Question about Sony KV-35S42 35" TV
Sony trinitron - sounf problem
Everything with the picture seems to be ok but I can't get the sound to come out. I have tested the speakers but that doesn't seem to be the problem. What can be the problem and how can it be fixed?
    New Friend:
  • 76 Answers
First confirm the sound source is coming or not. This can be confirmed by connecting AV out from your TV to any other source input source like Amplifier or Hometheatre. If it comes there is problem in audio output section. Before proceeding the above method first check sound menu if any changes in sound system. Normally the sound is BG,I,DK. If there is any changes in these options sound will not come or getting distorted sound. I think above information is useful to you.
Posted on Jun 24, 2008
Panasonic crt tv model sx2 no sound but there is picture on the screen and channel are working
just simply check the speaker, if its working then you have to proceed to next level of troubleshooting, check audio ic in physical appearance,you can recognize audio ic by just tracing where the speaker being connected.Next is energize your tv and get a multi-tester set to 50VDC range and check if there's a supply of about 12V,if its ok then set the multi-tester to rx10 ohmmeter range touch the black prod and then the red test prod to every pin of the ic one by one if you heard a humming sounf at the speaker it indicates normal operation of the audio section.there's a problem with the signal.
Mar 05, 2015 | Panasonic Televison & Video
Sony 32" trinitron perfect picture, but no sound
Check its speaker first. It sounds that the speaker is out. If it is found OK, check for any loose solder terminals at the audio output section circuit, of damaged component/s there.
Sep 15, 2012 | Sony FD Trinitron WEGA KV-27FV300 27" TV
Sony Trinitron TV's is making a fuzzy noise from the TV's speakers but when played via my amp everything is fine....
Hello
The audio output IC of your TV is faulty. It should be replaced with same type and number. If there is some loose sodering on the solder terminals of this IC, this type of fault can occur too. So check this first, before replacing the IC. Ok
Nov 22, 2011 | Televison & Video
No sound from tV speakers
check your speaker, use a battery 1.5vdc tap it to speaker wire if the speaker is ok you can hear a click sound as the wire touches the battery + & - .
Sep 10, 2009 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Picture on my sony 29" cuts out after a few minutes
I once had this problem.I unplugged it for a few minutes then plugged it in it worked , but then i took it to repair it and everything was fine
May 18, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Can't hear voice/some audio
your audio setting is set to 5.1 and your do not have enough speakers to hear all the sounds. I suggest to change the setting to 2 speakers and you will be able to hear everything. good luck
Apr 03, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Trinitron Blinking Chanel 3
I have a 36 Trinitron, the sound and picture went but the red light just keeps blinking, any ideas? Please ....
Feb 26, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV-32HRS10
I need more info. Sound ok but no picture? Do you have displays? (Vol bar, chan #, etc).
Feb 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA kv32fs120 32" picture too big/vertical arch...
Sounds like you have a problem with the high voltage regulation or the power supply. This condition is called "blooming" Stargazer
Aug 18, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-35S42 35" TV Logo
69 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
