Question about Homelite ZR10926 16 Chain Saw
Chain oil tank full, feed channel behind guide plate clear, but no oil going to chain when running. This is a homelite 16.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 78 Answers
There should be a oil adjusting screw on the bottom of your saw next to the bar beside the oil tank. Some models actually has the screw inside the tank. Drain the tank to make sure there isn't any debris clogging the hole where the oil feeds to the bar.
One way to check to see if the bar is oiling is:
1. Start the saw
2. Put a board, piece of cardboard or an uncolored old shirt in front of the bar
3. Press the trigger on the saw to allow the chain to circulate around the bar.
4. While keeping constant pressure on the trigger, look to see if there is a vertical line of oil on the piece of material you have placed on front of the bar. If the saw is oiling you will have a vertical line. If not adjust the oil set screw accordingly.
Posted on Nov 15, 2010
Oil not coming out on the bar
Check chain oil reservoir, assuming it is full and pathways are clear, your oil pump might be toast , or not set up properly. Usually, there is an adjusting screw. Don't run it dry.
Mar 12, 2014 | Homelite Gas, 16 In. Bar, 38 CC, Chain...
Chain binds on bar when trying to cut and will not move. If it runs very long the clutch gets hot. Why is it binding?
Have you been putting oil in the lube tank? If you have, and have been making sure it's using it, then the chain has a bent guide, or the guide in the bar has been bent, or the chain is too tight. They're pretty simple machines. The possibilities are fairly limited.
Jul 06, 2011 | Homelite ZR10926 16" Chain Saw
Homelite 330 chain saw no lubrification to the chain
Allot of times this is caused by dirt plugging up the outlet. Pull the side cover that holds the bar on and clean using carb cleaner and compressed air. You should see a small metal tube or hole where the chain runs at the top, make sure it is clear. If you remove the cain and the bar you can start and rev the saw to make sure oil is weeping, it won't squirt out.
Mar 09, 2011 | Homelite ZR10926 16" Chain Saw
Oil leak when running.
Remove the bar and chain from the engine. Clean the entire area where the bar fits to the case. Start the engine--oil should ooze out of the side port only. If ok, clean the bar drive-end small oil-channels that bring oil to the chain groove on each side of the bar. Also, clean the entire chain groove. Refit the bar, chain, and cover leaving the fasteners finger tight. Turn the chain adjuster CW until the chain comes up to the bar, but not so tight that the chain can't be turned by hand. Tighten the cover fasteners and recheck the chain tension. Start the engine and run the bar tip at speed near some cardboard--it should throw off a thin line of oil after several moments. Hope this helps!
Jun 02, 2010 | Homelite ZR10926 16 Chain Saw
Do not know what mixture or how to use
40:1 mixture for the fuel:oil ratio.16:1 will cause your saw to barely run(if at all) and if it does, will fog out every mosquito for 4 blocks. You can use any reputable 2-stroke oil, though stay away from outboard engine oil. Get the good stuff that says Stihl, or Husquavarnah, or something like that. Even the Homelite stuff is ok. The oil tank takes regular bar and chain oil.
May 30, 2010 | Homelite ZR10926 16 Chain Saw
What is the oil to gas ratio for a homelite zr 10926 16 chain saw
This is a current Homelite product although not your saw. This clearly recommends 50:1 as do I. I find no OM for your saw, a "Ranger 33cc 16" Chain Saw UT-10926"
http://www.homelite.com/product_manual/file_url/66/UT10540_60_80_QSG.pdf
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1 and have for a number of years.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
I suggest you contact Homelite and request an OM for your saw.
Homelite/Ryobi.com (Contact Us)
https://register.homelite.com/contact_us/new
Please ask they prove a link to a site where ALL homelite product OMs may be accessed.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 06, 2010 | Homelite ZR10926 16 Chain Saw
Homelite d3300 chainaw has stopped lubbing itself
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Oct 23, 2009 | Standard Oregon Chainsaw Chain For...
My saw runs a few minutes then gets hot and wont start
What is the ratio of the oil/gas mix?
Sounds like it is not getting sufficient lubrication.
Add 1/2 oz (about 1/2 shot glass) of 2-cycle oil to the gas tank and try again......
Check to be sure that you have LOTS of chain oil in the chain oil tank!!
\Keep us informed, please! -Jim
Oct 22, 2009 | Homelite ZR10926 16 Chain Saw
Need service manual for Homelite 16'' electric chain saw model UT 41320. Motor runs but chain stopped in middle of second cut.
chain is too tight on the bar or is lacking lubrication oil. loosen up the bar nuts and back off the chain tensioning screw a touch. make sure the bar oil reservoir is full and the chain is receiving oil when its running.
Oct 20, 2009 | Homelite Garden
I have a McColloch 16 in chain saw MS 1635 AV.
remove side cover,bar & chain.above bar mounting studs find a oblong channel that lines up w/ the small holes in the bar.clean everything,sawdust gets packed in the holes.if it leaks oil out the bottom,you need to replace the oil feed line fom the tank.
Sep 21, 2009 | McCulloch Garden
Homelite ZR10926 16 Chain Saw Logo
612 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
