Question about Craftsman Garden
I have a craftsman lawn tractor model # 917.287242 I need to remove the gas tank
  • 37 Answers
SOURCE: can not remove axle cover,
Hi, easy fix you have to pry the cover off. you can use a screw driver, or a pry bar.
Posted on Nov 23, 2008
  • 246 Answers
SOURCE: owners manual for a craftsman model 917255812 lawn tractor
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Respectfully
John
Posted on Apr 21, 2009
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
How do you remove or clean trash out of gas tank on craftsman lawn tractor 917.20390?
remove the tank, empty old gas an trash. put fresh gas in an swirl around an empty again. should be clean then. reinstall gas tank.
Jul 26, 2017 | Craftsman Garden
My Craftsman lawn tractor will run for a while and then stop then sometimes after sitting for a while will run again. What should I check? I added fuel additive to gas just incase the fuel was bad.
Drain the fuel tank. Dispose of the gasoline responsibly.
Replace the fuel line between the tank and the carburetor.
Put fresh gas in the tank. See how long it runs.
While you're at it, change the oil and remove any debris from
the cooling fins on the engine. It may be overheating.
If it still doesn't run, you probably failed to replace the fuel line.
Trust me, this is part of good maintenance for these machines.
Sep 24, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to remove gas tank from craftman LT1000 lawn tractor it is located under the seat
Hello, removing this tank is easier then it may initially seem. Here are the basic steps:
tilt the seat forward
remove the springs that support the rear of the seat
remove the knob on the transmission shift lever
remove the fuel cap
loosen the bolts under the foot rests (that is all part of the fender assembly)
gently lift the fender assembly to expose the fuel tank(I have used an engine crane type lift to do this)
remove the bracket over the tank
remove the tank
reassemble in reverse order.
If this helps please vote yes, Thank You!
May 02, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 17.5 hp 22in Huskee Lawn tractor is stalling out after 5 to 10 min.
Check simple things first - as soon as engine dies, remove gas cap and attempt to restart. If successful, the vent is blocked, causing a vacuum to form in the tank. Effect will be more pronounced when tank is full.
Jun 23, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I drain gas from tank craftsman ys 4500?
disconnect fuel line from fuel filter, snake fuel line over to left side of engine. Remove gas cap and fuel will empty out of fuel tank.
May 15, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a Craftsman lawn tractor 17.0hp 42" it is about 6 years old. The problem is when I try to start it, it will turn over but it will back fire, I changed the spark plug but it did not help. What could...
since you didn't give any specifics, such as model number, engine make/model no., etc., we'll have to GUESS. if it does actually backfire, i mean a real kapow, either you have water in the gasoline or the flywheel key is sheared. check the gas tank, water is heavier than gas and you'll be able to see a sort of glob rolling around on the bottom of the tank. you'll need to drain the entire system, carburetor included, IF there's water. if not, the flywheel will need to be removed, not an easy job, best left to a pro. it COULD be an electrical problem, but rare.
Sep 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman- gas not flowwing to engine from tank under seat.
Yes there is a filter in tank but cant be removed,dump gas out of tank and leave gas cap off place a rag over tank to catch any gas that you couldnt remove doesnt blow all over then take your air hose and blow through the gas line this will clean the filter after you do this place a can under gas line to catch gas and put a little gas in the tank to see if your problem is solved .
May 09, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
107 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
