Question about Maytag Washing Machines
Maytag f-o1 code , says change ccu board, I did but still the same , is there a clear code I do if so how Maytag epic z
  • 246 Answers
Unplug the unit for 2 1/2 minutes. Does the problem return? Open the top, check all of your connections going to your CCU. Are any loose? Also try following the black hose on the top, right hand side towards the rear. It goes to your pressure switch (round cylinder 2 1/2 - 3" wide). Give it a firm tap with something insulated (the handle of your screw driver for instance). If the switch gets stuck it can cause a false f01 eror code.
Posted on Jun 19, 2008
Pump panel board
I have a may tag epic that was flashing
Apr 14, 2012 | Maytag EPIC MFW9700S Front Load Washer
I push the power button and when I hit start it just shuts off. The only cycle that works is spin on my maytag epic z
Any luck? the certified Maytag repair company looked at mine and quoted $445. for the repair. it is 15 months old so of course the warranty is obsolete. The solution is a new CCU panel and Temperature sensor. Good luck.
Aug 30, 2011 | Maytag EPIC MFW9700S Front Load Washer
Flases f 21 code worked fine untill i put new front board in and i cleaned out lines and hose still giving f 21
I looked at your tech sheet. As you already know the F-21 on your machine has to do with touchpad not communicating with control. F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
If you have a new touchpad installed and the harness is fine then the control must be bad.
Apr 01, 2011 | Maytag EPIC MFW9600S
Codes F-21 And F-33 are showing up
this error occurs if the touch-pad/led assembly is not able to transmit/receive data to/from the central control unit (CCU) 1 check the touch -pad/led assembly by selecting different cycles and changing the modifiers and options available to confrim the touch-pad/led is responding. 2 unplug washer or disconnect power. 3 check wire harness connections to the touch-pad/led assembly and central control unit (CCU) now to the f-33 code system leak if after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. OR if the control has turned the water valves on and after 8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. press PAUSE/CANCEL twice to clear the display. possible causes/procedure 1 check for crack or holes in the washer tub and pressure switch hose. 2 replace components if necessary good luck
Feb 16, 2010 | Maytag EPICz 3.7 cu. ft. Washer
F 21 error code? Maytag epic z washer
The F21 code on the Maytag EPIC is indicative of a pump problem. The pump impellers should be checked, there should be four of them. Sometimes the impeller blades can be broken by coins, or other items. Make sure that the pump is clear of debris, then remove the discharge hose, and blow through it.
If after clearing the initial slug of water, the hose doesn't blow free and clear, you have something stuck in there.
Nov 28, 2009 | Maytag EPICz Electric Dryer
Please help me,,,, my maytag epic z front load washer
I think you've actually got an uprated control board.
Modern designs allow for less water usage - most in as you say about 3"
Water level is determined in 2 ways #1 pressure - A pressure switch is used with an inverted container low down in the water. As level rises, pressure builds untill the switch opens and the water shuts off.
#2 Time - The valve is only allowed to open for a preset time (to prevent flooding)
If the first board was faulty, the pressure switch probably was being ignored, so was overfilling.
Older models also used more water per wash.
Shutting off after 10 minutes on a quick wash? - if it performs a full cycle in this time, it's working normally. As I said - just updated.
Let me know if there are any defects or faults , otherwise, it seems to be "modernised" by using the new board.
Jul 04, 2008 | Maytag EPIC MFW9700S Front Load Washer
Can someone help me please,,,,, my maytag epic z front load washer..
I had gasoline spill on my purse and I put it in my front loader washer and now I have the worst smell of gas and it is awful and now I can't use my washer! Can anyone tell me how to get the smell out of my washer?
Jul 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Front load epic z - code f-01
Once you change the CCU, that is where the fault codes are stored. They will go away. To change the CCU, remove the screws on the top of the washer (usually #20 torx or 1/4 screws) Push the lid slightly back and lift off. Depending on the model of Epic z you have the CCU will be on the top, center towards the rear or on the top, right hand side towards the front. It will be the plastic box where all of the wires are going. However, before changng the CCU, unplug the unit for 2 1/2 minutes. Does the problem return? While you have the top open, check all of your connections going to your CCU. Are any loose? Also try following the black hose on the top, right hand side towards the rear. It goes to your pressure switch (round cylinder 2 1/2 - 3" wide). Give it a firm tap with something insulated (the handle of your screw driver for instance). If the switch gets stuck it can cause a false f01 eror code.
Jun 19, 2008 | Washing Machines
Maytag Epic Z error code
I need a clear code for maytag epic z front load washer
code f-o1 is coming up
says intall new ccu, I did but still the same
do I need to clear the code if so how.
please tell me.
Jun 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
200 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
