How do i find my password for my belkin to hook my epson printer up the one on the bottom of the unit isnt working
Belkin password
All most everyone uses a user name of Admin or admin and the password is admin or password.
Oct 10, 2017 | Computers & Internet
Printer won't go wireless
You should have received a CD with the installation software. This will guide you through the process of setting it up as a wireless printer. Make sure it is near to the wireless router when you set it up to ensure a good signal.
The wireless function only works via a wireless router, not directly from a PC with wireless capability.
Feb 20, 2011 | Epson Stylus CX4800 All-In-One InkJet...
It is a small Netgear from aol and I wish to change it over to a belkin . when i asked oal for help they gave me e serious of leters and numbers and told me to contac belkin and you would put these...
Belkin is compatible with aol, its just that the company dont support that router.. ie there support isnt trained in using it. They should provide you with the correct aol settings to use with the belkin. To put these in, connect your belkin
  • open internet explorer or alternative browser
  • type 192.168.2.1 in the webaddress bar and enter
  • this is the offline website for your belkin
  • click connection type on the left
  • leave the password box empty and click submit
  • On the connection type page you should be using pppoe
  • go next, your usernamer should be in the form
  • yourphoneno@dialbb.com and password
  • Aol will provide correct username and password if unsure of login details
  • VPI and VCI are 0 and 38 respectively
  • Mtu should be 1400
  • The rest of the default belkin settings are fine, click next and apply or finish at the bottom.
  • Your belkin router should now be connected to Aol
Any problems get back to me. Hope this helps.
Owen
Dec 29, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Cannot connect to wifi Epson printer
Are you trying to connect to the wireless network on the printer.
First check the wireless settings of the router?
Click Here to know more about router.
Oct 23, 2009 | Belkin (F5D7230-4) Router (587009)
Wireless capability?
You should be able to buy a USB Wireless hub which you then connect to your printer using a USB cable.
The hub will come with software and instructions that then allow your laptop/PC to connect and use the hub as if it was a wired unit.
Belkin do something like this so that's probably a good start.
Jan 03, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Epson C1100 Aculaser Duplex unit not recognised by Vista
I have had the problem, but it is easily fixed in Vista.
1. Click Control Panel
2 Click Printers
3 Right click your AL-C1100
4 Click Properties
5 Click Optional Settings label
6 Click - "Update printer info manually"
7 Click - "Duplex Print Unit "
8 Click Settings
9 Tick box in bottom left hand corner - "Duplex Print Unit"
10 Click OK .... exit
Sep 12, 2008 | Epson Aculaser C1100 Printer
Bluetooth dongle
Not really, what operating system are you using? on the printer itself set it to bluetooth settings and dont put n a code set but set it to discoverable, then when printing dont do a file print, instead right click on the file and then on your send to option if your computer is detecting the dongle one option will say stylus rx585- then it will print it. one thing that you can check is as belkin manufacturer if their bt dongle is compatible with epson, and FYI bluetooth printng is for photo printng only. doesnt look as good if you are going to print a document or text docs..
hope this helps, and if you have inquiries email me back
if it solved your issue pls rate as fixya, thanks!!!
May 03, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Printing using Parrallels and winxp
How do you have this unit connected via parallel - there is no parallel port
Apr 22, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
