Question about True GDM-69 Refrigerator
My GDM-68 cooler does not shut off even when thermostat is turned off. The unit freezes until fans hit ice. Can you help me?
  • 400 Answers
SOURCE: I have a true GDM-12FC floral cooler that the
You have not said if the cooler is cooling to the correct temperature or achieving the setpoint. Make sure that the correct thermostat has been supplied. Also that the sensor has been installed in the correct location. If all of the above is correct, then I would have the refrigerant level checked.
Posted on Mar 09, 2009
  • 88 Answers
SOURCE: Tru GDM-47 cooler evaporator icing up.
possible bad defrost timer,or control on an off is bad,were you adjust temperature...thermostat from 30 to 65.00 dollars....possible there is leak or unit is under or overcharged..more than likely under charged...possible defrost heater is not working...good luck..michael doctor airr appl.repair..service tech..843-384-8474...call if need additional help ..its free..
Posted on Mar 27, 2010
duane_wong
  • 6826 Answers
SOURCE: My true cooler gdm-45 is
The thermostat seems to be bad. Or, the defrost timer is staying on too long.
Posted on Jul 12, 2010
heatman101
  • 43501 Answers
SOURCE: I have a True refrigerator
You will need to find out why the unit is not shutting down properly....
It may be that the thermostat sensor will need to be placed in a different spot...or the temperature may just need to be raised higher...
Does the thermostat turn off the unit if the temperature is raised??? If so, then place a thermometer in the cooler and then adjust the thermostat to 38F by that thermometer and not by the t-stat calibration, it may be off even if it is new...
If the t-stat is not cycling the unit then you will need to use an electrical meter to trace out the power to the unit and find out why it is not shutting down...
heatman101
Posted on Mar 31, 2011
  • 5370 Answers
SOURCE: I have a GDM 49.
Its a defrost problem, the unit is not defrosting, due to this everything is getting frosted.The cooling cycle is running, so freezer freezes, but defrost cycle is not running so its all getting freezed and remains freezed.---------- -------------
First try manual defrost reset procedure. The procedure is as follows: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. -------------
If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. But in your case thermostat is all ready replaced, so either is defrost heater or board.But first see if manual defrost is solving the problem or not.If not then def heater or defrost board has to be checked.You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Posted on Aug 30, 2011
The GDM-41 true cooler is freezing my food what do you guys think I am thinking of replacing the thermostat
Simply turn the temperatue up a couple of points..If it is freezing stuff it is set too cold !
Dec 04, 2013 | True GDM-41 Refrigerator
Will not stop running
Are you referring to the compressor not shutting off down below or the evaporator fan inside the cooling area not shutting off? Evaporator fan always runs the compressor is controlled by the thermostat you could have a bad thermostat if the compressor never shuts off.
Mar 13, 2013 | True GDM-7 Beverage Cooler
Even I turn of the indoor unit via the controller , the outdoor unit is still running. I turn off the breaker and turn on still the the outdoor unit still running. What do you think the problem is?
Usually when this occurs it is a contactor burnt shut. If left to run, it will freeze the outdoor condensing unit into a block of ice. The contactor activates the compressor and
fan and the contactor is controlled by the low voltage from the thermostat. If the contact points are burnt shut the thermostat becomes of no use in controlling the outdoor condensing unit. The solution is to replace the contactor. Make sure all power to unit from all sources is shut off before attempting to replace. Hope this is helpful.
Jun 01, 2011 | Frigidaire Heating & Cooling
The water in our culligan water cooler keeps turning into ice and will not come out of the unit. How do we prevent it from freezing?
There is a thermostat that is to shut off the cooler. It has gone bad and will need to be replaced. Often the Culligan contract includes the cooler maintenance and repair...check with them, they should fix it for you.
heatman101
May 19, 2011 | Microwave Ovens
Mar 27, 2010 | True GDM-47-RL Refrigerator
HELP l need instructions for Homebase LF320 air cooler
I have the same unit, also given to me, and there really isn't much to it. Remember, it's an 'air cooler, not an air conditioning unit. Works fine as a floor standing fan on L, M and H settings (lo, med and high) but, if you want the air to cool slightly, freeze the blue ice packs and then put them in the base of the unit and top up with cold water until the level indicator on the front says full (red ball hits red arrow, like in a kettle). Then, turn on as normal and run the 'Cool' function along with your desired fan setting (L, M or H). I tend to add a few extra ice packs. The 'Cool' setting drags a fiber membrane into the water and over the intake surface, thus cooling the air slightly. Nothing like real air con but better than nothing on a day like today. 'Swing' throws the air around a little and 'Mode' gives you bursts of air, and that's about it to be honest...
Apr 07, 2009 | House Brand Dryers
Fan blower coleman electric cooler
The fan should blow air into the heat sink. The warm air exits the heat sink at both ends. (It might work the other way, haven't tried it.)
When you have ice in your cooler, you know the thermo-electric element is working well--it's below freezing!
Ice builds up because there is water in the cooler. For example, in humid weather, you open the cooler, some humid air gets in, and the cooler temperature condenses the water. You have to empty this water, either by tipping the cooler, or using a sponge.
You can easily defrost the cooler by unplugging it for an hour or so. You know it's time to defrost when you hear the fan blades making a racket because they're hitting something--a thick buildup of ice.
Aug 10, 2008 | Coleman Electric Cooler 40 Beverage Cooler
Need help
If you mean the breaker trips it probably is drawing locked rotor amps on compressor. Turn thermostat all the way to the left to turn it off. Restore power to unit. If fans inside stay on, that means the power on still on. Then turn thermostat to the rite to turn it back on. If the power fails again after turning thermostat back on the compressor is probably bad. :(
Jan 07, 2008 | True GDM-9 Beverage Cooler
Help?
turn thermostat all the way to the left to turn it off. restore power and see if it stays on and inside fan is running. Then turn thermostat to rite to turn on compressor. If the power trips when turning thermostat back on, the compressor may be bad. :(
Dec 27, 2007 | True GDM-41 Refrigerator
Friedrich air conditioning - inside unit ice build up
Hi, Reduced air flow, low on freon or being continuously run during cooler weather such as at night. Some people turn their thermostat on 60 thinking that it will help get it cooler faster. They freeze up at night and don't get a chance to thaw during the day. It needs set no lower than 75 or so. The evaporator may be dirty. Don't know a lot about your particular unit but if the outside unit has the compressor and refrigerant lines running to it, The large refrigerant line should sweat all the way to the compressor if its fully charged. Please rate me if I have helped. Good luck kstfas
Aug 28, 2007 | Friedrich M18CF Split System Air...
True GDM-69 Refrigerator Logo
62 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
