Question about Schlage FE595-CAM-ACC FE595-CAM-716-ACC Aged Bronze Electronic Security Key
Schlage FE 595 - - Just quit. Changed battery, codes, etc. Get green blinking light - hear click - doesn't engage. Disassembled - spring good, slides work, placement of round headed pin could be the problem - need help.
  • 963 Answers
This link will take you to the page you need, to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security.....
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number ( the programming code) that you need to reprogram the lock. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! A battery should last about three years under normal usage.
The ninth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Posted on Nov 09, 2011
Lost instruction book. Need to know how to chance codes
I'm directing you to this page, where you will be able to scroll down and find the information for your lock FE 595. Here you should find everything you need to know. Good luck!
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Just cut and paste the link into your browser or type it in directly in the search bar.
Jul 14, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
When I punch in my code for my Schlage FE595, the code is accepted and the schlage key blinks, however, it does not allow for the unlocking or for me to open the door. Also, when I set my door from the...
You did not indicate whether this is a new installation that you are having difficulty with,but I'm going to assume that it is.
I'm going to direct you to a web page that has a wealth of information for the Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
This page has links to the PDF file of the installation instructions, which you should already have in your possession:
http://consumer.schlage.com/Project%20Documents/P515-859.pdf
Also, there are two videos that may be helpful in troubleshooting your problem:
Installing your FE 595 Keypad Entry Lock video:
And, Programming Your FE 595 Keypad Entry Lock:
The reason that I think it's a good idea to review these two videos is that again, assuming this is a new installation, is that you may spot a mistake in the initial installation process.
Was the "Thumbturn" in the proper position when the inside plate was installed? (Shown at the 5 minute mark of the installation video)
Also to be found on the Service Support page link is a link to Schlage's Service & Support
which will allow you to contact Schlage if the problem remains unresolved after reviewing your installation.
I hope this helped. Good luck!
May 20, 2011 | Schlage FE595-PLY-FLA FE595PLY620FLA...
My schlage keypad lock has worked fine for a year. Yesterday, I entered the code and the handle would move but nothing would engage to open the door. It was if I was using the wrong entry code. I...
This is the first place I urge you to look for information on your lock:
On this page you will find links to installation instructions and videos for the various models of Schlage locksets.
I f you are not able to resolve your problem from there, then I recommend that you contact their Customer Service (under the Service and Support link) also found on that page.
There's always a good chance that you can press them to cover repair parts or replacement of your lock, even if it is out of warranty.
May 13, 2011 | Schlage Locks & Locksmithing
I have followed the instructions on how to change my entrance code, but am not being successful. I even changed the nine volt thinking that might be the problem. It blinks red quite a bit. Do I have to...
Here is a very useful link to a video on reprogramming the BE365 lock:
Apr 26, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Golden companion II full charge turn key on press lever to go forward it dont move hear clicking sound green light on dash blinks
John count the number of flashes by the green light and it will be the fault code indicating the problem Your owners manual should list the fault codes to be able to determine what the problem is. Ie 4 blinks pause 4 blinks pause. The clicking you hear is the electric brakes being engaged. Hope this helps
Mar 01, 2011 | Golden Technologies Companion II Travel...
Need to reset code. i know the cod now .just dont know how to enter new one
There's a video link on this page, under the FE 595 header:
Feb 05, 2011 | Schlage FE595VCAM716ACC Camelot Keypad...
I have the same kind of problem. I have the programming code, but when I enter it, after entering the 4 th digit the lock blinks an error thinking I entered an incorrect user code?? So I think I might have...
Restore the lock first
1.disconnect battery
2.press and release the SCHLAGE button
3.reconnect the bat and wait until SCHLAGE is no longer lit.
4. within 10 sec,press and hold SCHLAGE until SCHLAGE lights green and the lock beeps.
The lock is back to factory now.
Now add your user code.
Adding a new user code
DPC is-digit programming code
DUC is digit user code
Yellow sticker has factory 6 digit programming and 4 digit user code on it.
1. 6DPC push SCHLAGE, push 1, enter 4DUC twice.
this lock will only take 2 user codes.
Hope this helps. Leave feedback for others if it helps
Aug 30, 2009 | Schlage BE365-PLY BE365PLY626 Satin...
Door opens half way then closes quickly with electric operation sprayed wd40 on rollers but still not working properly
Sounds like the 9 volt battery is very low, please put in a new, fresh 9 volt battery and see if that helps, as you've already addressed any issues with sticking, etc. When the battery(ies) are low, some electronic locks don't have enough power to fully pull in the dead bolt and the internal spring can overpower the small motor and cause the lock to re-engage quickly.
If you're getting a flashing red light when you enter in your key code, followed by flashing green light, your battery is low, if you're getting a flashing red light, the batteri is critically low.
If you have recently installed this lockset, it is possible that the alignment is off and is causing the deadbolt to drag and is preventing free movement. You'll need to adjust the lockset to allow the deadbolt to move freely by turning the hand knob with the door shut all the way.
If that doesn't help, please contact Schlage directly by calling them at the numbers provided:
United States Customer Support
Warranty Information: 1.888.805.9837 All Other Inquiries: 1.800.847.1864 Canada Customer Support
Within Canada & US: 1.800.900.4734
Hope you find this helpful, best regards!
Aug 15, 2009 | Schlage Camelot Deadbolt Keypad, Satin...
Mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
May 31, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Schlage FE595-CAM-ACC  FE595-CAM-716-ACC Aged Bronze Electronic Security Key Logo
778 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
