Question about NetGear WGR614 Wireless Router
I need to set a static ip address on my netgear
    President:
  • 1,082 Answers
Http://kb.netgear.com/app/answers/detail/a_id/2175 This link is to a PDF maual for your Router..
It has detailed instructions for everything to do with it.
Posted on Nov 15, 2010
How to enable wireless connection on dell latitude e4300
I have had this issue on DSL troubles.The most common issue is the settings for the IP address.A computer in a business location will often be set for a static IP.You can change it,but don't forget to write down the static IP settings(as soon as you click on the "bullet" for "obtain IP address automatically" ,the static info is GONE,and there's no way to retrieve it.Go to control panel/network connections,right click on the NIC or Wi-Fi connection being used,click properties,highlight Internet Protocol TCP/IP,click properties.This will show auto or static IP.
May 31, 2012 | NetGear WGR614 Wireless Router
During set up router is asking for static IP address. Why is this question asked?
It should ask you to enter at least one Static IP address. You have to enter the IP address given by your ISP. Without IP address, you'll not be able set up the router. You can assign the DHCP later for the machines which will be connected with the router..
Hope this helps.
Good luck.
Thanks for using FixYa.
Aug 25, 2010 | NetGear N150 / RANGEMAX 150 Router
How do I set D-link DIR-615 router to issue IP
You will need to visit the D-Link and check the virtual videos to help you set up the D-link for static addresses. this is what you will need to do.
May 30, 2010 | D-Link DIR-615 Wireless Router
My friends has a netgear wgr 614 v9, and it wont connect,, juts keeps saying acquiring network address, i tried to reset it ( lil hole at the rear ) but no joy,, how can i solve this,, would someone...
your computer is not getting IP address from the router. You said that you reset the router. Press the Reset button on the router and hold it down for 30 seconds. release it. Unplug the power to the router and plug it back in. restart your computer and check if that connects. If that doesn't work then assign a static IP address in the range of your router. you will need to find out the default IP address of the router. you will find the default IP address of the router in the router manual or if you go to the web site of the manufacturer, you will get the IP address of that router. Now once you assign a static IP address to the computer it will show you connected , now try to set up your router.
Click Here for more information about the router and network
Feb 16, 2010 | NetGear WGR614 Wireless Router
Netgear DGN 2000 won't connect to internet by cable / wifi works
Might I suggest looking at the routers configuration. This can be done by typing in 192.168.1.1 into your web browser. Typically the default log in is: User Admin, Password is password. You want DHCP set on. Save all your settings. Then reset to factory default. There should be a reset button on the router. This will reset it to when it was new- any changes you made will be gone.
Oct 11, 2009 | NetGear DGN2000-100NAS Router
I am given a set up error while trying to configure netgear WGR614. Below is the message The router is setup with the static IP values read from the computer. However, there is no Internet connection with...
You need to contact your Internet Service Provider to obtain the setup configuration for the cable or DSL modem. A LAN cable is then connected from the modem to the Internet LAN port on the wireless router.
Normally you do not set a static IP address on the router, and the wireless card should be set to obtain an IP address automatically.
If you still have problems, give me details of what configuration steps you have carried out on the router and the wireless card together with the error messages.
Sep 12, 2009 | NetGear WGR614 Wireless Router
THERE IS AN IP ADDRESS CONFLICT WITH ANITHER
Identify the peripheral conflicting with the router and change the network address on one of the two. Their setup programs should give you the possibility to do so. The address should look like: 192.168.2.x
x ranging from 0 to 9
Aug 02, 2009 | NetGear WGT624 Wireless Router
How do I set a new address in the 850 motorola router
First, you ned to login into your router (check the manuals for this, Netgear has this printed behind the router near Serial no. etc).
Enable DHCP settings, allocate IP-address range say 192.168.0.1 to 192.168.0.5 (enough for 5 computers connecting via this router). Next, configure each computer to accept new IP-address from router by enabling DHCP.
The settings on a Windows XP Professional Desktop:
Need administrator access to your desktop, right-click on Network icon, Internet Protocol TCP/IP Properties, click on Properties button, then select Advanced properties, you can set DHCP from here.
Dec 17, 2008 | Arris Wireless G Broadband Router (wr850g)
Wireless access point connecting to router...
The question is how do you want to cable the netgear and what do you want to do with it.
If you cable a lan port of the DLink to the Netgear WAN port you will have two subnets that must be addressed differently. Opening up and forwarding the ports for XBox could be difficult.
I believe cabling the Netgear as an access point makes more sense. CONFIGURE THE NETGEAR BEFORE CABLING. This is achieved by wiring a lan port on the DLINK to a lan port on the netgear and ignoring the wan port on the netgear. This will involve configuring several router items that should be completed before the devices are cabled together. You will need to remember the Netgear's new network address and probably use a static IP address from a computer to configure it back into being a router after these changes, if required. Or reset the configuration to factory default following the users guide.
First the Netgear needs DHCP turned off as it will be part of the DLink's network and not a separate subnet - the DLink will perform the DHCP services.
Second the LAN side of the Netgear will need a static IP address in the DLink's network. This is where it may get tricky for you. Verify the DLink has an IP Address like 192.168.0.1 and a subnet mask like 255.255.255.0. That means all IP Addresses in your network start 192.168.0.??? where ??? is unique for your network. Verify your DLink router has a set of addresses reserved in the DHCP setup for dynamic address assignment these addresses like 192.168.0.100 to 192.168.0.199. If the above is true or with the information you extract from you DLink router you need to determine where you can create static IP addresses -- in the above case 192.168.0.2 to 192.168.0.99 are available. You need to assign one of those like 192.168.0.2 to the LAN side of the NetGear Router. You will probably want to assign another to the XBox == like 192.168.0.20. You will probably need to deal with opening ports or placing the XBox into the DMZ of the DLINK router which will require a static IP Address.
Now cable the devices
When considering the XBox Configuration below the DLink is the router that must be configured to allow the open ports or DMZ access to the Xbox == the netgear is not functioning as a router in this configuration.
Check out the following links on XBox Configuration if required.
The second link may be the best to start with.
The generic connection and configuration document
http://www.microsoft.com/windowsxp/using/networking/setup/xbox.mspx
This is a good description of possible router2.gif options.
http://www.ianarchbold.com/xboxlive/index.html
If you need assistance setting this up in your environment leave a comment on this problem and I will respond.
Dec 27, 2007 | NetGear MR314 (MR314NA) Wireless Router
Static IP
Normally a router will assign an ip address in relation to it's own address and not a static address, eg if router address is 192.168.2.1 it will assign your pc as 192.168.2.2. So if you mean you want to change the router to your pc's addresses that you have set yourself, you need to manually alter the routers ip address and dns address to the same as ypur pc's eg if yours are 10.0.0.1 then the router can be 10.0.0.2 or anything as long as first 3 digits are same. If it's not answered then apologies as it's unusual to detect static addresses, normally they are unable and can't see your pc'c.
Nov 07, 2006 | NetGear WGR614/WG511 (wgr614nawg511nakit)...
NetGear WGR614 Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
