Question about NEC VT670 Multimedia Projector
NEC VT670 status light blinks 12 times. New bulb installed a few months ago won't come on. The Power goes off. Suggestions? Actions? Cheers...
  • 144 Answers
SOURCE: Status light blinks red bulb replaced only 2 months ago
you need to reset the lamp timer
Posted on Jan 31, 2010
  • 74 Answers
SOURCE: HELP! I changed the bulb already. My NEC VT 470
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Posted on Apr 16, 2010
SOURCE: I have replaced bulbs in 3 different types of NEC
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
Posted on Oct 14, 2010
  • 23 Answers
SOURCE: NEC VT595 Projector - Status light blinks red constantly
Hi Craig,
If you get no lamp light at all coming from the main projection lens then odds are the lamp ballast or power supply has failed. These can usually be repaired & is a common fault among the VT series projectors. If one of the fans are stuck the unit normally still lights up for a few seconds up to 20 seconds or more until the extra heat trips the safety shutoff & shuts down the projector.
REPAIRS:
If you
Posted on Nov 16, 2010
SOURCE: I have a NEC VT700
I have solved that problems by replacing the plastic Lamp Cover. NEC says they wear out over the years due to the heat. If you have a spare VT700 about, swap covers and see if that works. or order one from NEC, thay cost 5 dollars.
Posted on Jan 26, 2011
Nec vt540 vt540k
probably needs filters cleaning or a new lamp replacement.
Oct 07, 2013 | NEC VT460 Multimedia Projector
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Apr 14, 2010 | NEC VT470 Multimedia Projector
250V T6.3AH Slow Blo Fuse
Depending upon the way in which the lamp finally smoked, it is not unusual for the feeder fuse to blow. Replace the fuse and try the projector. As long as you haev a new lamp, it should work OK.
Dan
Sep 11, 2008 | NEC VT670 Multimedia Projector
Lamp not lighting
Reset the lamp and try it.
Mar 28, 2008 | NEC VT660 Multimedia Projector
Status indicator / no lamp
The power supply unit ballast is bad for the vt670 part # 3n100572
Feb 12, 2008 | NEC VT670 Multimedia Projector
NEC VT47 Blink Sequence but not comming up.
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Feb 08, 2008 | NEC VT47 Multimedia Projector
No Picture on my nec VT676 model
Hi there
I'm shocked that NEC can't answer this guys.
The NEC's & Acer's make use of teh status lights and beeps to warn you that your lamp needs replacement.
Nov 13, 2007 | Office Equipment & Supplies
Status light blinking red
Oct 23, 2007 | NEC VT47 Multimedia Projector
NEC VT670 Multimedia Projector Logo
333 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
