Question about Peg Perego John Deere Gator HPX Ride on Toy
Need to buy front wheel tires - Peg Perego John Deere Gator HPX Ride on Toy
    Genius:
  • Peg Perego Master
  • 1,508 Answers
You can order a new ones here www.powerwheelsoutlet.com
Posted on Jun 13, 2012
Where can I buy wheels for a schwinn gladiator xc
Most local bike shops can source the proper size wheel that you need. Complete front wheels typically start about $25 and go up from there.
Aug 14, 2014 | Cycling
My car was wrecked and now my front passenger tire is bent inwards
It appears your car may have a damaged or out of alignment tie-rod.
You will need to have your alignment checked and adjusted at a wheel and Tire center or mechanical workshop that conducts wheel alignments, this isn't a very costly job, my last alignment costs was around 56 dollars (they are performed when you buy a new set of tires USUALLY), but your experience may vary depending on if the rod is damaged and needs to be replaced.
Oct 21, 2012 | Cars & Trucks
I need a front wheel or tyre and innertube. size of the tyre is 7x 1 3/4
Front wheels have solid tires with no tubes. You can only buy a compete set of front wheels from Bugaboo or Local agent. If you do plan to buy look at buying the bigger snow wheels they give a better ride.
Feb 20, 2011 | Bugaboo Cameleon Jogger
Wolbel in left front wheel
Does the steering wheel shake side to side while driving it as well? this may be due to a separated tire or bent rim.
Jan 10, 2011 | 1998 Pontiac Bonneville
What are the largest tires (width) that I can put on my 03 FXST (both rear and front) without doing any modifications. Thanks!
Hi.
Standard tires are already oversized in 03 model. This are the maximum standard allowed, probably the same as what you already have:
Front - D402F MH90-21 54H
Rear - D401 150/80B16 71H
(front: 80/90 - rear :150/80-it was 130 in 02 model)
Without modification you cannot use any bigger tire. By changing wheel, belt and pulley, you can mount at rear up to 200 at rear (see job done on the 06 softail here).
At front you need to replace wheel and to move the fender. The result is not always great when you do modification to front wheel. The best thing to do is buying a spacer kit.
Regards
Ginko.
Nov 12, 2010 | Harley Davidson FXST Softail Standard...
How big of a problem is an oil leak and a hard left pull while driving??
OIL LEAK BIG PROBLEM.COST MONEY TO BUY OIL.AND COST MONEY TO BUY A NEW ENGINE.NEED FIX IT QUICK AS POSSIBLE. HARD LEFT PULL WHILE COULD BE LOW TIRE PRESSURE OR MISMATCH TIRES ONE TIRE BIGGER THAN THE OTHER TIRE.BROKEN OR SAGGING SPRINGS.WHEEL ALIGNMENT IS OFF.FRONT BRAKE DRAGGING.
May 17, 2010 | 1995 Nissan Maxima
Vibration? when i lease the handel bar, my front wheel shake Why?
your tire is wearing out/scalloped..run you hand over the tire from on side to the other does it have a wavy pattern to it..buy a new tire... this has happened to me and it can get dangerous....seriously i put off buying the front tire because i felt it still had some life left in it, but i was heading down a road that i wasn't too familiar with and hit a rut going 65 it caused the front end to come up a little and when it came back down... it put me into the biggest Tank Slapper i"ve ever been in... it was so bad that i released the bars to get ready to go down and instantly the steering returned to normal after the bike slowed to about 40mph...the first time this happen to me i didn't even know what it was, same tire of course, but months earlier ..i popped a wheelie by accident in second gear and when it came back down i though i must have broke a bearing or something a little tank slapper. So be careful!
Oct 04, 2009 | 2008 Honda XL 700 V Transalp Abs
Needs snow tires?
This car is great in the snow. It has front wheel drive; however you should buy FOUR snow tires for safety's sake!
Dec 26, 2008 | 1996 Saab 900
Peg Perego John Deere Gator HPX Ride on Toy Logo
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
