that info.
Got an answer from Canon NZ:
1. Press the red Stop/Reset button and keep it pressed.
2. The 'Alarm' light will flash - count 12 flashes.
3. The screen on the Canon will show 'SERVICE MODE' and something #1.
4. Press the right arrow key twice to bring up FAX TYPE #3.
5. Press OK to check the country - mine showed Australia when it should have been New Zealand. Scrolling with the arrow keys shows the countries available for your machine.
Posted on Jun 27, 2008
THEFAX IS PICKING UP THE LINE AND NOT GIVING ME THE OPPORTUNITY TO PICK UP THE PHONE TO TALK
On the operation panel, press the following buttons to select DRPD.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select [DRPD], then press <OK>.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
On the operation panel, press the following buttons to select the correct ring pattern.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [RX SETTINGS], then press <OK>.
  4. Press the right or left arrow button to select [DRPD:FAX RNG PAT], then press <OK>.
  5. Select the proper ring pattern: NORMAL RING / DOUBLE RING / SHORT-SHORT-LONG / SHORT-LONG-SHORT / OTHER RING TYPE . Press <OK>.
  6. Press <Stop/Reset> to return to fax standby mode.
Feb 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 has stopped receiving faxes. When the fax phone number is called it rings but the fax does not pick up.
Can you still send fax? if sending and receiving are not working you can try to update or uninstall/reinstall the software for this unit..
Hope that helps.............
Aug 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Fax stopped operating when FIOS was installed
Verizon is lying to you. fax machines are ANALOG devices and will not work reliablyon DIGITAL phone lines.
Jan 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Fax problem
I can't receive faxes. I have a Canon MP830. Please advise what is wrong. Yhanks
Dec 10, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Mp830 printer
Make sure you use an anolog phone outlet.
Then in setup and the area code and phone number.
Place paper in tray, push fax , then dail number to fax to. The machine has to set to receive a fax .
Oct 23, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Lexmark x73
Yes you need to connect to computer to receive and send fax........ Telephone as to connected to dial up modem of the computer if you dont have dial up modem then the faxing wont work.........
About Distinctive Ring Pattern Detection (DRPD)
"Distinctive Ring" is a service provided by some telephone service providers. Two phone numbers are assigned to one phone line so that you will hear different ring patterns for incoming phone calls than for incoming faxes. If you subscribe to this service, follow the instructions below to program your All-In-One to use it.
On the X125:
Press Setup once, then press Menu nine (9) times until DRPD appears on the display.
On the X63:
  1. Press Setup once, then press Menu eight (8) times until DRPD appears on the display.
  2. Press Options until you see Learn, and then press Start/Yes.
  3. Dial the phone number that you want to use as a fax number. (Do this from a different phone line, not from the line the fax will be installed on.)
  4. Press Setup.
  5. Press Menu until you see Fax Receive Mode on the display.
  6. Press Options until you see DRPD, and then press Start/Yes. The All-In-One detects the ring pattern and answers all incoming faxes on the second ring.
Sep 20, 2007 | Lexmark X73 All-In-One InkJet Printer
Receiving incoming faxes
# Press the button to enter Fax mode. # Press . # Press the right or left arrow button to select [Receive mode settings], then press the button. # Press the up or down arrow to select the receive mode that best suits your needs(you probably want "FAX ONLY" When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only), then press . # Press repeatedly to return to fax standby mode.
Aug 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Cannot figure how to set up Canon MP830 All in One Fax machine with remote answering machine
Cannot figure how to hook up Canon MP830 all in one fax with remote answering machine. I can plug in phone line to send faxes fine but when hooked up in same hole and the phone rings it goes immediately to fax and can't receive phone calls. Maybe i have phone line hooked up in wrong place on my machine. The answering machine is in our master bedroom on the other side of the house. With my last a canon also i had it hooked up to go to fax after a certain amount of rings and it worked fine. That machine got fried by lightening and i replaced it with this machine. If anyone knows what i am doing wrong i really need this fax hooked up all the time for my business.
May 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830
When i am trying to fax a document it is saying that the memory is full. But when i go to the menu and to fax memory it is saying empty. How to solve this problem
Dec 19, 2006 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
315 people viewed this question
old marine
old marine
