Question about Samsung HT-TZ515T Theater System with Wireless Speakers
I have a HT-TZ515 Samsung Home Theater. I have replaced the cooling fan, but now whenever I power up the unit, the fan stays on all the time. It is somewhat loud.
  • connertamago
    connertamago Nov 16, 2010
    Which unit did you replace the fan in and what measure was it? It's probably loud because the specs are not the same.
techman
  • 3130 Answers
SOURCE: Lost Remote for my Durabrand HT-395 Home Theater Systom
There are no codes you program into the remotes unless they are learning remotes. If you did the manual search for the code, then the universal remote will not work on that unit I'm afraid. You see you are not entering the code into the remote when you push the numbers the book tells you to. What you are doing is accessing the pre programed codes that are already programed into the remote. You cannot add any codes for universal remotes unless like I said before, they are called learning type remotes. Those cost loads of cash. Good Luck
Posted on Oct 15, 2007
djnick989
  • 1067 Answers
SOURCE: fan check issue
ya need to get fan fixed is safe mode cuse they genrate alot of heat have to have it in well vented area on a nice power strip like monster
Posted on Jan 09, 2008
SOURCE: comcast remote and need code for a samsung ht-tq85 home theater
http://www.ehow.com/how_2116903_easily-program-comcast-remote-control.html
Posted on Aug 02, 2008
  • 3 Answers
SOURCE: unlock home theater system samsung ht-x20
http://www.videohelp.com/dvdhacks/samsung-ht-x20/8981
This should solve it :) I had similar problems. Swapnil
Posted on Nov 04, 2008
rockfixya
  • 679 Answers
SOURCE: How can I make Samsung Home Theater HT-TWZ312 DVD Region Free
there is no region hack for.......
but please try the following code may be works>>
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. Wait for player to finish loading and display 'no disc'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. Turn off.
10. Turn player on then off again.
11. Player is now region-free.
Thanks for using FixYa.
Posted on Jan 23, 2009
Error fan check message always appear when you turn the DVD on
Page 32 of the manual:
http://www.retrevo.com/support/Samsung-HT-Z510T-Home-Theater-Systems-manual/id/14714ci454/t/2/
Cooling Fan
The cooling fan supplies cool air to the unit to prevent overheating.
Please observe the following cautions for your safety.
Make sure the unit is well-ventilated. If the unit has poor ventilation, the temperature inside the unit may rise
and may damage it.
Do not obstruct the cooling fan or ventilation holes. (If the cooling fan or ventilation holes are covered with a
newspaper or cloth, heat may build up inside the unit and fire may result.)
So look at the fan and make sure it's turning. Pick out the dust balls. Give the system room to breath (Page 13: 4" clearance from the fan)
Feb 07, 2011 | Samsung HTZ-510 Theater System
I have a samsung HT-Q100 and its plays well but it will turn off itself after 45 minutes of playing time. I've check the back of the player and it heats up really hot( on the right of the fan at the back)...
If the fan is not providing sufficient cooling (it could be that the fan needs replacement), try placing a portable fan where it blows on the back of the unit. If the unit continues to work, you'll know you need to replace the fan within the unit.
Mar 07, 2010 | Samsung HT-Q100 System
What does FanChck mean on my samsung HT-Z320? How to I fix it?
I had the same problem with my Samsung HT-BD1250. In my case the fan did not run at any time! As a safety precaution, to prevent overheating, when the fan is malfunctioning the receiver powers off. I simply opened up the receiver and discovered that the fan was not even connected! I just plugged it in and.....Voila! Works like a charm. Be warned though that if your unit is still under warranty, opening it up will likely void the warranty.
Feb 07, 2010 | Samsung HT-Z310T Theater System
Protection Error on power up
your cooling fan has failed. Check the back of the unit for exhaust air coming out. If not replace fan.
http://www.partstore.com/
Nov 23, 2009 | Samsung HT-DB120 System
Fan chk problem too
it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jul 04, 2009 | Samsung HT-Z310T Theater System
Samsung ht-wx70 shutting off for protection
The word PROTECTION means that the cooling fan is defective. it needs to be replaced.
Call 1-800-7267864 (SAMSUNG) and they can repair it for you.
Hope this helps!
Jun 30, 2009 | Samsung HT-WX70 Theater System
Cooling fan stopped working.
http://www.samsungparts.com/search/search.asp
try to check all the accessories for your unit here
May 30, 2009 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Samsung HTDS610 Home Theater System power wont stay on!
I have the same problem.
I did my research and this is the solution:
Your HT system is overheated and the fan is not working. Just replace the fan and you will be good to go.
Ken
Aug 06, 2008 | Samsung HT-DS610 System
Samsung home theater
After having my unit for a year, it now reads this PROTECTION message. I tried to restore factory settings also before calling Samsung & they said something wrong with the cooling fan. Haven't tore into it yet, but does the units come with a fuse that might be blown. I'm tring to find free schematics on the net but hard to track down. If you just got yours, take it back to the store & get a new one!
Oct 06, 2007 | Audio Players & Recorders
Samsung HT-TZ515T Theater System with Wireless Speakers Logo
134 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
