Question about Maytag Refrigerator Light Switch - C3680310
If light stays on will refridg over heat? - Maytag Refrigerator Light Switch - C3680310
    Genius:
  • 1,015 Answers
The answer to your question is no,your refridgerator will not over heat. If you don't want to replace door switch you should be able to remove bulbs to shut off lights. I would try working door switch several times to see if it's just not closing all the way. Hope this helps. Thanks
Posted on Nov 15, 2010
What could be wrong?
check the flame if it reaching the tube
Jul 10, 2014 | Dometic RM2652 Refrigerator
Cant adjust temperature
check to maker sure lights are going off when door is closed , if not it will get extreamly hot ibn refrigerator and cause lights to go off and stay off til cool,
Nov 29, 2013 | GE CustomStyle PSC23NSTSS Stainless Steel...
Ge refridge light heats up
When the door is opened for any long length of time, the light will get hot, remember it should switch off when you close the door, just peek through the seal without opening the door & see if you can see any light if so you will have to adjust the activating switch.
Nov 21, 2013 | Refrigerators
Refridge. light went out. Bulb is good. Indicator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
A/C will not blow cold. I tryed adding refridge
It will take it a while ,until the compressor starts staying engaged long enough to **** the freon in faster.
Jul 10, 2010 | 2003 Chevrolet Silverado 1500
The freezer works but the refridge doesnt
the freezer back wall need to be open and check the heat element
and the thermostat , also make sure the fan is working in the freezer.
if the frost on the coils are not even then it is sealsystem that is bad news,
but if it is just frozen defrost
it with hair dryer and check the elements i told you to check
Dec 31, 2009 | Refrigerators
Whirlpool side by side (106.56692501). Refrig was not cooling but freezer is. Freezer is slowly heating up though. Unit is still running. It just isn't blowing air into the refrigerator.
You have ice in freezer fins. You need to remove back panel inside of freezer, melt all the ice replace panel, plug refridge back in. The ice causes bad airflow to the refridge side, causing to heat up.
Jul 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator light stays on even when door is closed.
Turn off the Low Ambient Switch on the upper panel of the Refrigerator door. That will turn it off.
May 06, 2009 | Dometic NDR 1292 Refrigerator
LIGHT SWITCH ON MY REFRIDG. DOOR
Just pry gently with a flat blade screwdriver.
May 04, 2009 | Refrigerators
Smell coming from the refrigerator
I would assume you have a bad self defrosting motor. This motor generally is used to cycle heat at certain points to keep the unit from allowing the condansation from freezing inside the refridg. I am assuning the smell is this motor heating up. Should the motor quit, it is normally not a fire hazard but should be taken care of. You'll need to remove the back panel of the refridg and you'll see the minuture motor and probably hear is making noise. Always be sure to unplug the refridg before opening the back panel or any service to prevent shock. Good luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Samsung RS2630SH Side by Side Refrigerator
Maytag Refrigerator Light Switch - C3680310 Logo
119 people viewed this question
Top Maytag Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Maytag Electrical Supply Expert? Answer questions, earn points and help others
