Change a JennAir JMV8208aa Microwave light bulb
Inside light
1. Disconnect power to oven.
2. Remove screws located in front on top of microwave securing grille.
2. Remove grille.
3. Remove screws securing bulb holder.
4. Remove light bulb
Cooktop lights
2. Remove lamp cover or remove screws securing bottom plate cover.
3. Disconnect lamps.
If your bulb is stuck or physically broken, it can be a pain. It's sometimes tacked in place with hot glue,
and sometimes there may have been enough moisture to corrode and seize
up.
You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
You
may be able to put the tips of needle nose pliers inside the broken
bulb's socket, gently but firmly force the pliers jaws apart and then
rotate the pliers to loosen it.
Another cool trick is to put a big
glob of hot glue on the end of a stick or dowel, then shove it into the
broken base and let it cool about 5 minutes, then turn the stick.
I
like to put a little WD-40 or rust buster on the threads of the new
bulb, too. Grease, Vaseline, cooking oil, or anything like that will
work. Just a thin coat.
The lamps are available at most grocery stores, hardware stores, home centers, and places like Wal-Mart and Lowe's.
If the unit uses halogen bulbs, do not handle them with bare hands, as oils from the skin make them run hotter and shorten their lives.
