Question about Microwave Ovens
My kitchen faucet is model# 7705-CART with a bar code on my Home Expo receipt of 652312771507 which should correspond with model number listed. Is there any place here in Atlanta that would have the cartridge needed for this due to water not being able to be shut off by pulling down the lever. I have spoke with Tino customer service rep at Mico and he was saying this warranty item should be approved today but that we would not receive until 11/19/2010 which is this Friday at best. I need before then so as to not run up a large water bill. Please advise asap!
snakehead
  • 1074 Answers
SOURCE: GE Microwave Model JVM1650
the diode is open when the voltage arive at the anode junction it locks off due to the diode is not passing the voltage,change the diode and the microwave will resume operation.good luck.
Posted on Aug 04, 2007
tiway1
  • 100 Answers
SOURCE: home warranty company saying JennAir M166 built in microwave isn't a true built in
Bottom line is... Home warranty companies will do anything possible to wriggle out of paying for something. (Especially if it's American Home Shield).
I'd suggest offering to fax / email photos and the front cover of your owners manual. Your model is 100% considered a built in unit and they are lying to you and trying to cheat you if they say otherwise.
Posted on Aug 24, 2008
dmftrucker
  • 1922 Answers
SOURCE: Microwave won't Work
sounds like a fuse for starters, remove outer cover there will be a white cartridge appx 1"longX1/8"dia this is a ceramic fuse avail at most hardware stores in 15 or 20 amp configurations, if this blows again after repl suspect a faulty H.V. Diode/H.V. Capacitor, or the magnetron tube unless while inside unit you see something obviously wrong 2 fuses are under $5.00
Posted on Sep 27, 2009
Testimonial: "Thanks for the help! I'll try it and let you know."
  • 8909 Answers
SOURCE: I have almost the same
That sounds like the Magnetron/Invertor has failed and taken out the mains fuse.
The Invertor is not user serviceable.
Call an authorised repair department.
Posted on Feb 14, 2011
  • 4336 Answers
SOURCE: How do I get to
You have to turn off the water and disassemble the valve from the top side. Check your screens at the discharge point, particles block there, also.
Posted on Mar 05, 2011
The small round metal mesh discs inside the kitchen tap have fallen out & will not stay in when re-inserted. Now the water squirts out at weird angles drenching the kitchen work surfaces. Do I need a...
Hi Jean,
These mesh discs and the part they go into - along with a few other small parts - make up what is called "an aerator".
Most aerators simply screw on threads at the end of your faucet. You can remove it by twisting it. You may need a wrench to loosen it first. Wrap the aerator in thick cloth / towel so that the wrench does not dent or scrape the finish on the aerator body.
Some aerators thread up and inside the faucet - rather than at the end - and need a special wrench to remove
Once removed, you should reassemble the parts and reinstall on the faucet. You may find replacement aerators in Home Depot, Lowe's, etc. if you're missing parts, etc. If changing it out, be sure to bring the old one with you to match.
I hope this helps & good luck!
Sep 22, 2011 | Microwave Ovens
I obtained a Grohe replacement faucet head (kitchen) - part number 46298IE). The box contains (besides the faucet head) two small round cylinders (white); one has a green end; the other is white with a...
Thanks for the info about the lifetime warranty, who knew? The two parts mentioned are flow control valves that get inserted at the base of the sprayhead, not the in the hose. The green one says "water care" which will restrict flow more than the white one. It's an either or scenario, not both. There is a VERY faint arrow that points up toward the top of the nozzle. Push it all the way up and reconnect the hose tightly. That's it. My replacement didn't come with a wrench, did that come with the original faucet?
One more thing, if you bought a house that has this and don't qualify for the lifetime warranty, don't get stuck paying $100-$150 for this part if you just need to replace the aerator. The gray head that the water comes out twists out with a wrench revealing the aerator. The part number is 13929 or sometimes referred as 1392900, $10-15, if you can find it.
Sep 19, 2011 | Microwave Ovens
Don't know what the extra water line is for on my new kitchen faucet
Is it for the auxiliary sprayer that you may not have? You don't give much information about your new faucet except you do say it is on your microwave oven. I could give better help if I had an idea what make/brand/model it was.
Thank you for your question @ FixYa.com
Aug 15, 2011 | Microwave Ovens
I have installed the muirfield model kitchen faucet. I attached the water hoses and I am not getting hot water when I turn to hot. I am only getting a trickle. bith my hot and cold water is turned on all...
You are going to have to take the line off again and check it for debris or any plastic guides that have slipped out of place. You may have an internal clogg caused by something getting into the hot side of the faucet. Check any screens on the faucet for pluggage.
May 06, 2011 | Microwave Ovens
Our kitchen faucet has continued to lose water pressure over the past two weeks to the point that it's down to a trickle. We have removed the faucet to look for any clogging and there is none. what could...
You took off the faucet, but did you take the aerator off the spout? That's a very common trouble, especially if you have hard water with lots of minerals. The aerator screen gets clogged and your water slows to a trickle or is stopped entirely.
The aerator just screws onto or into the faucet, but you might need a wrench to remove it if it hasn't been off in a while. Tape the jaws of the wrench to keep from damaging the chrome unless you plan to replace the aerator. Once it's off the faucet you can take the aerator apart, noting the order of the pieces, and clean off the screen. Reassemble it and put the aerator back on and you should have your water back.
You might also just want to replace the thing; you can find replacements at hardware stores and home improvement places. Just take the old one along to make sure you're getting the right replacement.
Mar 12, 2011 | Microwave Ovens
How do I get to the cartridge to see if it is blocked in some way. I have reduced flow. This is on my kitchen faucet. American Standard Jasmine Kitchen faucet
Mar 05, 2011 | Microwave Ovens
We live in a house built in early 60's. Re; Plumbing to kitchen sink and dishwasher. On vary rare occasion the sink faucet will have decent water pressure. We have changed the water faucet with a Moen. As...
if this is the only place in the home where water pressure is a problem then the lines may very well be the issue. if you have low pressure throughout the home then there may be a problem with the main water supply in the home. if the lines are galvanized pipe then they may be restricted due to rust or other deposits forming on the inside of the pipe. unless you are good at plumbing then i would suggest having a professional come out and assess the condition of the lines.
Feb 25, 2011 | Microwave Ovens
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
Lost receipt book for my Oster Breadmachine Model #4807. Where can i get a receipt on line?
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers for spare parts, as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Jan 12, 2011 | Microwave Ovens
I need a glass tray for my NN-T664SFX
go to this website
http://www.pstc.panasonic.com/Epartr/PartsListChoice.asp
you can either search by model: enter NN-T664SF and click the part number box, then find the tray listed under accessories. OR
you can search by part number from that same link. Enter F06014T01AP and click retrieve part info. Once you add this to your shopping basket you will see two items listed, as the original model has been replaced by another model. Click verify availability... and the shopping basket will adjust and only show one item in the cart, which will reflect the replacement model item. Finalize your purchase from there by entering your personal info. Good luck!
Oct 06, 2009 | Panasonic Microwave Ovens
Microwave Ovens Logo
131 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
