Question about Brother IntelliFAX 4100 Laser Fax
Machine error 71 - Brother IntelliFAX 4100 Laser Fax
  • 2,296 Answers
This error indicates that there is a scanner motor error. Try and remove the error by following these steps: Press MENU *,2,8,6,4. The machine beeps for approximately 1 second and will display "MAINTENANCE" on the screen, indicating that it is placed in the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry from the keys. Now you are inside the simulation, Press 01 to reset the error status. After that press 99 to exit the simulation.
- Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine exit from the maintenance mode, restoring it to the standby state.
- Pressing the Stop button after entering only one digit restores the machine to the initial stage of the maintenance mode.
If the error comes back call Brother support, here are the contact details:
7777 North Brother Blvd.
Bartlett, Tennessee 38133
Phone: 1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
Monday-Friday, 9:00am to 8:00pm Eastern Time
Posted on Feb 08, 2011
What is machine error 71 How to fix it?
Error 71 on a MFC-9600 means there is a problem with the motor inside the printer.
You can try unplugging and waiting a few minutes, then plugging back in again.
If it is still coming up with the error, if its still under warranty Brother will replace/repair it for you, otherwise you will have to pay Brother for the repair cost.
Mar 05, 2011 | Brother MFC 9600 All-In-One Laser Printer
What does an error 71 mean? (brother fax machine)
The error code 71 indicates a problem with the scanner motor for document feed. Could be timing problem, or motor problem. If tries to feed documents probably timing, no feed motor.
Feb 07, 2011 | Brother IntelliFAX 4100 Laser Fax
Brother 4100 appear machine error 71? why?
The error 71 indicates to "Unplug unit, and call Brother" after calling Brother they will refer you to an authorized dealer for repair which costs more than a brand new unit.
please rate !
Apr 11, 2010 | Brother IntelliFAX 4100 Laser Fax
Brother Fax 4100 ''error code 71'' Started smoking, then stopped
Error 71 normally indicates a laser fault, but the smoke may be an additional fault such as the fuser or the power supply. The cost of the machine repair could be more then it's worth 8(.
Aug 25, 2009 | Brother Office Equipment & Supplies
Cover open pls close cover error machine 71
DCP-1400 HAS ERROR MESSAGE "MACHINE ERROR 71" HOW DO I CORRECT THIS?
May 07, 2009 | Brother DCP 1400 All-In-One Laser Printer
Mfc9880 machine error 71
error 71 is a problem with the polygon motor which is in the laser unit. This error usually means that you would need the laser unit replaced.
I'd suggest calling out an engineer.
Dec 12, 2008 | Brother MFC 9880 All-In-One Laser Printer
Machine error 71
Error code 71 -- ( Polygon motor does not synchronize with the reference clock. ) What ever that means - hope that helps.
Mar 20, 2008 | Brother MFC 9700 All-In-One Laser Printer
Machine Error 17 Brother
I am assuming that you error listed above is actually a "Machine Error 71" not a 17 as their is no such 17 error. The error 71 is a problem with the Polygon Mirror (laser scanner). The scanner is going to require replacement. The part is available at Seattle Platen, Dale 1-800-221-2388.
Hope that helps you.
Feb 21, 2008 | Brother FAX-8360P Plain Paper Laser
Brother IntelliFAX 4100 Laser Fax Logo
512 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
