Question about Samsung SF-560 Plain Paper Laser Fax
When faxes I have sent are being returned back to me the body of the fax is being reduced in size
    Genius:
  • 1,218 Answers
When you send a fax (Assume a full page at 100% )...when it is printed at the other end there is now also a "header" printed showing the time, date, who sent it etc etc across the top of the page...now you also have to print your 100% information on the page therefore to do this and still keep it on a standard 11" page...the information is "typically" reduced to about 95% so that it will all fit on the page....if the other person then turns it around and sends it back to you the same thing happens so it now could be reduce by at least 10% or more.
Posted on Nov 15, 2010
Scanner
you should check the settings in your fax machine. it is possible it is set to send the fax with 90% of the original image size.
Apr 28, 2013 | Sharp FO 77 Roll paper Thermal Fax
How do I fax I have put the documents in the tray now what do I d
There's two way to fax, 1. you can lay the documents to be sent/faxed on the flatbed (scanning sheet bed) and fax it after selecting the Fax option from the menu and dial the receiver's number. 2. If in case your documents is larger than the flatbed, you can put it on the sheetfed tray, and follow the same procedures to send the fax, it'll automatically pull the document as it copies the files to the temporary memory. But in this case, you'll need to resize the document size, suppose if your scanner bed supports A4 and you are faxing Legal Size paper, reduce the size of the paper to fit on A4, (approx 10% will do). Good luck.
May 24, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do you fax a document that is 11 by 14 inches?
Most fax machines and printers will scan and fax an 11x14 document. Just check your owners manual to see if any settings need to be changed AND contact the person you are faxing to let them know to put 11x14 paper in their machine, or some of the print may be lost if the fax will be printed on two 8x11 sheets.
If you don't have your owners manual, post a question and include the manufacturer and model number of your fax machine or printer and one of us will look it up for you.
Feb 10, 2010 | Office Equipment & Supplies
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Size of received/sent fax
you must have the reduction mode on in the fax section. This allows incoming faxes that are larger than the size paper you have available to be printed. You may have you paper set in a direction or size paper that is not the same as the fax being sent.
Nov 17, 2008 | Panasonic Workio DP-1820E Copier
Faxes I send are reduced in size and have series of black line down right hand side.
If its reduced in size during transmit or copy then simply place a letter size document in the feeder and close the two sliders up to the sides of the paper. If you don't close the slider up to the paper it will go into auto reduction
Apr 27, 2007 | Canon LaserClass LC 8500 Plain Paper Fax
Samsung SF-560 Plain Paper Laser Fax Logo
97 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
