Question about Intertherm P3RA-048K Air Conditioner
Need sequencer for intertherm mac2460a furnace. furnace is 35 yrs. old . where can i find parts?
3 Suggested Answers
Gigatech
  • 259 Answers
SOURCE: REPLACED 10KW FAN/HEAT SEQUENCER AND LOST TRACK OF WIRING
Could not find the E1Eh-020HA but found the E2 series
http://www.nordyne.com/Literature/707716c.pdf
http://www.nordyne.com/Literature/901a.pdf
Hope this helps. :]
Posted on Dec 13, 2007
SOURCE: How do I remove the limit switch from my old furnace?
Sounds like you took a hit from a capacitor. That is the only thing that could Zap you if you are sure all power is off. Usually capacitors hold a charge if their is no resistor/ bleeder on it. Find your capacitor(s) round or oval with wires coming off the top. DISCONECT POWER TO UNIT. Short across the terminals on all capacitors with a screw driver to release charge. Do not touch metal part of screw driver while doing this. Then remove your wires form your limit with insulated insulated needle nose pliers.
Posted on Nov 02, 2009
S3RA-036K
Any capacitor of the same rating as old one will work, it doesn't have to be a Intertherm part. I would say its 25-35 ufd 370v.
May 12, 2014 | Intertherm P3RA-030K Air Conditioner
Intertherm furnace parts
if its electric heat one of the sequencers or elements out
Jan 04, 2014 | Intertherm Heating & Cooling
Intertherm feh 015ha
either the heat strips, fusible links on elements or sequencers.
Sep 21, 2013 | Intertherm E3EB010H Electric Furnac
Intertherm furnace. Continuous cycling
Check for air restrictions or replace the filter, this appears to be lack of air in the mixture port if this is suppplied by gas
Jan 06, 2010 | Heating & Cooling
Intertherm Heat Pump
Some of the old heat pumps made the reversing valve in the heating mode. On your new thermostat the orange wire will need to be on the B terminal. If it was color coded? I hope you made notes of how it was.
Jan 05, 2010 | Heating & Cooling
Nov 02, 2009 | Intertherm P3RA-048K Air Conditioner
Need replacement part # and wiring diagram for Nordyne Intertherm E1EH O12HA sequencer
take it to a hvac supply house and they will match it up for you. The wiring diagram will be on the furnace
Oct 30, 2009 | Heating & Cooling
Intertherm furnace/AC, fan on the furnace won't shut off.
How old is the intertherm. The old ones have fan limit switch and sometimes they stick. The new ones have a fan baord or time delay relay. They go bad from moisture and they just go bad sometimes. It sounds like you just have a shorted relay. If you think you can replace it you can get a relay at any parts store. Need the model number of unit. If not just call a service tech for free estimate. Russ
Jul 24, 2009 | Heating & Cooling
Troubleshooting intertherm feh-015ha (FROM FREEZING FAMILY)
Having changed the fuse and breaker tell me there is a major short in you furnace. 240 volts is a lot of amperage and a very delicate job to attempt to help you directly. I have found that any intertherm dealer near you will be happy to help solve your problem. Yes, the sequencers are possible reason but 50 amps at 240 volts is what concerns me. Did your transformer burn out also?
Let me know what you think and if you would like, I will locate the correct source of help. Thanks, JT
Feb 02, 2009 | Heating & Cooling
Intertherm furnace problem?'s
the blower on my furnace keeps going on and off when i turn the furnace on .ichanged the snapdiscs no change changed thermocoupler and therostat still no change whats my problem
Oct 27, 2007 | Intertherm P3RA-048K Air Conditioner
Intertherm P3RA-048K Air Conditioner Logo
158 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
