SOURCE: vaillant 831 combi boiler timer help
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
SOURCE: need to set the timer!!!
Jonathan,
See this link:
http://www.glow-worm.co.uk/products/pdf/discontinued/boilers/CXI_range.pdf
Hope this helps!
SOURCE: combi boiler problem
most have an overrun built in for a few minutes. if much longer have you got a room thermostat anywhere to turn down
If it never turns off check the switch which controls ON/TIMED/OFF and turn to timed or off. if it still continues on timed then it's the timer
SOURCE: Girlie - Cannot set combi boiler timer
Being the girl that you are, I'll step forward and ask your need. Can you take a phone cam pic and send it to me so I can see what the rtimer looks like. [email protected]
SOURCE: no info how to set my boilers digital clock/timer
[email protected] mail me if i have one i will mail it to you
