Question about Sony Playstation 3 (PS3) Console
My son's PS3 is not working. The power button is stuck with the red light on, and the console wont turn on and off, it just beebs when you try to press it. I tried a dart with a small suction cup on it , but that didn't help. Any ideas? Mel
  • 4,102 Answers
This is a very common problem and its to do with the ps3 over heating,
try the following.
leave it off and unplugged for an hour
check all air vents are free from fluff and dust and vac if needed.
make sure the ps3 is not being used whilst its on carpet
make sure the ps3 is not sitting on top of another electrical item such as dvd or sky box as this will cause it to over heat a lot quicker.
make sure its not wedged in a confined space it needs to have plenty of room around it to ensure cool air flow.
unplug all the leads from the back of the ps3 and the telly then plug them all back in, doing this removes any static that may have built up, then switch it on.
if after doing the above it still dont work then this indicates that either the gpu or cpu chip has over heated, if you have any warranty left take it back you need to check on the ps3 web site to see how old your ps3 is as this fault is covered by ps3 warranty for a couple of years but you need to check this.
now as for getting it repaired, well its a bit hit and miss i repair them myself and if it was an xbox 360 then i would say the chance of it working again is pretty high but as its a ps3 then these can be a bit hit and miss if the ps3 has over heated a lot and fried the cpu or gpu chip or both then the cost of repair would not be worth doing as it would be cheaper to buy a second hand ps3 or even a reconditioned one.
its not the kind of repair you can do yourself as you need to know how to test the circuit board to find out if the chips have been damaged.
the only other option you have is selling it for spares, i buy the damaged ones for spare parts but you wont get much for it as it is, i mean you could pay for the repair and you may get charged even though it cant be fixed,
i always say to my customers that if i cant repair it i will only charge for the parts i used which is nothing but if i do fix it then i charge them the cost of the repair, usually if its beyond repair they let me buy it off them as i pay more than they would get from ebay as they sell on their for about 30 quid with the problem you have got.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
ps3 ylod and rrod
Posted on Nov 15, 2010
PS3 stuck on red light after it froze up. I unplugged it and replugged it and it's still stuck on the red light. It doesn't change or anything even after hitting the power button.
It would help, if you posted the model number of your system, as they do vary sightly. Is there a disk inside they system? This could be the main problem in witch there are several solutions to remove it. If not, than try inserting a disk, as the PS3 auto recognizes a disk being inserted and turns on the system. If the light is on, and it wont let you power it on, then generally it's the stuck disk problem. ^^ Hope this helps, and good luck.
PS3 Slim Manual Eject for Stuck Disc
Sep 23, 2015 | Sony Playstation 3 (PS3) Console
Ps3 slim 129 gb will mot eject mw2 it makes the beebing noise and the another weird noise that sounds like it is stuck and the doesnt work the games does eject from the main menu but it is still in the ps3
1. First shut down the system by flipping the power switch in the back off.
2. Hold down the eject disc button.
3. While still holding down the eject button, flip the power switch to turn back on your PS3.
4. When the green light comes on, wait a few seconds then tap the eject button a couple times. The fan will run on full power and the disc will eject.
Nov 23, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 (PS3) Console: i had a power cut whilst playing ps3 , now it wont...
First thing to try is a video reset.
While the PS3 if off (red light solid) hold down the power button until you hear the SECOND beep, quickly release.
Let me know if this works, otherwise we'll try step 2.
May 16, 2010 | Sony Playstation 3 (PS3) Console
I connected my sons ps3 to our new hd tv and now it wont connect to his tv as it only seems to be using the hdmi output which his tv does not support
Turn the PS3 off and make sure it is just showing a red light,
Then, with the PS3 connected to the TV with the regular (not HDMI) connections, press and hold the power button.
As soon as you see the screen flicker, release the power button.
That should do it!
Jan 27, 2010 | Sony Playstation 3 (PS3) Console
Mid game my console beeped and shutoff. Now it wont eject disk or turn on at all. Light goes Green, Yellow then flashes Red
your PS3 overheated, what you need to do is remove the power cable and hold the power button for 5 seconds to make sure that there is no power left, then plug it back in and press the eject button hold it down, it will power up and eject disk, if that fails, you need to RMA your ps3 to sony or you can try and return it to vendor with the game case or dvd case of the disk that is stuck they should replace both
Jan 03, 2010 | Sony Playstation 3 (PS3) Console
PS3 has blinking red power light and nothing else
switch it off from the back,, hold down the eject button, and turn it on from the back,, it should spit the cd out,,
The ps3 needs to be sent back to be fixed it is YLOD..<--not good
it will take at least 4-6 weeks before you get your Console back. And also, if your warranty is expired, you have to pay a big fat $150,- to get the job done!
or go to youtube and look for a PS3 Ylod fix,,
Nov 28, 2009 | Sony PlayStation® 3 (60 GB) Console
When I turn on my ps3 system on, there is no signal on my T.V.
With the system off, hold down the power button on your PS3 for 10 seconds. This should set everything back to factory defaults. If that doesn't work, try holding it down until you hear the beep that sounds when the system turns on. Keep it held until you hear 2 more beeps, and release it instantly. If it doesn't work after that, then its going to be a problem with either the power supply, meaning that its missing some off the voltages which powers on the system properly or the main board is bad, at that point you would have to call Sony Tech Support.
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont turn on using controller and power button...
try cycling the power on the back of the console
are the lights blinking on your controller when you press them?
Jul 11, 2009 | Sony Playstation 3 (PS3) Console
PS3 will not play HD games - Everything else plays fine
My sons playstation had this problem and having spoke to a SONY rep, this was the cure.
1. Ensure there are no discs in the drive.
2. turn off PS3.
3. Connect controller with USB cable.
4. On the console press and hold the power button until a third beep is herd then let go. The PS3 should be showing a red light (OFF)
5. Again, press and hold the power button. You should hear two single beebs and then two beebs together. On the two beeps together, let go of power button.
6. The green light should be on and six options should be on the screen. select the THIRD option.
7. Follow the on screen instructions.
This fixed the issue. Apparently the files can get a little corrupted and following the above corrects the issue.
I hope this helps
Feb 26, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
56 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
