Question about Makita 9.6v Cordless Impact Driver 6903VD
I have a Makita modle # 60930 driver drill that stopped working. Battery OK. took apart and switch worked. Tried to put back but a couple parts fell out. Need to know where they go. Ome is a small black washer (nylon?) and the other is a sall piece of metal about 3/4inch x 1/8th with a hump in middle. Need schematics please. Thanks, Joe Martin
  • 34 Answers
When you have it open, check carbon brushes. This schema might help you (even if it's not the same model)
Posted on Nov 22, 2010
My brushless Makita drill driver just stopped. It wasn't hot and the battery is fine. I clicked a fully charged battery into it and nothing. But when I put that battery into another drill nothing.
If you are ABSOLUTELY certain that the batteries are good then the only other culprit has to be the switch that feeds power to brushless motor. Also check battery contacts for corrosion.
May 26, 2016 | Makita Drills
Stopped working
battery or electric and what make?
Nov 29, 2015 | Drills
Trigger Switch
I don't thinkk you got the motor aligned in the housing right. It sounds like it's in a bind causing the battery to over amp which shuts it down. The litium batteries have curcuits that detect overloads so you don't damage the battery. There are alignment guides in the housing and on the motor to help get it right.
Jan 05, 2013 | Makita Btd141 Lxt 18v Lithium Impact...
I have a new 7000 battery for my 6075D Makita drill. The drill won't turn at all. battery is charged. I wanted to take the drill casing apart. All the screws are out. the casing will not come apart near...
Makita engineers are sneaky bastards that's why. There's a special tool required to take the front off and another compression tool to compress all the parts back together. You got to find your local Makita service center and have them do it. They make these Makitas like Hondas, because they want to keep all the money and don't want you monkeying around and fixing the parts yourself for cheap.
I know, I know life's a b.tch sometimes.
Nov 11, 2010 | Makita Drills
Fell apart!!
the transmission comes in assy. all u can do is to match the gear & test every small installed. if it's dw997 see www.erplacementparts.com for your guide how to re-assemble.
if dw988 trans diagram see similarity on how to put it back.
Aug 16, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Battery charger just flashes to say the battery has to cool down but will not start charging.tried another charger same thing happens but does not show that the batteries are faulty!
Unfortunately, Makita’s li-ion battery packs have a design flaw. After having the same problem with my two batteries, I took it apart and saw the problem immediately. You see each battery pack has ten li-ion battery cells and a circuit board with a memory chip witch holds the charging history of the battery pack. But that memory chip constantly draws power from 2 of the 10 batteries. The current it draws is very small but if you consider it over 6 month or more, the power drain becomes very significant. You end up with a battery pack with 8 still fully charged battery cells and 2 drained battery cells. When you put this battery pack in the charger, it detects weak battery cells, assumes they are defective and refuses to charge. To avoid this problem you should charge your battery pack often, even if you haven't used it, every two months should be ok.
I suspect that Makita doesn’t make these battery packs, they make power tools, good ones too. But Makita should definitely have a few words with their supplier before they become a liability!
Jul 03, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita 9.6v Cordless  Impact Driver 6903VD Logo
256 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
