Question about EnGenius Technologies ECB3500 802.11g High Power 600mw Access Point/client Bridge/repeater/router/wd
Not able to access the ecb3500 software at all
How do I setup port forwarding (UPnP) on and EnGenius ECB-3500?
https://www.radiolabs.com/downloads/manuals/Product%20Manuals/RL3022AP-User-Manual.pdf. Also this>>https://www.youtube.com/watch?v=c-YomYxZMoU
Mar 06, 2014 | EnGenius ECB3500 - wireless access point...
Which program and settings should I use on my En Genius ECB3500 for rental homes?
For your current router you want to set the following options to optimize your wireless network and make sure it runs stable:
Security mode: WPA2 with AES
Channel mode: manual
Wifi Channel: 11
In order to extend the range of your wifi network you will want to get an access point, or a second router and configure that one as an access point.
Dec 06, 2013 | EnGenius Technologies ECB3500 802.11g High...
Password admin is not working
there maybe a reset button on the back of the AP. If so power up the AP and press this reset button for a few seconds then release the button and it should be reset to the factory defaults.
Sep 28, 2012 | EnGenius ECB3500 - wireless access point...
Need an html editor that will run on windows7
Hi efm3,
Here is a site with some popular HTML editors for windows.
http://webdesign.about.com/od/windowshtmleditors/tp/free-windows-editors.htm
Hope this helps!
Please Rate;)
Gary
May 26, 2011 | EnGenius Technologies ECB3500 802.11g High...
I have ECB 3500, I have used this over a year now. I upgraded to the new firmware, and I am trying to log in to it by typing the correct ip, and it gives me log in page, but once I type user name and...
try to reset the hardware by pressing at the back of the router.
then put the default user name and password.
if the problem persist,you must configure it using UTP CAT5E CABLE/RJ45
Feb 01, 2011 | EnGenius ECB3500 - wireless access point...
I'm trying to connect the ecb3500 as an AP Router to get wireless access from my cable modem. THe old LinkSys worked fine, although it has low power, but the ecb is unable to connect (status of connection...
ECB3500 Can I downgrade firmware safely with this product?Yes. I cannot get into the device from my computer. What is the basic setting check?
- Make sure you are directly connected to the unit.
- Do not have a switch or router in between and do not connect wirelessly.
- Make sure your power injector/adapter is on, power is going to the unit, and the "network" side is going to your computer.
- Make sure your computer is set to a static IP address of 192.168.1.10.
- Type in 192.168.1.1 using Internet Explorer.
How to change the IP Address?
The default IP address is 192.168.1.1. This IP address is typically in conflict with many routers out in the market. You will need to change the IP address manually to an IP address that is different but part of the same network. This means if your router IP address is 192.168.1.1, you should change the device to 192.168.1.2, for example. We recommend you change the IP address before other settings. You change your IP address in the "LAN" section in the GUI.
How do I reset the device?
Locate the reset button next to the CAT5 (RJ45) connection. Press and hold the reset button for 10 seconds and then let go. You should see your 10/100 LAN connection at your computer go away and then come back. That will confirm a reset has occurred. The unit settings should all be back to default including its IP address of 192.168.1.1.
How do I set up AP WDS Repeater?
Click here for instructions.
How do I set up the device under Apple MAC OS X environment?
I cannot connect or maintain a log in to the device.
We recommend using internet explorer with at least IE7 or higher. Make sure you have latest version of Java script.
What distance in kilometers (km) should I set the device to?
Default is 1km. If you are setting up long distance point to point links, the time it takes the radio wave to get there needs to be considered for proper handshaking (ACK response). This window should be accurate within 5 kilometers. In other words if you have a 5 kilometer link, ideally you should set it to 5km, but a setting of 1km to 10km should keep you in an acceptable window. For short distances, keep this to 1km.
What is a point-to-point link setup?One unit would need to be in AP mode while the other in CB mode. The AP should be connected directly to the routers LAN port, and the other will be in Client Bridge Mode linking back to the AP. The Client side will then provide a WIRED connection for users of the remote location. You can choose to connect this wired connection to just one PC, or to a switch, hub, or another wireless access point for multiple users at the remote location. What is a Client Bridge (CB) Mode?
A client connects to an access point. Your laptop is a client. A bridge is something that connects two "wired" networks together. A client bridge therefore is a radio that wirelessly bridges two networks. The Ethernet port of the 2610 in CB mode provides the wired connection to the remote location. This Ethernet port can directly connect to a single PC, a hub, a switch, or another router.
What is considered a "good" signal?The signal meter is not available in AP mode. In CB mode, under connection status, a signal of -74dbm or better is a good signal. It's important to understand which direction numerically is a better signal. Dbm's are referenced to 1 milliwatt. 1mW = 0dbm. A stronger signal would be a positive number and a weak signal would be a very negative number. For example, a -50dbm signal is stronger signal than -92dbm. What is spanning tree protocol?
When there are several possible paths a packet can route to (redundant links for increased reliability for example), a loop can occur (jamming up the network). It is used to prevent these loops.
What is the default gateway?The default gateway is your router's IP address. The default gateway information is not required, but is recommended.What is the default user name and password to log into this device?
Log in name is "admin" and password is "admin" by default.
What is WDS Mode?Stands for Wireless Distribution System. Allows access points to link together and provide repeating. Note however, this repeating comes at a cost of reduced bandwidth. Bandwidth will be reduced by 30-40%, and it is recommended that NO multiple repeating hops be done for this reason. Which antenna connector is the primary antenna?The one closer to the power jack.
Jan 06, 2011 | EnGenius Technologies ECB3500 802.11g High...
I just installed a new ECB-3500. It works fine on
Connect your Lenovo to the ECB with a standard Ethernet cable. Assure yourself that it can talk to the internet in this configuration. If it works, it will rule out DNS and DHCP issues and will point to a wireless-only issue.
Temporarily turn off encryption on your router and see if your Lenovo can connect. If it does, turn on WEP encryption only. If that also works, go back to WPA. Wherever the process breaks down, it will tell you where your problem lies.
May 17, 2010 | EnGenius Technologies ECB3500 802.11g High...
EnGenius Technologies ECB3500 802.11g High Power 600mw Access Point/client Bridge/repeater/router/wd Logo
66 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
