Question about Electrolux EW1000i Front Load Washer
Help!do not open the door EWF 8556 after finish washing
  • 183 Answers
SOURCE: WF100 door wont open
The interlock has jammed, first try gently pushing the door frame on the latch side of the door and then hit the outer door frame with your fist, not too hard but a reasonable bang this may release the door, if this works spray a lubricant into the latch hole in the panel, open and close the door a few times before reusing, if this fails then you have to force the door open, the best way is to remove the lid and manouver the door lock from the inside, either the lock or the latck will eventually break, this is unavoidable, then replace the interlock and any other broken part.
Regards
Advisor
Posted on Nov 17, 2007
  • 21 Answers
SOURCE: Front loader door will not open after a washing cycle is finished
call the repair man it is a comp. issue
Posted on Feb 14, 2009
  • 3 Answers
SOURCE: Hi i have a electrolux ewf 1074 front loader. it
Press and hold the 'Delay' and 'Extra Rinse' buttons together and it will 'unlock' your control panel (this is a tamper proof feature for the kiddies)
Posted on Jun 11, 2009
  • 104 Answers
SOURCE: Indesit wd 125. Wash cycle had finished, door lock was off but
Unplug machine, take lid off and locate the door lock. You will have to use a small screwdriver or something to release the lock. Then replace your door handle.
Posted on Jan 28, 2010
  • 1382 Answers
SOURCE: unable to open door
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Posted on Jul 04, 2010
Ewf 8556
Good Morning Mass manana,
I see that you are looking to reset your Electrolux washer due to the fact that the "Start/Pause" button does not appear, and you can't start your laundry. You can reset this appliance. What you will need to do is either unplug it or you can shut the power off at the circuit breaker. When you do this you will need to leave it off for at least 2-3 minutes. Cut the power back on, start any cycle. If you are still having trouble not being able to start the washer, I suggest either contact the manufacturer or your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Mar 26, 2014 | Electrolux Washing Machines
Door locked
Try turning the main power off at the socket for 5 mins - the door may open then , if not turn the power back on and see what happens.
i had this problem on an Electrolux and it worked.
Jan 22, 2014 | Washing Machines
My Electrolux EWF 8556 Front Loading washer wont Start
Hi I would check the plug to see if the wires have come loose or the fuse is gone in the plug this can happen at any time and its the last place you always look, the plug looks fine but
Nov 15, 2017 | Washing Machines
My electrolux ewf 1087 front loader door wont open
You will need to remove the drum and reset the alignment.
The cloth is struck and has jammed on the drum movement.
click this link: drum removal
Jan 21, 2013 | Electrolux Washing Machines
How do you unsnap the lid clothing stuck under agitator
i bought2 month ago new electrolux washing machine model EWF 8556....now this washing machine will give me a problem......problem is start /stop button always blinking.....and other button also not funtion( spin/option/rinse) also for delay button....... so please help me as soon as possible..... tq
Aug 12, 2010 | Washing Machines
The wash is finished but the door will not open?
You door switch is most likely faulty.
Open the drain filter door in the bottom corner of the machine. See if you can locate a lever or ring to pull down. This will manually release the door.
Regards
Ash
Oct 21, 2009 | Miele Washing Machines
Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
Aug 08, 2009 | Electrolux EW1000i Front Load Washer
Electrolux EW1000i Front Load Washer Logo
225 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
