Question about Xerox Phaser 8500/DN Printer
How to reset the xerox phaser 7500 chip? - Xerox Phaser 8500/DN Printer
    President:
  • 2,923 Answers
Try this: Hold down the back ARROW key with the "i" them with your other hand turn on the machine.
If that did not help, kindly contact the manufacturer and see if they have another way of resetting the chip.
Thank you and good luck!
Posted on Nov 22, 2010
  • Sam_Cheng Jan 17, 2011
    For this model,the right chip is very important,
Tip
Replacement drivers for the Phaser 7500
The print drive for this printer is horrible, and causes functunal print issues. The best and simplest work around for this is to not use the phaser 7500 driver. Answer coming next . . . Use the Okidata C9500 print driver. It works perfectly for the Phaser 7500. Now you know how to make it print properly
on May 10, 2012 | Xerox Computers & Internet
What is the steps for installing xerox 7500 MCU board
sir you can read service manual if you have if don't have service manual download it from this link
http://www.mk-electronic.de/spareparts/de/ger/PDFDokumente/Xerox/Drucker/Laser/color/Phaser%C2%AE%207500.pdf
hope that it will help you
Feb 05, 2014 | Xerox Phaser 7500N Laser Printer - 7500/N
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
How to reset toner chip on Xerox Phaser 6121 mfp printer?
You would have to replace the chip, there is no reset for it. Plus you would need to refill the cartridge with more toner as well.
Sep 04, 2013 | Xerox Phaser 3100MFP/S Laser Printer
I ´m searchingfor the same answer. I have been refilling the toners but now it seems thatthey reach the limits, so the printers is asking me for a new toner. I knowthat you can find from alibaba.com the reset chips. If I have any news I'llposted, please do the same.
Nov 15, 2010 | Xerox Phaser 7750DN Laser Printer
How do i empty the waste cartridge on my xerox phaser 7500?
Xerox has designed this so you must buy a new one from them. It's got a digital chip inside the waste cartridge, if you dump out the waste, the printer knows its getting the same old one put back in even if its empty. Wasteful printer. I hate it.
Aug 24, 2010 | Office Equipment & Supplies
Xerox phaser 7500DN does not proceed after warming up screen. Hangs on Warming Up Screen.
Open and close the paper drawers!!! Super stupid solution, but trust me... it works!
Aug 17, 2010 | Xerox Phaser 7750DN Laser Printer
How can I reset the Xerox Phaser 3100MFP fuser?
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
Dec 15, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Xerox Phaser  8500/DN Printer Logo
590 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
