Question about Toshiba Satellite L455DS5976 Notebook
When i plus up my laptop the power lights come on but it doesnt post or screen comes on.
  • Toshiba Master
  • 5,568 Answers
Check the hard drive activity light; if it is active at power on, look at the display from an angle to see if some ghosting of images is visible. If so, the back light for the display or its inverter may have failed.
If you have a friend you can borrow a monitor from or use briefly, connect it to the VGA (D-15 connector) to see if you have any video output. If you still see nothing, turn off the power and access the memory in the laptop. Remove and return any memory cards and try it again.
If you still have no boot, it will need technical help since this could indicate a failed motherboard or CPU.
Posted on Nov 15, 2010
We can't see LED light chip directly
Post the laptop manufacturer name, and model number.
The model number is on the Bottom of the laptop.
Post in a Comment.
Plus add additional info about what are you referring to?
Offhand, I would guess a reference to the LED backlighting on the laptop.
If this holds true, and you have no Backlight, the normal procedure is to replace the LCD screen.
With most laptops utilizing LED's as a Backlight, the LED backlighting is incorporated into the LCD screen assembly, and that's why when the LED backlighting goes bad, the LCD screen itself is replaced.
Post back in a Comment.
Regards,
joecoolvette
Jan 23, 2013 | Computers & Internet
Laptop broken screen... plugged in Dell monitor,still doesnt work
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 03, 2012 | Computers & Internet
I turn on my Laptop and the fan will spin and the Hard disk light will turn on as well as the power light (obviously) But the Hard drive doesnt spin up and the screen stays blank no lights no nothing i...
Remove all of the ram, turn the laptop on if it does not beep you have a bad motherboard. If it beeps replace the memory and remove the hard drive turn on the laptop and see if it posts. If it posts without the hard drive then the hard drive is bad. Otherwise it is probably still a bad motherboard.
Apr 24, 2011 | Computers & Internet
Dell 1525 lights flash when power button is pushed but no
Even if the hard drive is bad you should still see the normal bios post screens and then an error message saying "no boot device found" or something similar. If you have a monitor in your home you should attach the vga cable from it onto the vga connection on that laptop. Then turn on the laptop and see if you get a picture on that monitor. If you do then either the laptop lcd inverter is bad or the lcd itself is bad. If you don't get a picture you may have to press a toggle button or buttons on the laptop to switch to the external lcd. Usually this is Fn plus another F button on the top.
Feb 07, 2010 | Dell Inspiron 1525 Notebook
Acer3100 laptop comes on but no screen
Fan needs to be clean plus your CPU clocking must be check by expert. Power supply is good? did you take a look at it? Under the laptop required Power shows, if your AMP loose or less your laptop will
faintdown. Your battery migth also **** all the power so laptop performans gets down. Your lcd inverter also could be faulty. Bad caps also issue for this, You need OHM meter to test some power issues.
Goodluck or show to expert
JMC
Aug 12, 2009 | Acer Aspire 3100-1405 Notebook
Booting problem
Is the cell still in there ? if the battery is bad, the PS will not provide the charge, plus running the computer .try your pc without the cell pack. Only the power supply connected
Hope this help. keep me posted if not
Jun 06, 2009 | Gateway Solo 9500 Notebook
Nec laptop, i turn it on and the screen doesnt turn on
Dear Sir,
Go to http://xviruslab.blogspot.com, and download Quick Heal Total Security (PC Mobile Scan and Data Theft Protection, Anti Phishing) or Quick Heal Anti Virus Plus, mail me if you're facing any problem.
Thank you
Bye bye
Mar 12, 2009 | Compaq Keyboard
A215 S5818 doesnt boot at all...
Hi there.
Remove the battery and try it on AC power only.
Post back with the results please.
Good luck and thanks for using Fixya!!!
Feb 19, 2009 | Toshiba Satellite A215-S5818 Notebook
Toshiba Satellite L455DS5976 Notebook Logo
61 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
