Question about Philips GOGEAR SA6045 MP3 Player
My neice lost the charger that connects the unit to the computer via usb port. Where do I go to get one?
You can buy one from Best Buy or Walmart. Just make sure that the ports match.
Posted on Nov 15, 2010
My outlet in the car is not on when my car is turned off. Can you charge this unit through your usb port on the computer?
Yes..you can charge your unit via computer port....and in some cases with your cell phone charger.
Sep 11, 2011 | Garmin Nuvi 1300 GPS Receiver
Is it possible to obtain a charger for a Vivitar vivicam 8025
One way to charge the battery is via the USB connection. Connect the camera to a powered USB port (not all computer USB ports put out enough current for the job, however). Another is to use a USB charger, as available for many cell phones. You should be able to find such a charger at just about any department, electronics, or office-supply store.
May 16, 2011 | Cameras
I lost my charger for my Sanyo x1250 digital camera. Cant i use my USB cable as an alternative charger?
Did the mains charger connect to the camera's USB port? If so, it will probably charge from any USB port including your computer. Otherwise, no.
I found a charger (and batteries) for this camera on Amazon by searching for "Sanyo x1250 charger".
Nov 30, 2010 | Cameras
Can I charge my Magellan roadmate with USB cable connected to the computer?
It depends on the Roadmate that you have. :
- If your Roadmate has a separate plug-in port for charging your unit IN ADDITION TO a USB port, then no, your Roadmate cannot be charged using your computer via the USB cable.
- If your Roadmate only has a USB port available for charging your unit, then yes, you can charge it via your computer via USB.
However, please note, according to Magellan, charging your unit using your PC via USB can take up to 12 hours to charge vs. 4-6 hours when using the vehicle power adapter.
FYI: This is mainly due to USB constraints on pretty much all electronic devices. USB cannot carry the same amount of power to a device. It uses what is commonly known as a 'trickle' charge to recharge a device. It carries much less current than a full-blown charger (like an AC power adapter).
Apr 18, 2010 | Magellan RoadMate 1340 GPS Receiver
My Nuvi 200 will not charge and the USB port
My condolences. I would suggest you plug the unit in to your computer's USB port using an appropriate data cable (in case you no longer have the Garmin data cable, there are lots of devices, including cameras, that use such a cable with the large USB plug at one end and the mini-USB at the other). That would give you a handle on where the fault lies -- in the auto charger cable itself vs the nuvi's socket. If the nuvi charges from your computer, you're halfway home; if not, I suspect the cost of repairing the nuvi's USB jack could exceed the cost of a replacement unit.
Mar 16, 2010 | Garmin nuvi 200W GPS Receiver
When connects to power in the car, it thinks it is connecting to the computer.
if your charger not original garmin you should make this modification on mini usb port. tested works with non original chargers (min 500mA).
Nov 14, 2009 | Garmin nuvi 260W GPS Receiver
I turn it on, logo comes on, and it turns off. I've tried holding the on button 8 sec, no luck.
With the limited information provided, a simple first step is to make sure the internal battery is either fully charged or is in a condition to accept a charge. When the internal battery's charge is allowed to below a certain level, it will no longer be capable of accepting a charge via the car charger.
The battery can be conditioned to accept a charge easily, however. This is done by connecting the GPS to the computer via USB port, NOT the car charger. Some Garmin GPS units come with a 120 volt charger that connects to the USB port of the GPS - this method is also an acceptable charge / condition method. Leave the GPS connected for 8 hours or longer (over night) and try to power up again.
I hope this helps!
Oct 24, 2009 | Garmin nuvi 205W GPS Receiver
Can not find or activate comport 1 on windows Vista
Com port referes to a serial port. It looks like a monitor port only smaller. Since yuo connect via USB, it may be that the locator software is set to use Serial port or Comm Prot. See if it can be changed to USB. Perhaps load the software before or after plugin in the unit, that may make a differernce.
Apr 07, 2009 | Microsoft Windows Vista Home Basic for PC
Garmin nuvi 260w not operating while plugged in
Based on your description, you are doing it right. You said....
"when i connect it to the car charger it shows the computer sysmbol and starts charging. there is no other usb port on the device"
That is correct. It takes about 2-3 hours to fully charge a low battery.
There is only a mini USB port on a 260.
It's used for charging and downloading updates of software or maps.
Sep 02, 2008 | Garmin nuvi 200W GPS Receiver
Philips GOGEAR SA6045 MP3 Player Logo
108 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
