Question about Apple MacBook Housing, Top Case with Keyboard Version 2 Mac Notebook
Spilled a little coffee on macbook--not even a 1/ 4 cup, dried off immediately-- on keyboard, then took battery out and back in and two keys not working so took battery out rinsed around those keys very lightly with water and wiped dry right away. Then took battery out for 24 hours to dry and then when put battery back computer slowly came on seemed fine, went dead after about a minute or two. What should I do?
    Problem Solver:
  • 6 Answers
After liquid spill the laptop has to be disassemble and the motherboard inspected for liquid damage. In some cases cleaning the motherboard might fix the laptop.
Check out this guide for troubleshooting Mac laptop liquid spills.
Posted on Sep 13, 2013
  • Apple Expert
  • 481 Answers
Bring it in for service and prepare for bad news.
When you spill liquids into a computer, the first thing you must do is disconnect all the power immediately, and do not reapply power to the computer until the spill is totally taken care of. This doesn't mean just rinsing lightly and patting, it means disassembling the entire machine, flushing all non-mechanical parts completely with distilled water, and air-drying in a clean, low-humidity environment. And even then you need to cross your fingers that when you apply power, it isn't going to smoke on you.
In the future, keep all liquids far away from computers.
Posted on Dec 02, 2010
Keyboard dont type
No matter how careful you may be, knocking a cup of coffee or spilling a glass of soda over your keyboard may happen. This does not, however, mean the end of your keyboard. If you act quickly, you may be able to fix your wet keyboard to avoid any corrosion of its electronic components or any short circuit which might render it unusable. By following a few recommendations, you should be able to fix your wet computer keyboard.
Unplug the keyboard from your computer immediately after the spill to avoid any corrosion or short circuit. If you spilled water over your laptop's keyboard, turn your computer off by clicking on "Shut Down" on "Turn Off" in the start menu, unplug the power supply and remove the battery. Turn the keyboard upside down and shake it to remove most of the water from it. Take a hair dryer and set it to its lowest temperature setting. Use it to dry any water which might remain under your keyboard's keys. Wait at least 12 hours before plugging your keyboard into your computer again. If your computer is a laptop, wait 12 hours before turning it on again. For Other Liquids Disconnect the keyboard from your computer immediately after the spill to avoid any short circuit or corrosion. Turn your computer off by selecting "Shut Down" or "Turn Off" in the start menu, remove the battery and disconnect the power supply. Place paper towels on a table, turn the keyboard upside down and shake it over them to allow most of the liquid to fall down. Take a few clean paper towels and wipe the liquid off your keyboard's keys. To clean between the keys, you can also use cotton swabs with just a little bit of water. If the liquid which you spilled over your keyboard contained a high amount of sugar, such as soda or sugared coffee, you might have to remove some of your keyboard's keys to clean the surface under the keys with paper towels or swabs. You can do so by lifting them gently with a screwdriver or by using a key remover, which you can find in some IT stores. Wait at least 12 hours before using your keyboard again. If your computer is a laptop, wait the same length of time before turning it on again. How to Clean Your Keyboard http://www.tucows.com/article/684 Fix Computer Keyboard Problems http://technologyandinternet.blogspot.com/2007/10/fix-computer-keyboard-problems.html
Apr 20, 2013 | E-Machines eMachines Desktop PC
Tip
Spilled liquid on Keyboard!
1. Purchase plastic keyboard cover. 2. Keep coffee etc. anywhere not near keyboard.
For spill, unplug keyboard. If non sugar liquid, invert keyboard, shake or tap gently. Wipe with lent free absorbent cloth while still inverted. If soda or coffee with sugar, pour 1/4 cup of clear clean (distilled the best) water onto keyboard (yes), Then invert. Let dry a minimum of several hours still inverted. I cheat with a hairdryer on low 6-12 inches. After keyboard is completely dry (and cool). Plug in after turning computer off, restart, test all keys, including shift, option etc. If keys miss or don't work buy new keyboard and cover! Aloha, Cliff
on Sep 27, 2014 | Apple 24" iMac Desktop
Spilled coffee on keyboard now screen flickers
I wash once a laptop keyboard after someone spilled beer on it. Try to unmount keyboard and wash it with water and soap. It works for me. Let keyboard to naturally dry one day.
Jul 21, 2012 | Computers & Internet
I have a gateway keyboard ku-0833 and its working fine but I spilt a little coffee on it and a few of the keys are stiff to push. Is there a way I can clean it, tried using cotton swabs around the keys but...
You can pry out the keys using a butter knife and use rubbing alcohol to clean the underneath.
if the coffee got into the connectors you might be out of luck.
**THE FOLLOWING IS NOT RECOMMENDED**
When i spilt mt dew on my keyboard i took out the battery let it decharge for 5 minutes. I put it in a pan and poured rubbing alcohol on it and let it sit for 5 min. While it was sitting i swished the alcohol around a little bit so it could flow. took it out and let it dry for about 1-2 hours and it worked perfectly. this is orta used as a last resort
Nov 24, 2010 | Gateway 2520915 Keyboard
I spilled coffee on the key board and need to replace it. The key board appears to be sealed in with a plastic surround. How do i get the key board out? It is an E-system 3213Intel celeron. Yours hopefully...
Take the keyboard and run water over it and take it apart and let the component dry out (while it is not connected to the computer).
I had a mechanic tell me that this is what he did to a keyboard that was part of an automobile engine analysis Bear Ace machine at Sears.
He said that someone spilled a cup of coffee on it and it wouldn't work.
Good luck on this repair of a coffee stained keyboard.
Jul 20, 2010 | Gateway Computers & Internet
A cup of coffee spills in the keyboard of my laptop, now coffee is dry out but the keys are stuck
I'm sorry but the keyboard has to be replaced. The new keyboards us a chemical contact and the hot coffee has damaged the chemical.
Mar 25, 2010 | Computers & Internet
Spilt coffee over keyboard
It might be :-( and usually stuff that lack isn't covered unless you pay extra for a high end warranty.
There are a few things you can do to try to save it though. As long as nothing shorted out (you didn't smell anything burning did you?), chances are a good cleaning could fix it. Are the keys sticking? Most laptops nowadays have a small try under the keyboard to keep stuff away from the vital electronics in case of situation such as yours.
1) Power down the laptop and remove the battery
2) Gently pop the keys around where the spill occurred, just pry them with your finger nail, they should snap right off with a little encouragement
3) Take a damp rag and blot up any remaining spills, or sticky spots, remember liquids and electronics dont mix so go easy on the water.
4) With a dry rag, blot up any remaining wet spots, can hurt to let it sit and air dry for a few minutes as well.
5) Pop all the keys back on and hopefully you'll be all set!
Feb 04, 2010 | Apple MacBook Mac Notebook
How to clean keyboard - sticky keys
If you're lucky, the coffee did not penetrate into the key membranes. Remove the battery, then try rinsing the affected area with clean water the same way you spilled your coffee. That way the water will go into the same areas. If you try some upside-down-on-an-angle rinse, the water may not get into the sticky areas. Dry immediately using a hair dryer set on low/medium.
Chances are it's ruined, but a few minutes of rinsing and drying might save your keyboard. Not much to lose by trying.
Nov 12, 2009 | Microsoft Wireless Optical Desktop Comfort...
Need to restart Logitech external keyboard after spilling coffee
If no operation after a few days the liquid did permanent damage to keyboard. Not uncommon.
May 08, 2017 | Logitech 9675020403 Keyboard
Apple MacBook Housing, Top Case with Keyboard Version 2  Mac Notebook Logo
613 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
