Question about Panasonic DMC-ZS1 Digital Camera
When I turn off my camera the lens doesn't go all the way in.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 15, 2010
Lens error restart camera canon SX10IS
Here are some troubleshooting steps for a lens error. And here's a video summary of those steps:
Jan 23, 2013 | Canon Cameras
Lens doesn't work
Try removing the battery and memory card for at least 15 minutes. With some cameras, this will reset the camera and lens may clear the error message, as long as there is something that is not physically damaged the camera.
Jan 20, 2013 | Kodak Easyshare C195 14 Mega Pixels...
Hi. my problem with my camera is that my niece play with it and she pushed the lens mechanism while the camera is on. now, the lens was stuck and doesn't comes out anymore. when i'm turning on
Force it out like it was forced in. Try to rotate the lens. Remember it has to be off. As soon as the lens is half way out, turn the camara on and the lens will go to its position. If not, while the lens is out turn it left or right until it's back to its position.
Good luck.
Aug 24, 2012 | Sony Cyber-shot DSC-W55 Digital Camera
My Sony DSC-S700 froze with the lens open yesterday while I was taking pictures. I took the batteries out and put them back in but it would not turn on. I went home and charged the batteries and it still...
The lens can become bound by grit and dirt, it can be off its tracks, or it can be sitting crooked due to dropping it or rough handling. First make sure you have a fully charged known good batteryc:%5cusers%5charry%5cappdata%5clocal%5ctemp%5cmsohtml1%5c01%5cclip_image001.gif in the unit and it is turned off. Plug your Audio/Video cable into the camera. Lay the camera down on its back on a firm smooth surface. Press on the shutter button with one hand and while holding it down turn the camera on. If the lens becomes free, immediately point the lens down toward the floor and use the zoom to zoom it out. Take a soft brush, such as an art brush, and brush around the base of the lens to make sure you have removed any sand, dirt, etc. from the crevice around the lens where it enters the camera body.
If that doesn't free the lens there are a couple of other things you can attempt, but these may damage the camera too. If the camera is going to be tossed in the trash if it doesn't work try these two steps.
1. Take the battery out of the camera. Grasp the camera by the edges of the top and bottom with the lens facing downward. Cup your other hand slightly and smack the face of the camera into the palmc:%5cusers%5charry%5cappdata%5clocal%5ctemp%5cmsohtml1%5c01%5cclip_image001.gif of your cupped hand several times. Reinstall the battery and try the camera.
2. If step 1 didn't work, look closely at the lens seating in the camera. See if the gap around the lens is even all the way around. If it is not, take a thin tool of some sort that will fit into the gap at the narrowest point and softly pry the lens slowly toward the widest part of the gap. If the lens is off the pins, sometimes that will snap it back on. If you hear a small light snap. reinstall the battery and try the lens. If it works, point it face down and run the lens in and out several times using the zoom.
If this doesn't work, and again, ONLY if the camera is going to be trashed if you can not fix it, try prying the the lens out forcefully, but gently. This has worked as a last resort many times. Good luck.
Aug 22, 2012 | Sony Cameras
How do I re-set a 10.1megopixel c1033
Chances are something is blocking the lens. It could be a lens cap, or your finger, or even a grain of dust or sand.
Here's the best first course of action:
1. Turn off the camera
2. Blow sharply into the areas around the lens/lens cap.
3. Turn it on again and see if that resolves the problem. Be sure nothing is physically obstructing the lens. (No lens cap, no finger, etc.)
4. If blowing doesn't work, try using a can of compressed air like you would buy at an office supply store, and blow out the area around the lens and lens housing. Chances are, if nothing was obstructing the lens that you could see, it might be a bit of dust or sand. Even a little sand can totally screw up the lens and keep it from moving in or out.
5. If this doesn't work, you should take your camera to a camera shop and have it professionally inspected and cleaned. Check out how much this will cost, though, before you do -- it might not make sense to pay what they want to charge, versus just buying a new camera.
May 05, 2012 | GE C1033 Digital Camera
Panasonic DMC-ZS1 Digital Camera Logo
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
