The heater blows the fuse the problem started when unit ran out fuel the unit is a dyna glo heater
  • 2,299 Answers
Does the fuse blow immediately? Or does it run for a while before the fuse blows? Please give me more detail. Thanks!
Posted on Nov 15, 2010
I just turned on my dyna-glo kerosene topedo type heater and it run for about 10 seconds without igniting and then shuts off with a red flashing indicator light on!
the photo electric cell is not working
it is doesn't see fire , it shuts off the fuel so that excess fuel is not going to the chamber that can cause an explosion or fire if it ignites
new items , take it back for a warranty check or refund
for older units tale it to a service agent for repairs
Dec 08, 2016 | Dyna-Glo Heating & Cooling
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Why does the fuse keep blowing out on my dyna glo roc kfa 120 forced heater
Because there is a fault in the unit, time to get it repaired assuming that is the correct size of fuse.
Dec 13, 2014 | Dyna-Glo Heating & Cooling
Dyna-glo work horse 120,000 btu blows the fuse when fan motor kicks on
Looks like the motor is trying to draw too much power, causing the fuse to blow. There could also be a heavy strain on the motor, causing this as well. Sometimes the fuse or circuit breaker will go bad and need to be replaced as well. Good luck.
Dec 04, 2014 | Dyna-Glo Heating & Cooling
I have a dyna glo pro rmc-kfa170tdgp heater. its 3 yrs old and is used ea. winter. its stored and still looks new. we started the heater and ran it until it was empty. we refilled it and now it wont...
This is only a guess but how about putting a drop of light house hold oil on the top of the fuel tank then screwing it on. If I were to guess and I certainly am I am guessing that the fuel valve is stuck, just like my fork trucks do in the winter. Try this and if you can some how let me know if this worked for you.Curious as to out come. Good luck
Dec 28, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
I have a dyna glo ventless model fp 65 30,000 btu flame doesnt burn very high
It would be ideal to take it apart and blow it out but you could try vacuuming out the grates real good.
Nov 11, 2010 | Dyna-Glo D-E37 Wall Mounted Panel Heater
My Dyna glo Heater RMC-KFA210WH-03 will not fully ignite
I just bought one. The fuel line was cracked. Replaced it 2$ fix
Jan 27, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
My Dyna Glo heater forced air heater worked great last year. I run it on Diesel and ran it empty before putting it away for the summer. Went to fire it up and it wouldn't work. Replaced all of the cracked...
the filter in the tank line is partially clogged with gel from useing diesel fuel you should really use a anti gel agent when running a sulphur type fuel in a unit designed for white gas/ keosene
Jan 20, 2010 | Kitchen Ranges
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
