Question about Canon CanoScan D660U Flatbed Scanner
Lines throughout Was working fine when scanning now have lines across the whole bed. Have uninstalled and reinstalled but still same problem. Hope you can help. Thanks Regina
  • 490 Answers
Clean the glas with IsoPropyl Alcohol. Remove stapler pins before scanning as it can damage/scratch glass.
S. Mohan, Chennai
Posted on Jun 23, 2008
Scanner grinds when powers on
Its not drivers issue, hard ware issue.. Scanner assm faulty,replace it..For tech guys:Open flat bed glass, remove scanner assm clean inside reflector glass with ear buds & adf glass especially at home position.. lubricate on rail refix it back.. check it..
Dec 22, 2011 | HP Photosmart C4580 All-in-One InkJet...
My HP C4480 scanner only returns a black image (on
Did you repaired old drivers? if so first uninstall your products drivers and also its folders from program files, then uninstall "wrong update" and reinstall scanner. sometimes built in scanning modules comes wrong but everything works with original scanning software, use different software to scan and some of them may work perfectlly.
Feb 20, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
When I scan 4x6 photos there is a line (sometimes green) across the entire photo that used to not be there. Scanning larger 8x11 photos the line does not show or when scanning documents. Help! I'm in...
If line is vertical.
Try scanning a bigger document. Use a blank page big as the scan capacity and scan the blank page.
If for example you are using an a3 scanner, scan a blank A3 page.
When scanning blank page set resolution to an high value, so that you does not lose pixels.
Check scan result, and explore the whole document using zoom to see if the line is still present on the test scan of the blank page.
If there is still the line, then it is either a scanner dirty, probably inside glass, or a dafective sensor on CCD sensor array.
If there is no line, then the problem is usually depending on the software.
In that case uninstall the software and install it again.
If that is not enough to fix the problem, try uninstalling software, doing a system restore to a date before the problem started , and then installing software again.
If the line is horizontal , that is usually a loss of power on the high voltage to lamp.
Try reinstalling software first, if that does not fix the problem , and line is horizontal, then it is fault mentioned above.
Horizontal lines at the end of a document may also be caused by faulty scanner control board, or scanner going out of memory.
Oct 10, 2009 | Fujitsu Office Equipment & Supplies
HP Laserjet M1522nf Multi page scanning problem
Check this thread in HP forums:
Second Page Scan is Garbled on HP1522nf
Download the file attached to LARS post halfway down the page and follow his instructions on how to unzip and install it.
Hope this helps.
Sep 11, 2009 | Office Equipment & Supplies
Lines across scan
It appears to be a freak problem. The best way is to bring it to original condition. Try uninstalling the scanner, run Scandisk on the Comp, Switch off and reinstall the driver. this may work.
S. Mohan
Feb 12, 2009 | Microtek ScanMaker 9800XL Flatbed Scanner
Mustek Scan Express A3 USB Scanner
I've had a similar problem with the streaks, lines and color bleeds appearing in the scan. Try uninstalling the all software and drivers for the scanner and reinstall. Worked for me. Have had to do this a couple of times since I've owned the scanner... about three to four years now.
Jan 25, 2009 | Mustek A3 USB Flatbed Scanner
Scan light
Yes the bub for it needs replacement. please consult a service technician that is accredited by epson, you can check one on your area by going to site and look for a servicer.
Hope this helps
Sep 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
FIne art scanning - uneven color across scans especially at edge of bed
The problem is going to be with the bulb itself. The scaner you are using is not made to do such precise work. The bulb itself is undersized for such a large scale job. You can look into upgrading the bulb of your scanner but I would not sudgest it unless you go to an authorized dealer/maint contractor for your Microtek to find the proper upgrade.
Apr 28, 2008 | Microtek ScanMaker 9800XL Flatbed Scanner
Canon CanoScan D660U Flatbed Scanner Logo
139 people viewed this question
old marine
old marine
