Question about Microsoft Windows XP Professional
How to uninstall "microsoft.net framework 2.0
  • 592 Answers
Click on the start button
click on control panel
click add/remove programs
.net framework should be listed about halfway down the list, or there-abouts.
click on whichever version of .net you want to remove
then click on remove and follow the instructions from there
Posted on Nov 30, 2010
sodeep
  • 3267 Answers
SOURCE: microsoft .net framework 3.0 service pack 2 and it put this
Not much except to be careful when taking a printout. You can't remove this XPS document writer so the thing to do is make your deskjet/laserjet printer the default printer and be sure to select the right printer before releasing the print command....sodeep
Posted on May 01, 2009
  • 99 Answers
SOURCE: microsoft.net framework 3.5 service pack 1 and.net
ya now a days some software runs on net frame work 3.5 sp1 for nero 9 etc. if u dont have it. ols refer to microsoft site to download the software. it is free to download at no extra cost.......
Posted on Nov 04, 2009
LASITHA-VEGA
  • 428 Answers
SOURCE: error problem while downloading updates
1. Before doing anything else, write down the .NET Framework versions which
are already installed:
How to determine which versions of the .NET Framework are installed and
whether service packs have been applied
http://support.microsoft.com/kb/318785
2. Now see Resolution Method 2 in http://support.microsoft.com/kb/923100
(ignore the title). After running the appropriate/needed tool, (re)install
all .NET Framework versions manually using the download links on the page.
Posted on May 28, 2010
steve_e_uk
  • 1675 Answers
SOURCE: Can I remove the Windows XP Microsoft.NET
no it over rights the older version every time you get updated..hope this helps please rate thanks
Posted on Aug 21, 2010
  • 10406 Answers
SOURCE: I need to uninstall Microsoft.Net
Either accept the fact that your "install" will have side-effects,
or install Microsoft.Net Version 4 on "top" of Version 2.
Posted on Oct 14, 2010
Tip
How To Completely Remove .Net Framework
Directions:
  1. Download the .NET Framework cleanup tool
  2. Open dotnetfx_cleanup_tool.zip and run cleanup_tool.exe.
  3. Download and reinstall the version of the .NET Framework you want, .NET Framework 3.5 includes .NET Framework 2.0 service pack 1 and .NET Framework 3.0 service pack 1.
Prerequisites:
Note: If you are installing on XP 64 bit or Windows 2003 you might need to install the Windows Imaging Component. The Windows Imaging Component 32 bit can be found here. The Windows Imaging Component 64 bit can be found here.
on Feb 20, 2011 | Computers & Internet
Error problem while downloading updates
May 28, 2010 | Microsoft Windows Vista Ultimate Edition
Can not install Net Framewoek 3.0 because of
Sir,
Run the cleanup tool to clean out temporary files, run the .NET
Framework cleanup tool, Run the installation file, then reboot and try to install it again and see if it works. If not try the below following steps....
Step One:
1. Go to Add or Remove Programs, try to remove all .NET Framework.
2. Please download and install the Windows Installer Cleanup utility
from this link:
http://download.microsoft.com/downlo...BD/msicuu2.exe
3. Then, please run it from Start-> All Programs-> Windows Install
Clean Up.
4. Please remove all Microsoft .NET Framework shown there and click
Remove.
Step Two:
1. Click Start->Run, type INSTALLER and click OK.
2. In the open folder, click View menu and select Details.
3. Right-click the Date Modified column header.
4. Click Comments
5. In the Comments column, locate the cached Windows Installer file
that displays Microsoft .NET Framework 1.1 (English) RTL x86 enu.
6. Right-click the cached Windows Installer file and then click
Uninstall.
7. Close the window.
8. Delete the cached Windows Installer file.
Step Three:
1. Restart your computer.
2. While your computer is booting up, press F8 to invoke the startup
menu.
3. In the startup menu, choose Safe Mode.
4. Log on as an administrator.
Note: In Safe Mode, your system display and Desktop will look and
perform differently than in Normal Mode. This is only temporary.
5. Delete the folder C:\WINDOWS\Microsoft.NET
6. Delete the folder C:\WINDOWS\system32\URTTemp
7. In the C:\Windows\System32 folder, locate the file mscoree.dll.
Right click and rename it to mscoree.old
Step Four:
1. Click Start->Run, type REGEDIT and click OK.
2. Navigate to the following registry key by expanding the "+" beside
the registry tree in the left pane:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework
3. Delete this key in the left pane.
4. Repeat steps 2-3 to delete the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup
5. Restart your computer to Normal Mode
Step Five:
1. Please download the Microsoft .NET Framework Version 1.1
Redistributable Package from the following link and save it to C:
http://www.microsoft.com/downloads/d...DisplayLang=en
2. Click Start->Run, type "c:\dotnetfx.exe /C" (without quotation marks
and there is a space in this command) in the open box and click OK.
3. Click Run, and type "C:\.NET Framework 1.1" (without quotation
marks) in the open box click OK
Note: If you are prompted to create this folder, please click Yes to
continue.
4. Locate the folder C:\.NET Framework 1.1 and double click the file
netfx.msi in it to install .NET Framework components.
If .NET Framework 1.1 can be successfully installed, we can go on to
install .NET Framework 1.1 Service Pack 1:
Microsoft .NET Framework 1.1 Service Pack 1
Step Six:
If the above two can be installed correctly, please download KB886903
from the following link and install again:
http://www.microsoft.com/downloads/d...displaylang=en
If the problem still exists, please describe the error message when
installing Microsoft .Net Framework Service Pack in further detail
Thanks
Good luck
Nov 07, 2009 | Microsoft Computers & Internet
Vista error codes 643 and 646
the error codes that you have mention is related to windows update of Microsoft .net framework.
To troubleshoot this issue, I suggest we first perform these steps:
Step 1: Download Microsoft Windows Installer CleanUp utility
1. Visit:
2. Save the file to your computer.
3. Right click "msicuu2.exe", click "Run as administrator" and follow the
wizard to install this tool on your computer.
Step 2: Remove .NET Framework
1. Click Start ->All Programs->Windows Installer Clean Up, click Allow.
2. See if you can find .Net Framework software. If so, remove them.
After that, please restart the computer and perform the following
suggestions to reinstall .NET framework 1.1 and the updates for it.
Step 3: Install .NET Framework 1.1 Redistributable Package and related updates
1. Please download the Microsoft .NET Framework Version 1.1 Redistributable
Package from the following link and save it to the C drive (C:\)
1) Microsoft .NET Framework Version 1.1 Redistributable Package
http://download.microsoft.com/downlo...6/dotnetfx.exe
2) Microsoft .NET Framework 1.1 Service Pack 1
http://download.microsoft.com/downlo...867460-X86.exe
3) Security Update for Microsoft .NET Framework, Version 1.1 Service Pack 1
(KB928366)
http://www.download.windowsupdate.co...d81a178b15.exe
4) .NET Framework 1.1 Service Pack 1 SYSTEM.WEB.DLL and MSCOREE.DLL Security
Update for Windows Vista (KB929729)
http://download.microsoft.com/downlo...929729-X86.exe
Please follow the steps above and if still problem persist please lets us know
Regards,
Om
Oct 20, 2009 | Computers & Internet
.Net Framework 1.1 sp1 Install Fails
You need to uninstall and install the latest version of .net frame work
You can download it from www.microsoft.com/downloads
Apr 15, 2009 | Microsoft Windows Vista Home Premium with...
HP colour laserjet 1600 not recognised by USB port
I believe the problem is related to microsoft .NET Framework. I have researched and there are many posts of incompatibility between .NET Framework and many printers not just 1600. My 1600 stopped working and I traced the problem to upgrade to .NET Framework 3.5 I uninstalled 1600, then uninstalled .NET Framework 3.5 (and 3.0 as well for good measure), reinstalled 1600 and it is working fine now again. You can uninstall .NET versions using Add/Remove programs on the Control Panel. To avoid re-updating, I also turned off Windows automatic updates. I left .NET Framework 2.0. No problems with other programs but the computer did have trouble rebooting the very first time after I uninstalled .NET Framework 3.5 and 3.0. Unknown if that was related to the uninstall or a completely unrelated problem. Anyway if you want to try something less drastic than removing .NET versions, check out this Microsoft link:
http://support.microsoft.com/kb/961118
refers to a printer fix related to .NET. In my experience, the Microsoft fixes never work but you are welcome to try before uninstalling .NET Framework versions.
Jan 16, 2009 | Office Equipment & Supplies
I have been trying to download the drivers for Lexmark printer Z53 for a week. I've tried several times on two different computers and keep getting error "message 1603 error installing Microsofft.net...
Windows Update error code "0x643" and Windows Installer error code "1603" are generic error codes. Typically, these error codes mean that the update was not installed. These errors codes are usually caused by a corruption in the .NET Framework installation or by an inconsistency on the MSI database state.
Method 1: Manually remove and reinstall .NET Framework loadTOCNode(2, 'resolution'); To manually remove and reinstall the .NET Framework, follow these steps:
  1. Remove the .NET Framework.
    1. Click Start, and then click Control Panel.
    2. Double-click Add or Remove Programs.
    3. Note each version of the .NET Framework that is already installed on the computer. Then, uninstall all the versions of the .NET Framework.
    4. When you are prompted, restart the computer.
  2. Use the Windows Installer CleanUp Utility to clean up the MSI database state for all the versions of the .NET Framework.
    1. Download the Windows Installer CleanUp Utility. The following file is available for download from the Microsoft Download Center:
      Download the Windows Installer CleanUp Utility package now. (http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe)
      For more information about how to download Microsoft support files, click the following article number to view the article in the Microsoft Knowledge Base: 119591 (http://support.microsoft.com/kb/119591/ ) How to obtain Microsoft support files from online services Microsoft scanned this file for viruses. Microsoft used the most current virus-detection software that was available on the date that the file was posted. The file is stored on security-enhanced servers that help prevent any unauthorized changes to the file.
    2. Install the Windows Installer CleanUp Utility as an administrator or as a user account that is a member of the local Administrators group.
    3. Click Start, point to All Programs, and then click Windows Install Cleanup.
    4. In the Windows Installer CleanUp Utility, remove all Windows Installer applications for the .NET Framework.
  3. Restart the computer.
  4. Download and then reinstall all the versions of the .NET Framework that were previously installed on the computer.
    To download the .NET Framework 1.0, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?FamilyID=d7158dee-a83f-4e21-b05a-009d06457787&DisplayLang=en (http://www.microsoft.com/downloads/details.aspx?FamilyID=d7158dee-a83f-4e21-b05a-009d06457787&DisplayLang=en) To download the .NET Framework 1.0 Service Pack 3, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=6978D761-4A92-4106-A9BC-83E78D4ABC5B&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=6978D761-4A92-4106-A9BC-83E78D4ABC5B&displaylang=en) To download the .NET Framework 1.1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=262D25E3-F589-4842-8157-034D1E7CF3A3&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=262D25E3-F589-4842-8157-034D1E7CF3A3&displaylang=en) To download the .NET Framework 1.1 Service Pack 1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en) To download the .NET Framework 2.0, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5&DisplayLang=en (http://www.microsoft.com/downloads/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5&DisplayLang=en) To download the .NET Framework 2.0 Service Pack 1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=79BC3B77-E02C-4AD3-AACF-A7633F706BA5&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=79BC3B77-E02C-4AD3-AACF-A7633F706BA5&displaylang=en) To download the .NET Framework 3.0, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=10CC340B-F857-4A14-83F5-25634C3BF043&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=10CC340B-F857-4A14-83F5-25634C3BF043&displaylang=en) To download the .NET Framework 3.0 Service Pack 1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=EC2CA85D-B255-4425-9E65-1E88A0BDB72A&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=EC2CA85D-B255-4425-9E65-1E88A0BDB72A&displaylang=en) To download the .NET Framework 3.5, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=333325FD-AE52-4E35-B531-508D977D32A6&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=333325FD-AE52-4E35-B531-508D977D32A6&displaylang=en)
  5. When you are prompted, restart the computer.
Note When you have reinstalled all the versions of the .NET Framework, you can use Windows Update to check for updates to the .NET Framework.
Dec 02, 2008 | Office Equipment & Supplies
You cannot install the Microsoft .NET Framework 1.1 because the NET Framework 2 is already installed. The NET Framework 2 is the latest version of Microsoft NET Framework. I think you can remove the latest Framework in the Add/Remove Programs from the Control Panel. Then restart your computer and install the old version. But my advice is, just let the latest NET Framework remain and don't uninstall it.
Jun 02, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
70 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
