Question about Samsung Refrigerators
Hi, I have a Samsung side by side RS21DASW 532 liters. It is correctly pluged, in a place out of he sun and wiht good distance from the wall. The display keeps blinking the numbers and the ice is melting inside the freezer.The fridge seems not working as wel. What can I try?
  • 1462 Answers
SOURCE: SAMSUNG SIDE BY SIDE FRIDGE FREEZER
these appliances are a pain in the butt. fault with water dispensor is oprob that the water bottle at bottom of fridge is frozen. rise in temp is prob that defrost not taking place. not a diy unless you are experienced
Posted on Mar 20, 2007
fridgetech
  • 473 Answers
SOURCE: whirlpool side by side fridge freezer s20-d rbb32 a/g
Either there is a loose connection at that board or in the plug where the wiring goes into the door (should be at top or bottom door hinge). If all connections are tight then replace the board. Not sure how old this unit is but it does come with a one yr warranty from date of purchase.
Posted on Oct 08, 2007
  • 1073 Answers
SOURCE: Ice maker is not working
if you keep your hands out of the little beam slot on the paddel that is located on the left of the freezer and push it in the beam should shoot across to the reciever on the right and the light should stay on constant, that is if you have the switch on the right side turned on.
if it is turned on and the paddel is depressed and the light is still blinking the you need a beam kit part number 4389102
Posted on Apr 12, 2008
SOURCE: sub-zero 532 problem
you have a Freon Leak @ the Evaporator.. Ice ball on back wall.. left side....
Posted on Apr 15, 2008
SOURCE: Samsung RS2533SW freezer not cooling problem
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Posted on Apr 20, 2009
I have a vehicle which have moved for 2383 kilo meters and used 320 liters of diesel what should be the consumption rate
school work you should solve by yourself... not by fixya...
you have following data:
v = volume = 320liters
d = distance = 2383km (kilometers is a single word...)
there is several formula to solve this mathematical problem, if you want how many liters per 100km formula is as follows:
(v/d) x 100 = 100km/ltr just substitute your data
if you hear then that vehicle is using 7.5ltr/100km that was the formula. unfortunately - you need to calculate your own data, this was just an example...
another variation is distance per liter, there is formula:
d/v = distance (kilometers) per liter
if you hear that car is driving 11km/ltr - that is again, and example, you need to calculate your own data...
enjoy! and vote...
Feb 10, 2015 | Haier DWL3525DDBB 24 inch Built-in Tall...
Tv was cleaned with water yesterday on the screen and today one side is duller and the picture is shaking. When first turning it on the left side of the screen is white and right side is black
I'm afraid you have gotten some water where it never should be; the current controlling the millions of pixels is being bled off.
If you live where heat is now available, place the set (power disconnected) where it is exposed to warm air.
If the sun is shining and you can place the set with the back facing the sun, let it sit for a while and you might try prayer that nothing was damaged by currents flowing where they should not.
A little late for suggestions but LCD screens have many hundreds of electrical contacts around the perimeter of the screen and water (or any other liquid) should never sprayed at the screen.
A clean, soft cloth, sprayed (dampened) and gently wiped on the screen should suffice to remove most contaminants.
If the surface of the screen seems to yield (soft to the touch) use extreme caution with pressure.
Good luck-
Jan 10, 2015 | Samsung UN55H6203 55 Inch 1080p 120Hz
How big is neptune and how far is it from the sun
According to CoolCosmos,
The average distance of Neptune from the Sun is 2,795,084,800 miles or 4,498,252,900 kilometers. Because its orbit is elliptical, its distance from the Sun changes depending on where it is in its orbit. The closest Neptune gets to the Sun is 2,771,087,000 miles or 4,459,630,000 kilometers. The farthest it gets from the Sun is 2,819,080,000 miles or 4,536,870,000 kilometers.
Dec 18, 2014 | Washing Machines
The distance of the Sun and Mercury
Assuming you mean the distance from earth to the sun and earth to mercury, the are as follows, according to Wikipedia: The mean distance from earth to the sun is 149,597,890 km.
The mean distance from mercury to the sun is 57,909,715 km. Extrapolating, by subtracting the two distances, one gets 91, 688, 715 km as the mean distance from earth to mercury assuming that the planets were in alignment on the same side of the sun.
However, with mercury on the opposite side of the sun from earth then the distance from earth to mercury would increase by 57,909,175 km over the earth's distance to the sun to 207,007,965 km.
I hope this helps you with your problem with the 1987 Alpine V6 though I can't imagine how.
May 14, 2014 | 1987 Alpine V6
Uranus facts
Mean distance from Sun:19.19 AU = 2.871x109 kmMaximum distance from Sun:20.07 AU=3.003x109 kmMinimum distance from Sun:18.31 AU=2.739x109 km
Hope this helps!
Oct 17, 2013 | Computers & Internet
Two fire stations are 12 miles apart. Juliet, the ranger at tower A, notes that a fire has started at an angle of 42.3 from the line between the two towers. Romeo, the ranger at tower B, finds the angle is...
Hi ya,
Let x = distance between towerA and the fire
=> x = 12*cos(42.3)
=> x = 8.876 (correct to 3 decimal places)
let y = distance between towerB and the fire
=> y = 12*cos(61.7)
=> y = 5.689 (correct to 3 decimal places)
Here's a handy page on the use of SohCahToa - http://www.mathsisfun.com/sine-cosine-tangent.html
I hope this helps and good luck! If you have more questions - ask away!
Many Thanks Don.
Sep 07, 2011 | Computers & Internet
Hi i have a samsung 40" LCD TV wiht the clicking
Useally it 3 more,it alway on the tv power supply board.The the board,where the power a/c plug into it.Seaches the entire power supply board for dying capacitors,it alway bulges up or puffing up on it tops.By replacing all these capacitors with the same Micro Ferit and about 10 voltage rating higher for those dead capacitors for better tolorance next power supply board spike heat waves.
Jan 27, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Sub-zero refrigerator not getting cold - model 532
make sure that the compressor filter is clean -- if it hasn't been cleaned recently, can prevent proper operation.
Jun 06, 2010 | Refrigerators
HOW TO BLEED FUEL LINE ON LANDROVER
on most Discovery's the fuel rail will have a schrader type valve (usually on the right side of rail -US pass side). let the car sit a while before you do this and have some rags to collect any fuel that shoots out. (wear protective eyewear, and dont stand directly in line wiht this as it can shoot a distance). press the valve (like a tire valve) slowly, and fuel will squirt out until the pressure is equalized. in some cases, wiht weaker pressure regulators, you may not get much out at all. thx
May 10, 2010 | 1996 Land Rover Discovery
Refrigerators Logo
44 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
