Question about Clevo 2850 Notebook
I have clevo m7x0s laptop.i have a lot of installer but i dont even know how to start formatting my loptop.i already tried it to boot from dvd-rom and usb flash drive....pls help me...thank you! jmlatumbo@yahoo.com
3 Suggested Answers
LaSander
  • 14 Answers
SOURCE: my clevo m120w usb port not working but hardware
Wich os? If you have Win 98 or older Then the usb drive Doesent work;)
Try the download site for your laptop
Posted on Dec 31, 2009
stranger_ab
  • 133 Answers
SOURCE: clevo m7x0s video driver for
Below is the link for you to download the driver for your device.
Link to download driver.
Please feel free to contact me in case of any query. I am followin up.
Regards.
Posted on Dec 13, 2010
How do we reformat the drive
First you need a dvd-rom Then when starting the computer press F1 or F2 or esc to get into the bios. Set the boot order to boot from the dvd-rom first then the hard-drive. Put a windows install dvd in the dvd-rom. restart the computer. Press any key once the windows install comes up choose the partition or hard drive to format. You won't be able to format from windows directly unless it is a second partition. In the old days you could format using dos. You may be able to use a utility like Hiren's Boot CD to format
Nov 26, 2013 | Acer Aspire 4520-5582 Notebook
Asus eee pc 1015x
Hello
The answer is YES. You can load Win-7 from an external DVD player, after making it as first boot device. You must have get DVD as first boot devce and the internal hard disc to second boot device. Click out all boot devices to none, by entering into the bios window. You can get the bios settings, by press and hold the "Delete" key of your computer, as it first try to load. OK.
Jan 28, 2012 | ASUS Eee PC 1015PXPU17RD Netbook
I WANT TO FORMAT MY LOPTOP TOSHIBA NB100 MODEL NO.PLL10E-00K01TAR
First restart your Toshiba laptop. Press either "F1," "0," or "F8" to be taken to your computer's hard drive utility screen. The key command differs depending on the model Toshiba computer that you own.
Select "Restore Original Factory Image" from the list of options in System Recovery. Verify that you want to continue the process by clicking "Yes," then click "Next".
Restart the Toshiba laptop once the factory restore process has been completed. You will be prompted to enter information such as the date, time and language preferences.
Feel free to get the reliable technical help at http://www.vtechsquad.com/toshiba-support/ for troubleshoot all kind of Toshiba PCs(laptop/desktop).
Oct 29, 2011 | Toshiba Computers & Internet
Clevo m7x0s video driver for windows 7
Regards.
Dec 13, 2010 | Computers & Internet
Hi I'm Tony from the Philippines and I have a Compaq presario f756nr notebook pc (to be exact), i want to reformat my laptop and the problem i am facing now is that when i try to use my cd/dvd rom drive to...
Hi Tony,
Thanks for the details you have mentioned. The steps you have taken are correct and if the System/ hardware is ok, it should boot from CD Drive. Whenever i have faced such an issue, i always started afresh to check each hardware (CD, DVD, ROM, Hard Disk, Cables, Connections etc) and most of the times the issue was optical drive or CD/DVDs.
So, I recommend that make sure that the CD/DVD ROM is functioning properly. When the system is set to boot from CD/DVD, it must try to read CD/DVD after power on. It is indicated by spinning of the optical drive and blinking CD ROM LED. If there is a bootable CD in the drive, it should boot. You may try to boot the system through DOS bootable CD. Also, if you still have the OS on your system, you may check the CD ROM through windows.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 09, 2010 | HP Compaq Presario F756NR Notebook
I want to reformat my neo notebook model M54SE. What is the command and what are the things i need. Thanks.
ok all you have to do is to prepair your tools.Its better to clean first the entire loptop if you know to disassemble it.But if you want to install the operating system Winxp, win vista, or win7 stARTER all you need is to buy this OS. Then if you have now the OS put it in the DVD rom and go to the bios by hitting the del key once you there select the boot menu then set the first boot dvd rom then press the f10 key then yes to save your BIOS setting. then press any key to boot strap your start up. once your screen is blue in color wait until the loading of drivers will done.Then select the option to hit enter key to continue then follow screen instruction for partition setup of your laptop hdd. It must be 2 partitions the OS must installed or setup in 1st partition then follow the screen for formatting hdd then go on until it must finish the installation setup of your OS.Good Luck
Jun 30, 2010 | Computers & Internet
How to format windows vista os
The easy way is to do this via the vista os CD or an old xp one.
You will need to reboot your PC as it starts up look out for 'boot options' and select boot from your cd drive. If you do not get this option then please reboot again then go into boot options and select your CD rom or DVD rom to be your boot device.
For both options after making the change and your have your CD i, you will be given to option to press any key.
make sure you select to reinstall windows, at this point you will be be given the option to format your hard drive.
If you need more info or the PC is a laptop with out a CD Rom / DVD rom let me know and I will go over other ways to format your hard drive.
Mar 15, 2010 | Dell XPS 410 PC Desktop
How to format laptop
First insert windows disk into cd/dvd rom.
Then when you power up the computer press F1 or F2 or del key to enter in bios.
Then go to boot menu and set first boot device as cd/dvd rom then save settings and exit.
Then it boot with that disk then follow the procedure on screen then select 1 partition and press enter when it ask for install new windows.
Then format it with fat32 or NTFS quick then it formats that partition and install windows it take 39 minutes approx.
Then after completion of windows installation open my computer and right click on other partition and format it .
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 13, 2010 | Acer Aspire 5500 5570-2609 Laptop
BLUE SCREEN WHEN BOOT UP
If you can, go back to a good running install from the system restore. Updates (especially from microsoft) don't always work.
Aug 26, 2009 | Acer Aspire 3690-2196 Notebook
Can't install XP on Toshiba Satellite 2410-S185
you are on win 98? wow..that USB support is thin to minimal on that o/s
you may need to upgrade to another windows version for that..sounds like your computer has a few kinks and issues
Mar 19, 2008 | Computers & Internet
Clevo 2850 Notebook Logo
119 people viewed this question
Top Clevo Computers & Internet Experts
David Payne
David Payne
Are you a Clevo Computer and Internet Expert? Answer questions, earn points and help others
