Question about Maytag Refrigerators
My bottom freezer is working, but upper frig is not. Model # MFD2560HEW Thanks
Maytag performa bottom freezer works but upper
First you should make sure your Evaperator fan is working. Open the freezer door and press the door switch in and see if you here the fan running.
If you dont here the fan you might have a fan motor problem.
Jan 07, 2010 | Refrigerators
Freezer on the bottom
Because there are many models like the model number listed above your post I will need you to confirm the model number on the refrigerator. The photo below shows were to look for the model number. Some like yours have a simple defrost system and some have circuit control boards. Everyone has these problems with every brand, Your model is Amana and also a Maytag brand. Let me know so I can help you get this going thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 28, 2009 | Amana ABB1927DE Bottom Freezer...
We left the frig door ajar for 6 hrs, now the frig isn't working but the freezer is... where is the reset button? Thanks!!
Hi, No reset button. Check and make sure the evaporator fan motor inside the freezer is running. While checking that, look and see if there is any frost build up on the rear panelin the freezer. Please let me know if any of these are the case so I can asist you further.
Thanks
Vic
May 23, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Refrigerator not cold
first check your damper door from the freezer to the refrigerator compartment make sure its in the proper position. Then turn off the refrigerator for a few hours until the heavy frost melts away. turn on the refrigerator check the refrigeration cycle, is it working properly, is it going into defrost are the defrost heaters working.
Feb 21, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer work and no cold on the top section
The defrost controller was changed and it resolved the problem. after a day power off to permit the ice to melt.
May 28, 2008 | Maytag MBB1954G Bottom Freezer...
Refrigerators Logo
138 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
