Question about Samsung RB215LASH
No cooling in refridgerator
I am facing problem in my refridgerator all of sudden it stopped cooling. I have changed my compresser last year. I have purchased this six year back. Pls advice me. my email ID
  • 1,462 Answers
Is freezer cooling?
a possible cause is build up of ice on the evaporator. take off the back panel in the freezer and check. also check the fan is working. if there is excessive ice build up, this can mean that the defrost system is not working. in any case, if there is ice build-up, carefully melt the ice off with a hairdryer
Posted on Jun 19, 2008
Refrigerator not cooling all of a sudden
Most refrigerators do NOT cool all of a sudden, but rather gradually! If you need to cool something all of a sudden, you should consider use a freeze spray of some sort!
May 12, 2017 | Refrigerators
My amana fridge keeps blowing the GFI circuit
change the GFI circuit to 20 amp
Mar 30, 2017 | Refrigerators
2002northland 36" refridgerator and freezer not
The compressor should turn on after it cools. It shuts down if it overheats to prevent damage/fire. The compressor itself could be bad but more than likely the fan is dead.
Jan 11, 2011 | Northland 36SSS Side by Side Refrigerator
Maytag refrigerator mtb2154drq suddenly the refrig stopped cooling but freezer still working. Even with high setting of 9, temp doesn't go below 60degF, while freezer ar 4-5setting is at 25degF. Up until...
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at
Jun 10, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
How can a refrigerator will cool without compressor?
they all have compressers or some way to pressurize the gas, this can also be done wioth a gas flame like in motorhomes, cooling is preformed by compressing the refridgerent and then decompressing it through a metered hole or valve in the high pressure line, this change in state from high pressure to low pressure makes the gas very cold.
Nov 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Freezer side and Refridgerator side are not cooling food
I would find out what it would cost to fix it. If the cost is more than the price of a new one then I would get a new one.
Aug 23, 2009 | Kenmore 51562 / 51564 / 51569
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Samsung RB215LASH Logo
184 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
