Question about Gateway FPD2275W LCD Monitor
Thanks........ OK, ohms.....I'm trying it in a two-step process. Just changed the Power Setting Options as you suggested. Let's see what this does to the problem. If it doesn't change, I'll move to a blank screen for screensaver. And then, if THAT doesn't work, I'll probably go get a new monitor.....sound like a plan??? Thanks ever so much.........
  • cp556 Jun 19, 2008
    UPDATE ON WARRANTY REPAIR:
    LG honored its commitment. They are sending me a new monitor (my credit card will have a hold for $183 until I return the old monitor). They are paying shipping charges both ways.
    Apparently I'm not the first one to have this problem. The only question LG Warranty asked was "what resolution is it set to" and my answer was acceptable.
    So perhaps this on/off issue is a known problem...
    THANKS TO OHMS FOR HIS ANSWERS! I'll use you guys again....
  • cp556 Jun 22, 2008
    Ohms fixed it! Since I changed the Power Options settings as directed, the monitor has not gone to sleep and thus been hard to wake up.
    At ohms' suggestion, I activated my 3-year LG Warranty and a new/refurb monitor is on its way to me at no charge from LG.
    Good work, ohms!! I'll tell my friends about FixYa..... thanks!!
  • 1,879 Answers
Comment by ohms, posted on Jun 19, 2008Definitely it is not your computer. When it was given the signal to go OFF, it did but like completely off. Comment by ohms, posted on Jun 19, 2008Oh one more thing, if the monitor still exhibits same issue after setting your Power Options as displayed above,
check your warranty with that monitor and exercise it.
Yep u got it !
Posted on Jun 19, 2008
  • monk3ybidzness
    monk3ybidzness Jun 19, 2008
    sorry - i posted my response at the original thread : )
How do I check the coil on my 8n to verify it is OK?
A digital multimeter is required for testing the resistance levels of the ignition coil. The terminals of the coil are going to be marked "negative" and "positive," and these are the two points where the resistance of primary winding can be measured. Step 1: Prepare the multimeter
To check a 12 volt coil, set the multimeter to at least a 200 Ohms setting. Attach both leads of the meter to the coil-terminals with black to the negative terminal and red to the positive one.
Step 2: Test the resistance
The normal, acceptable range for a standard 12-volt car is 1.5 to 1.7 Ohms. See if the reading is within this range.
Step 3: Test the secondary coil resistance
Set the meter to 20K Ohm setting, and attach the leads to the ignition coil's center terminal. The reading for secondary-coil resistance should be 11, because if it is lower, that's the reason why sparks are not appearing
Oct 19, 2016 | Cars & Trucks
How do I get computer to hibernate...when it NO longer is one of my options??
try control panel Power options and look to enable hibernation. or serach the help part of your computer for enable hibernation.
May 07, 2015 | Dell Computers & Internet
Samsung
Hi Anubhav,
Please try the ff:
Perform a Soft Reset
Step 1 Press and hold the power button for 10 to 20 seconds.
Step 2 Release the power button and tap the "Power Off" option under the "Device Options" menu that appears. Tap "OK" to initiate the shutdown.
Step 3 Press the power button again to restart the device.
Perform a Hard (Master) Reset
Step 1 Tap the "Menu" key from the home screen and then tap "Settings."
Step 2 Go to "Privacy" and tap "Factory Data Reset" to review the Factory Data Reset information.
Step 3 Review the Factory Reset options. Place a check next to "Format USB Storage" to clear your device of user data, such as music, pictures and other account settings.
Step 4 Review the disclaimer and verify your changes before tapping "Reset phone."
Step 5 Tap the "Erase Everything" or "Yes" buttons to confirm the reset the phone to factory settings. The device initiates the restoration process to the original factory configuration.
Perform an Alternative Soft Reset
Step 1 Power off the phone. If the phone does not turn off, remove the back cover of the phone and take out the battery. Wait between 10 and 30 seconds and then replace both the battery and the cover to restart the device.
Step 2 Simultaneously hold down the power/lock keys.
Step 3 Release the keys when the Android screen appears.
May 06, 2014 | Cell Phones
Proxy setting 130
Exactly error: "Unable to connect to the proxy server
A proxy server is a server that acts as an intermediary between your computer and other servers. Right now, your system is configured to use a proxy, but Google Chrome can't connect to it.
Here are some suggestions:
If you use a proxy server, check your proxy settings or check with your network administrator to make sure the proxy server is working.
If you don't believe you should be using a proxy server, try the following steps: Go to Wrench menu > Options > Under the Hood > Change proxy settings > LAN Settings and deselect "Use a proxy server for your LAN."
Error 130 (net::ERR_PROXY_CONNECTION_FAILED): Proxy server connection failed."
Any doubts you can get the help of a technician through
www.thebestpcdoctor.com
Toll free: 877 407 9229
Sep 19, 2011 | Google Chrome
MY asus pc continues to not wake up. I have to
POWER OPTION
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
POWER OPTION
-set display to never
Restart pc
Jul 15, 2010 | ASUS Eee PC 900 Notebook
Think pad t42 monitor keeps turning off. I tried changing power settings to never ... did not help still doing the same thing anything else I can do? thanks
POWER OPTION
Restart pc
POWER OPTION
Restart pc
Jul 02, 2010 | IBM ThinkPad T42 Notebook
I have recently purchased a replacement battery for my HP zd8000 laptop. The problem is that the laptop is calibrated for the old battery and doesn't appear to even want to charge the new one. Any help...
You should first try to recalibrate the notebook and battery using the following steps: (this should be done every three months also as short charges and discharges really mess it up and will give you a false reading)
Step 1 - Disable the Windows Power Management
In Windows, right-click the Desktop and select Properties in the menu list.
Click the Screen Saver tab and then click the Power button.
Under Power schemes, select Always On in the drop down menu.
Under Settings for Always On power scheme, select Never in each of the drop down menus.
Click OK on the Power Options Properties window and then click OK on the Display Properties window.
Step 2 - Fully charge the battery
Connect the AC adapter to the notebook.
Charge the battery until the Windows battery meter is at 100%.
Step 3 - Fully discharge the battery
Remove the AC adapter.
Keep the notebook on until the battery has completely drained and the notebook automatically turns off.
Keep the AC adapter connected to the notebook until the battery has completely charged.
Step 4 - Enable the Windows Power Management
Under Power schemes, select Portable/Laptop in the drop down menu.
Now...
If you go into Control Panel, Power Options, and select the Power Meter tab, what does it say?
If you are still having issues, then do the following and then go back through the recalibration process:
Try going into Control Panel, Administrative Tools, Computer Management then down to devices and there should be an entry for batteries. Select that and right click to select scan for hardware changes.
Jan 04, 2010 | HP Pavilion zd8000 Notebook
Can't put computer to sleep, again
go to your desktop right click then properties go to screensaver then click the power then you will see the power options properties click the hibernate then enable it clik ok then ok again
Aug 10, 2009 | Compaq Presario SR5712F PC Desktop
How do i get my lock off
right click on the desktop, properties, slect screen saver, setting, change the setting, you can put it never, so never will power off.
Mar 14, 2009 | Acer Computers & Internet
My Browser
If you can ping an address successfully then the problem is either with a proxy setting or a corrupted setting in browser.
These instructions are for IE7:
Click Tools > Internet Options > Connections tab > LAN Settings.
Make sure that "Automatically Detect Settings IS checked. Also, make sure that "Use Proxy Server for your LAN IS NOT checked.
If there is an address in the Address box under that option, then you will to either need to erase the address before unchecking the proxy option, or temporarily check the option to use proxy server then erase the address and then uncheck the box again. Then click OK and close all screens. Then open Internet Explorer again.
If that works, great. If not try resetting the browser setting to default by following these steps:
Click Tools > Internet Options > Advanced tab
Then click the Reset button at the bottom. Then read the dialog that comes up and make sure that you are Ok with the changes that are gonna be made. If so, click Reset and the bottom of the dialog box.
After the process finishes click Close and then OK. After that close and reoopen Internet Explorer.
I hope this helps. Please remember to rate this information.
Thanks
Aug 31, 2008 | Averatec 6200H Notebook
Gateway FPD2275W LCD Monitor Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
