Question about JVC Televison & Video
I have a 46" widescreen,
  • JVC Master
  • 5,568 Answers
The pop may have been caused by a catastrophically failed power semiconductor or an electrolytic capacitor.
The main supply is often on a separate board (these are often outsourced) which will be smaller in size but have larger components on it. Removing the back panel should let you recognize it fairly easily. Examine this board carefully with a good light and look for components that appear damaged; this could be a three-lead transistor, a module (both often in black epoxy) or a capacitor any of which will be cylindrical and could be any size ranging upward to 2" in height and ~ 1 1/2" diameter. If the latter has failed, it may have a burst aluminum top or have spit chemicals onto the board.
Since you have neither sound nor video, I don't think the back light inverter for the display will be a fault. This will be on an even smaller board and traceable to the fluorescent tube. If you do not find a problem you can identify on the main power supply, check this smaller board for the same kind of visible failure since a failure on the inverter could cause a fuse in the main supply to fail which would disable the entire set.
Good luck-
Posted on Nov 15, 2010
I have a Vizio p50hdm while watching heard a pop noise and tv went out cant turn back on.I replaced main board and power board and still doesn't come on any Ideas?
The power amplifier chip (which goes "pop" when it goes bad) may be located on the board where the IR sensor is. Sometimes (but not always) you can make the TV come on by holding the power button in _until_ the TV comes on. But that usually only works when the chip is "going" bad. If you heard the pop, it's probably shot. Also, check for a fuse on _any_ of the boards, and possibly a main fuse at the back of the TV.
Mar 09, 2016 | Vizio 50" p50hdm high definition...
No picture or sound on some channels
we cannot get a picture or sound on several channels. Otherwise the TV works fine. Any solutions? as you get p&s on several channels so your ser is ok the problem 1 loose contact near tuner or it is defective. 2 tuner signal line .
Sep 16, 2007 | Toshiba 20AF44 20" TV
While watching tv we heard a pop and the receiver stopped working. Power button does nothing. We've opened it up but can't see anything that looks burnt or fried...
It could be a relay that burnt out, they usually dont show any signs of damage, or the motherboard could be fried too with no signs of damage eather! Hope this helps!
Nov 29, 2013 | Yamaha RX-SL100 Receiver
Hitachi clu-4591av stopped working - popping sound
The power supply regulator section should be troubleshooted. The "Pop" sound you heard might be of a bursted electrolytic capacitor in the AC mains rectifier section inside the TV. All the related commponets, rectifier diodes, protection zener diodes etc:- should be checked before switch ON the TV further.
May 15, 2012 | Televison & Video
We heard a "pop" noise
The pop noise could be a capacitor poping its top up.This is a common problem to most TV sets today. Usually located at the power supply board.Once this parts give up it usually shorts the circuit and blows a fuse.Replacements of these parts mentioned will often remedy the problem.Flashing power indicators indicate a problem.If you have the chance of counting how many the blinks are I could have told you the problems code are and the source of the problem.
Dec 05, 2010 | Akai PT46DL10 46" HDTV-Ready Television
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
Microwave made loud popping noise
The magnetron is bad. Probably cost about $50 or $60 for the part. Not too easy to replace, but it can be done.
Dec 13, 2007 | Whirlpool MH7130XE Microwave Oven
No picture
Bad IHVT ( flyback transformer)--need complete service
number off back for part #-----------Let me know...T.
Oct 15, 2007 | GE 46GW947 46" Rear Projection Television
RCA has no sound
well u have a problem in the audio circuits of the tv which includes the speaker itself. but most of the time the audio power output transistor or ic get easily damaged resulting a no sound tv. if u dont have any idea with regards to this, i suggest have it check with a qualified service technician. it will not cost u a lot for sure.
Jan 17, 2007 | RCA F36665 36" TV
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
