Question about Polk Audio DSW MicroPRO 1000 Subwoofer Speaker
My dsw micropro 1000 wont produce any sound.all the lights are on so its getting power.i have it on auto so when it senses a signal it comes on automatically.the LFE cable is plugged in correctly to the unit and a/v receiver.a/v shows in the window that the LFE signal is going out.i have turned a/c switch off & unplugged power cord for 2 mins. and turned back on but nothing happened.after a while the sub will shut down and go back to auto mode.i have also switched it to power full time but still will not work.any answers?
2 Suggested Answers
  • 362 Answers
SOURCE: Got a brand new dsw
if there is multiple jacks on the sub be sure they are hooked up correctly simple mistake if not no doubtly a simple overlooked setting on your amp good luck you will get it
Posted on Nov 20, 2010
What could be the issue with my sub woofer power?
Many of these SUB amps ended up with Capacitor failures in the Power supply section . Find someone who works on amps or TVs to have a look see.
May 26, 2014 | Polk Audio Polk DSW PRO 550WI Subwoofer
Micropro 2000 has power but has no sound even for test tones. No test tones. What is it?
This could be either a source or a sub problem.
The missing piece to this puzzle is the source identity and setup. Is IT set up correctly for a subwoofer?
If you want to test the sub by itself just temporarily feed one of your FRONT speaker outputs directly to its Speaker IN connectors.
... Or ANY device or source you have can be directly connected to its RCA Line In. BE WARNED - IF IT WORKS IT WILL BE LOUD
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Polk-Audio-DSW-microPRO-2000-Subwoofers-manual/id/23015dj593/t/2/
The unnamed elctronic source will have a manual, too. Use it to troubleshoot.
Jul 08, 2011 | Polk Audio DSW MicroPRO 2000 Subwoofer...
I unplugged my rca cables from micropro 4000 and it made a loud boom. Now it no longer puts out any bass. I pushed on the sub and it feels good. The sub powers on just no bass.
Open the case and check the resistance value of the actual speaker - should be around 8 ohms. If it doesn't get a reading, then it's bad.
Jan 01, 2011 | Polk Audio DSW MicroPRO 4000 Subwoofer...
When i flip the turn signal up or down i get a buzzing noise, also when on the turn light is dim. What might it be?
Great question! First the turn signal. That almost sounds like a relay or your switch may be going bad. The relay can be tested by useing a simple test light found a any auto part store. Now for the head lights. Sorry to tell you but it sounds to me like your alternater may not be produceing the power that your truck needs. Have the alternator tested. It may need to be replaced.
Sep 22, 2010 | 1996 Ford Explorer
DSW PRO 600 not getting signal from receiver. Why?
You don't name the electronics, which can be the source of the problem. See #3.
1. If you suspect the cable why don't you just swap in another RCA cable? BTW: there's no such thing as a "subwoofer" cable. Monster makes their money on those beliefs. Cables don't wear out but they can go bad if one or more conductors fails. Oxides devolp at either end which can inhibit conductivity. Remove each end and reinsert it with a twisting motion.
2. Maybe. You need to ensure the sub is defined. Run speaker level check. If no sound at the sub, prove the LFE/sub channel has output by running the RCA cable to a recorder or your TV (low volume). If there's no signal, duh, no speaker will work with it.
3. Mmm, not if it's exhibiting the same problem as the old one and the Polk 450. Have you looked at the setting of the Standby/Auto/On Switch? And the Power Mode LED's? Red is bad.
Mar 31, 2010 | Polk Audio DSW PRO 600 Subwoofer Speaker
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
Generator runs great but doesn't produce any power
There is a electronic module that senses load current that pulls the throttle up for high RPM. Fine the module and look it over, you may need to replace it.
Jun 23, 2009 | Coleman Powermate Premium Plus 6250W...
Turn signal wont turn off by itself
There is NO auto signal cancel device on the Valkyrie. You must set up an auto system in your own head connected to your left thumb.
Jun 22, 2009 | 1997 Honda F6 C Valkyrie
Polk Audio DSW MicroPRO 1000 Subwoofer Speaker Logo
54 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
