Question about Canon CLC 1120 Color Copier
Getting an error message e005 0200 on my canon clc1120 copier how to fix please
Soulvisitor
  • 1113 Answers
SOURCE: canon 1140 E005 and 0100 error
Error E005 means the cleaning web has run out. Needs replacing and ressetting.
Posted on Oct 16, 2007
  • 121 Answers
SOURCE: Canon IR 1600 Error message E000
You'll need to replace the fuser unit. Not exactly the cheapest part of the machine...
Unless, that it, you were taking things apart and happened to unplug something accidentally. If you take the cover off where the paper comes out, look at the connectors directly inside there under the black piece of paper that you'll see. If one of those are pulled out, it could cause the problem.
Otherwise you need to replace the fuser unit.
Erice
Posted on Nov 23, 2007
  • 37 Answers
SOURCE: getting a eooo mesage
E000 error is due power surge or electrical fault within the copier. you can clear the error in service mode.
Posted on Oct 02, 2008
  • 990 Answers
SOURCE: how do i fix error message E019 on canon 2016 image runner
Dear sir; The error code you have, means;"waste toner full, replace drum unit" but let's try to reset,steps by steps;
1,press "additional function", "*" "2", "8" in that order.
2, sssw will display, press "OK"
3,enter 34 press ok, enter 0 press ok.
4, prs stop key.
machine should be working now, if still have problem let me know ,I'm always around, if everything is fine, please be generous give me a rating,thank you,
WISH YOU HAVE A MERRY CHRISTMAS !!!
Posted on Dec 23, 2008
Cogz
  • 1326 Answers
SOURCE: E005 0200
That is the problem with your copier, you neeed to reset the error code in service mode. And You need to replace both of the cleaning web, the upper and lower web. Good Luck
Posted on Jan 14, 2009
Can I run my canon CLC1120 color copier on an inverter?
Dear
The printer may used on inverter, The power rating of the inverter should be 150% more than the power rating of the printer having 200-300% over load capacity for 33-6 secs.
However ON LINE ups better.
Thanks.
Feb 25, 2015 | Canon Office Equipment & Supplies
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
My iR2016 displays "system error E007, would you please help me repairing it?-
it error code means fuser unite problem please change fuser unite then solve your problem
Nov 20, 2009 | Canon PC-940 Black and White Copier
CLC1120 errer code E020 0180
hi
please open frond door,move toner tank, below the cleaning blade section u can see two senzor rads with wire. remove it and clean OK
Oct 20, 2009 | Canon CLC 1120 Color Copier
Error message: E000004-0401
Probably the copier is iR C5185i
- E004 = Fixing unit protection circuit trouble
-  0401 = Check the connection of the connectors of the relay PCB, the IH power supply, the fixing thermoswitch, and replace the fixing unit (fixing
thermoswitch OFF), the relay PCB, and the IH power PCB (blowout of the
FU261).
In the service mode, clear the error by selecting COPIER > FUNCTION >
CLEAR > ERR.
You need a canon technician to resolve this problem.
Sep 25, 2009 | Canon Office Equipment & Supplies
Constant paper jam error message
How to fix my Pixma 3300, ink tank is full, please give me ways how to reset.
Apr 16, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
E000 error message on canon imagerunner 2000 copier
Hello.
E000 means :
"The main thermistor reading does not reach 40oC 14 sec after the fixing heater goes ON (fixing low temperature error)"
Jan 19, 2009 | Canon ImageRunner 1600 Copier
Canon CLC 1120 Color Copier Logo
173 people viewed this question
old marine
old marine
