Question about JVC Televison & Video
Hi, have an older model VHS # HR-A61U . The tape will not eject and found a small spring on the stand under the recorder . I opened the cabinet but cant tell where the spring goes. It is not broken or strecthed just came off. This happened a few years ago and took it to an authorized repair center and waited for a few weeks to get back at a cost of almost $100. Anyone have an idea or pic as to where this goes. The belt is not broken . thanks
ANTHONYPAULB
  • 17 Answers
SOURCE: JVC HR S5700AM S-VHS video recorder - won't accept tapes
Hey Lindsay
Yes the ejector is probably damaged inside maybe a bent arm or something mine is like that 2 and I didnt even bother fixing it I will be finding one very soon and I suggest you should 2 so just throw out the old and come in the new with your new vcr or dvd vcr combo..
Posted on Jul 23, 2008
  • 4234 Answers
SOURCE: Re: Model PV-4523S
The problem is that the "idler" assemby has gotten slippery. This is either a rubber tire or perhaps a gear that is driven by a belt inside the machine. In either case, this is a simple repair and is common as machines age. This should be a $75 repair including parts. The pinch roller (rubber cylinder) is what pulls the tape across the heads in a steady fashion and has no role in keeping the tape inside the cassette. This is handled by the idler assembly and works for FF/REW and PLAY. Also, a cleaning tape will clean the heads but not effect the pinch roller.
Dan
Posted on Jul 30, 2008
  • 19 Answers
SOURCE: tape wont eject small spring found
Take off top of vcr to expose the tape carriage lift tape door, on the lhs/rhs you shouls see the other small spring fit the spring that you have to the opposite side and try to eject your video cassette, the spring is the part that is stopping from ejecting the tape hiopefully once you have reattached the spring all should be well.
Posted on Aug 14, 2009
  • 16 Answers
SOURCE: JVC HR-S9500 S-VHS VCR. all functions work except
the eject button is a plastic piece that turns and pushes down on the board and is more then likely broken open the vcr take off the front face plate and check the button, it will propaply fall out. you can use super glue and glue the button back in place
Posted on Jan 05, 2010
mybradley7
  • 242 Answers
SOURCE: Wont eject the tape. Found small plastic gear broken.
check the tip in my profile
Posted on Jul 31, 2010
Hi, I have a JVC HR-J658 VCR that doesn't eject tapes.
You mean a tape is stuck inside? Disconnect power and open up the cover. If the tape is stuck around the posts, free it and by manually turning the loading motor you can slowly get the mechanism to eject the tape.
Nov 05, 2013 | JVC HR-670 VHS VCR
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
Tape wont eject small spring found
Aug 14, 2009 | Sharp VC-A560U VHS VCR
My Panasonic Omnivision VHS won't eject
take the top off and eject it manualy, there is nothing else u can do with replacing a part, (small white spring loaded, ) probabaly
May 09, 2009 | Zenith ZHX-313 System
Tapes won't go down, and then eject.
Have you tried to force eject the cassette. May be the ribon of the tape has come out. Try using another cassette.
Mar 24, 2009 | Panasonic PV-V4522 VHS VCR
Will not release the cassette when ejected and breaks the tape.
there is a spring attached to the tape release gear that will eventuall wear out through time, also, sometimes the rubber belts wear out and throws the timing off.
That would be the first two things to check. Make sure spring is not stretched. Try testing with cover off and watch to see if the part holding the back of the tape releases.
Mar 11, 2009 | JVC Televison & Video
JVC HR -J655EK Video Stuck
Hi hannah. The simplest way to remove stuck tapes is to remove the top cover. Usually just a couple of screws. Then remove the stuck tape and put the cover back into place. You can also look for emergency eject hole and insert a snall pin into the hole and attempt to eject the disc while repeatedly twisting the pin inside the hole.
May 16, 2008 | JVC HR-J461MS VHS VCR
Recording issue
if it is really old there might be a switch on the front under the little door to switch record speeds.
Apr 24, 2008 | RCA VR615HF VHS VCR
Lg v181 combo problem with vcr keeps ejecting tapes when I want to record.
The tape load carriage is defective or there is something in the way inside the machine....accordianman
Feb 21, 2008 | LG V181 DVD Player/VCR
Older VHS tapes play 'sped up' on S-VHS
A couple of possibilities: 1. One of the machines had a audio & tracking head alignment problem. If memory serves, tracking pulses are recorded on the bottom edge of the tape, and if one machine's head is slightly off, then these pulses aren't being picked up.
2. Do both machines have 3 play/record speeds? Many machines had SP, EP, & LP. Some didn't have EP, and if your older tapes were recorded in EP, perhaps this would cause your problem.
Both of these possibilities might be way out in left field.
Perhaps you could have a friend try your old tapes in their machine- in short, narrow down the defect. Is it the older VCR and it's recordings, or is it some goofy problem on the new one.
Lastly, you might check the audio/tracking head- see if it needs cleaning. This head is just to the right of the rotating video drum assembly.
Jan 28, 2008 | JVC HR-S3901 S-VHS VCR
Televison & Video Logo
53 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
